<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Will MM finally work on Pi zero 2 W?]]></title><description><![CDATA[<p dir="auto"><strong>I want to run MM on Pi zero 2 W.</strong><br />
There is a lot of information out there, but is it possible to finally make it work?<br />
Is it possible to automatically start using PM2?<br />
Please tell me how to do it if possible.</p>
]]></description><link>https://forum.magicmirror.builders/topic/18093/will-mm-finally-work-on-pi-zero-2-w</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 22:48:19 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18093.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Oct 2023 00:21:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Will MM finally work on Pi zero 2 W? on Mon, 16 Oct 2023 10:46:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ryus" aria-label="Profile: ryus">@<bdi>ryus</bdi></a> see<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/111786</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111786</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 16 Oct 2023 10:46:49 GMT</pubDate></item><item><title><![CDATA[Reply to Will MM finally work on Pi zero 2 W? on Mon, 16 Oct 2023 04:32:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Thank you for your reply<br />
Were you able to execute it?</p>
]]></description><link>https://forum.magicmirror.builders/post/111783</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111783</guid><dc:creator><![CDATA[ryus]]></dc:creator><pubDate>Mon, 16 Oct 2023 04:32:08 GMT</pubDate></item><item><title><![CDATA[Reply to Will MM finally work on Pi zero 2 W? on Mon, 16 Oct 2023 00:26:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ryus" aria-label="Profile: ryus">@<bdi>ryus</bdi></a> run my install script on a newly flashed SD card</p>
]]></description><link>https://forum.magicmirror.builders/post/111769</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111769</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 16 Oct 2023 00:26:44 GMT</pubDate></item></channel></rss>
