<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Failed Update]]></title><description><![CDATA[<p dir="auto">I tried to Update my wife’s mirror and got this error ( I tried  to stop MM with no success as It is still running)</p>
<p dir="auto">Linux MAGIC-MIRROR 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64</p>
<p dir="auto">The programs included with the Debian GNU/Linux system are free software;<br />
the exact distribution terms for each program are described in the<br />
individual files in /usr/share/doc/*/copyright.</p>
<p dir="auto">Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent<br />
permitted by applicable law.<br />
Last login: Tue Oct 17 13:12:23 2023<br />
junior@MAGIC-MIRROR:~ $ bash -c  “$(curl -sL <a href="https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh</a>)”<br />
bash: line 117: [: !=: unary operator expected</p>
<p dir="auto">doing test run = true, NO updates will be applied!</p>
<p dir="auto">update log will be in /home/junior/MagicMirror/installers/upgrade.log<br />
Check current Node installation …<br />
Node currently installed. Checking version number.<br />
Minimum Node version: v20.8.0<br />
Installed Node version: v16.20.2<br />
Node should be upgraded.<br />
A Node process is currently running. Can’t upgrade.<br />
Please quit all Node processes and restart the update.<br />
running process(s) are<br />
junior 3451 3450 0 Oct17 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js<br />
junior@MAGIC-MIRROR:~ $</p>
<p dir="auto">.js<br />
junior@MAGIC-MIRROR:~ $ ^C<br />
junior@MAGIC-MIRROR:~ $ pm2 stop mm</p>
]]></description><link>https://forum.magicmirror.builders/topic/18111/failed-update</link><generator>RSS for Node</generator><lastBuildDate>Sat, 15 Aug 2026 16:45:17 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18111.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 22 Oct 2023 08:28:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Failed Update on Tue, 31 Oct 2023 14:02:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  I did this<br />
sudo apt-get remove nodejs npm -y<br />
hash -r<br />
which node<br />
which n</p>
<p dir="auto">if which n response with empty then do</p>
<p dir="auto">sudo apt-get install n</p>
<p dir="auto">once n responds then</p>
<p dir="auto">sudo n 20.8.0	--arch armv7l<br />
hash -r<br />
node -v</p>
<p dir="auto">Then both scripts and it went through!</p>
]]></description><link>https://forum.magicmirror.builders/post/112207</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112207</guid><dc:creator><![CDATA[DarkV]]></dc:creator><pubDate>Tue, 31 Oct 2023 14:02:50 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Thu, 04 Jan 2024 18:02:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Many thanks. Will backup the system before I try.</p>
]]></description><link>https://forum.magicmirror.builders/post/113942</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113942</guid><dc:creator><![CDATA[DarkV]]></dc:creator><pubDate>Thu, 04 Jan 2024 18:02:58 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Fri, 05 Jan 2024 03:35:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darkv" aria-label="Profile: DarkV">@<bdi>DarkV</bdi></a> I think I have fixed the upgrade script.<br />
of course backup your mm system,</p>
<p dir="auto">use my backup restore scripts.<br />
<a href="https://github.com/sdetweil/MagicMirror-backup-restore" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror-backup-restore</a></p>
<p dir="auto">if you have space, copy the entire mm folder to another to save it.</p>
<p dir="auto">don’t upgrade if there is nothing you need</p>
]]></description><link>https://forum.magicmirror.builders/post/113798</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113798</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 05 Jan 2024 03:35:31 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Tue, 02 Jan 2024 09:19:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darkv" aria-label="Profile: DarkV">@<bdi>DarkV</bdi></a> Sorry to bug you again, but there is an update, since you said that my setup in a Hybrid setup, what script do I use?  The wifey will kill me if I mess it up and for some reason I cannot backup my M2 Sata drive with Windows 11 as it is not detected, meaning I have one shot to get it right</p>
]]></description><link>https://forum.magicmirror.builders/post/113787</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113787</guid><dc:creator><![CDATA[DarkV]]></dc:creator><pubDate>Tue, 02 Jan 2024 09:19:09 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Sat, 04 Nov 2023 10:29:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darkv" aria-label="Profile: DarkV">@<bdi>DarkV</bdi></a> Thanks. I found a way to create the hybrid system so I could test your original.problem…</p>
]]></description><link>https://forum.magicmirror.builders/post/112296</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112296</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 04 Nov 2023 10:29:05 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Sat, 04 Nov 2023 10:03:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> My image is 112GB (although only 8.4 GB is used) as I used  Win32 disc imager software. If you still want me to upload let me know although I don’t know a site that will allow a file that large.</p>
]]></description><link>https://forum.magicmirror.builders/post/112295</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112295</guid><dc:creator><![CDATA[DarkV]]></dc:creator><pubDate>Sat, 04 Nov 2023 10:03:28 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Fri, 03 Nov 2023 16:08:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darkv" aria-label="Profile: DarkV">@<bdi>DarkV</bdi></a> thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/112292</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112292</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 03 Nov 2023 16:08:40 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Fri, 03 Nov 2023 20:09:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> The Image was my previous install  I made in February when I migrated from SD to M2 SSD.  So an older version of what I am using now.<br />
I am using PI4.</p>
]]></description><link>https://forum.magicmirror.builders/post/112291</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112291</guid><dc:creator><![CDATA[DarkV]]></dc:creator><pubDate>Fri, 03 Nov 2023 20:09:28 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Fri, 03 Nov 2023 07:54:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Sam, sorry for the confusion, everything is working. A said I had installed node 18 and then it all worked. I didn’t need help, just wanted to point out that node 20 seems to not be working with some systems. But as I see you got that covered in your script.</p>
]]></description><link>https://forum.magicmirror.builders/post/112284</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112284</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Fri, 03 Nov 2023 07:54:29 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Thu, 02 Nov 2023 21:46:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> ok, can you do</p>
<pre><code>sudo apt update --fix-missing
sudo apt install -f
<p dir="auto">watch out for node changing…</p>
]]></description><link>https://forum.magicmirror.builders/post/112272</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112272</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 02 Nov 2023 21:46:30 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Thu, 02 Nov 2023 21:09:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Sorry I have BUSTER installed. My mistake.</p>
<p dir="auto">Here the lastlog</p>
<pre><code>Upgrade started - Wed Nov  1 10:25:06 CET 2023
system is Linux magicmirror 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
n (node version manager tool) not installed, doing test run, install skipped
Check current Node installation ...
Minimum Node version: v18.18.0
Upgrade started - Wed Nov  1 10:45:19 CET 2023
user requested to force apply changes
node not installed, trying via apt-get
Reading package lists... Building dependency tree... Reading state information... nodejs is already the newest version (20.9.0-1nodesource1). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
npm not installed, trying via apt-get
npm NOT installed now, install now
Reading package lists... Building dependency tree... Reading state information... Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: npm : Depends: nodejs (&gt;= 6.11~) Depends: node-abbrev (&gt;= 1.1.1~) but it is not going to be installed Depends: node-ansi-regex (&gt;= 3.0~) but it is not going to be installed Depends: node-ansistyles (&gt;= 0.1.3~) but it is not going to be installed Depends: node-aproba (&gt;= 1.2~) but it is not going to be installed Depends: node-archy (&gt;= 1.0~) but it is not going to be installed Depends: node-cacache (&gt;= 10.0.4~) but it is not going to be installed Depends: node-bluebird (&gt;= 3.5.1~) but it is not going to be installed Depends: node-call-limit (&gt;= 1.1~) but it is not going to be installed Depends: node-chownr (&gt;= 1.0.1~) but it is not going to be installed Depends: node-config-chain (&gt;= 1.1.11~) but it is not going to be installed Depends: node-detect-indent (&gt;= 5.0~) but it is not going to be installed Depends: node-detect-newline (&gt;= 2.1~) but it is not going to be installed Depends: node-editor (&gt;= 1.0~) but it is not going to be installed Depends: node-fs-vacuum (&gt;= 1.2.10~) but it is not going to be installed Depends: node-fs-write-stream-atomic (&gt;= 1.0.10~) but it is not going to be installed Depends: node-glob (&gt;= 7.1.2~) but it is not going to be installed Depends: node-graceful-fs (&gt;= 4.1.11~) but it is not going to be installed Depends: node-has-unicode (&gt;= 2.0.1~) but it is not going to be installed Depends: node-hosted-git-info (&gt;= 2.6~) but it is not going to be installed Depends: node-iferr (&gt;= 0.1.5~) but it is not going to be installed Depends: node-inflight (&gt;= 1.0.6~) but it is not going to be installed Depends: node-inherits (&gt;= 2.0.3~) but it is not going to be installed Depends: node-ini (&gt;= 1.3.5~) but it is not going to be installed Depends: node-npm-package-arg but it is not going to be installed Depends: node-promzard but it is not going to be installed Depends: node-jsonstream (&gt;= 1.3.2~) but it is not going to be installed Depends: node-json-parse-better-errors (&gt;= 1.0.1~) but it is not going to be installed Depends: node-lazy-property (&gt;= 1.0~) but it is not going to be installed Depends: node-libnpx (&gt;= 10.0.1~) but it is not going to be installed Depends: node-lockfile (&gt;= 1.0.3~) but it is not going to be installed Depends: node-lru-cache (&gt;= 4.1.1~) but it is not going to be installed Depends: node-mississippi (&gt;= 3.0~) but it is not going to be installed Depends: node-mkdirp (&gt;= 0.3.3) but it is not going to be installed Depends: node-move-concurrently (&gt;= 1.0.1~) but it is not going to be installed Depends: node-nopt but it is not going to be installed Depends: node-normalize-package-data (&gt;= 2.4~) but it is not going to be installed Depends: node-gyp (&gt;= 3.6.2~) but it is not going to be installed Depends: node-resolve-from (&gt;= 4.0~) but it is not going to be installed Depends: node-encoding but it is not going to be installed Depends: node-errno but it is not going to be installed Depends: node-npmlog (&gt;= 4.1.2~) but it is not going to be installed Depends: node-once (&gt;= 1.4~) but it is not going to be installed Depends: node-opener (&gt;= 1.4.3~) but it is not going to be installed Depends: node-osenv (&gt;= 0.1.5~) but it is not going to be installed Depends: node-path-is-inside (&gt;= 1.0.2~) but it is not going to be installed Depends: node-promise-inflight (&gt;= 1.0.1~) but it is not going to be installed Depends: node-ansi but it is not going to be installed Depends: node-qw (&gt;= 1.0.1~) but it is not going to be installed Depends: node-read (&gt;= 1.0.7~) but it is not going to be installed Depends: node-read-package-json (&gt;= 2.0.13~) but it is not going to be installed Depends: node-request (&gt;= 2.83~) but it is not going to be installed Depends: node-retry (&gt;= 0.10.1~) but it is not going to be installed Depends: node-rimraf (&gt;= 2.6.2~) but it is not going to be installed Depends: node-safe-buffer (&gt;= 5.1.1~) but it is not going to be installed Depends: node-semver (&gt;= 5.5~) but it is not going to be installed Depends: node-sha (&gt;= 2.0.1~) but it is not going to be installed Depends: node-slide (&gt;= 1.1.6~) but it is not going to be installed Depends: node-sorted-object (&gt;= 2.0.1~) but it is not going to be installed Depends: node-from2 but it is not going to be installed Depends: node-stream-iterate but it is not going to be installed Depends: node-ssri (&gt;= 5.2.4~) but it is not going to be installed Depends: node-strip-ansi (&gt;= 4.0~) but it is not going to be installed Depends: node-tar (&gt;= 4.4~) but it is not going to be installed Depends: node-text-table (&gt;= 0.2~) but it is not going to be installed Depends: node-uid-number (&gt;= 0.0.6~) but it is not going to be installed Depends: node-unique-filename (&gt;= 1.1~) but it is not going to be installed Depends: node-unpipe (&gt;= 1.0~) but it is not going to be installed Depends: node-boxen (&gt;= 1.2.1~) but it is not going to be installed Depends: node-import-lazy but it is not going to be installed Depends: node-is-npm (&gt;= 1.0~) but it is not going to be installed Depends: node-latest-version (&gt;= 3.0~) but it is not going to be installed Depends: node-semver-diff (&gt;= 2.0~) but it is not going to be installed Depends: node-xdg-basedir (&gt;= 3.0~) but it is not going to be installed Depends: node-validate-npm-package-name (&gt;= 3.0~) but it is not going to be installed Depends: node-which (&gt;= 1.3~) but it is not going to be installed Depends: node-wrappy (&gt;= 1.0.2~) but it is not going to be installed Depends: node-write-file-atomic (&gt;= 2.3~) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
doing test run = false
forcing low Node version
Installed Node version: V1.0.0
<p dir="auto">That was the last failed upgrade. Node V1.0.0 lol. Node 20 was installed.<br />
After that I manually purged Node, installed Node 18 and did the <code>npm run install-mm</code></p>
]]></description><link>https://forum.magicmirror.builders/post/112270</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112270</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Thu, 02 Nov 2023 21:09:39 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Thu, 02 Nov 2023 14:20:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> I check for buster and downgrade to node 18… not bullseye…</p>
<p dir="auto">interested to see the log…</p>
]]></description><link>https://forum.magicmirror.builders/post/112259</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112259</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 02 Nov 2023 14:20:56 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Thu, 02 Nov 2023 12:33:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> can u send me the ~/MagicMirror/installers/upgrade.log</p>
<p dir="auto">so I can see what happened…</p>
<p dir="auto">same userid at gmail</p>
]]></description><link>https://forum.magicmirror.builders/post/112258</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112258</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 02 Nov 2023 12:33:13 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Thu, 02 Nov 2023 12:31:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Sam, I did an update yesterday and found Node 20.8 not working on my raspbian bullseye install.<br />
I had an issue mentioned by someone else here before referring a missing GLIBCXX_3.4.26 file.<br />
I needed to purge and install node 18.x. Then it worked.<br />
Possible that this happens for more users with Raspbian<br />
Bullseye.<br />
I see your upgrade script requests Node 20.8.<br />
Not sure if that may be an issue for other people as well?</p>
]]></description><link>https://forum.magicmirror.builders/post/112257</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112257</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Thu, 02 Nov 2023 12:31:03 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Thu, 02 Nov 2023 13:50:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darkv" aria-label="Profile: DarkV">@<bdi>DarkV</bdi></a> any chance you still have the os image file you are running</p>
<p dir="auto">the info says (from the upgrade.log)</p>
<pre><code>6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
<p dir="auto">only one I can find online says<br />
6.1.21-v7+</p>
<p dir="auto">trying to test fix for the problem you encountered.</p>
<p dir="auto">if you still have the  image file can you give me its name…</p>
<p dir="auto">also, what pi is this,  3 or 4?<br />
thanks</p>
<p dir="auto">| edit:   was able to make one<br />
| install bullseye armhf<br />
| edit /boot/config.txt<br />
add<br />
arm_64bit=1</p>
<p dir="auto">then u will boot 64bit kernel, (seen with uname -a,   aarch64)</p>
<pre><code>Linux raspberrypi4 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64 GNU/Linux
<p dir="auto">and have 32 bit runtime (seen with file /bin/bash</p>
<pre><code>/bin/bash: ELF 32-bit LSB executable
]]></description><link>https://forum.magicmirror.builders/post/112229</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112229</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 02 Nov 2023 13:50:50 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Tue, 31 Oct 2023 14:07:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> No worries,  thanks you for your time</p>
]]></description><link>https://forum.magicmirror.builders/post/112209</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112209</guid><dc:creator><![CDATA[DarkV]]></dc:creator><pubDate>Tue, 31 Oct 2023 14:07:40 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Tue, 31 Oct 2023 14:06:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darkv" aria-label="Profile: DarkV">@<bdi>DarkV</bdi></a> said in <a href="/post/112207">Failed Update</a>:</p>
<p dir="auto">–arch armv7l</p>
<p dir="auto">awesome… it was that sneaky little --arch parm…</p>
<p dir="auto">fixing upgrade script  now .   sorry for your troubles</p>
]]></description><link>https://forum.magicmirror.builders/post/112208</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112208</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 31 Oct 2023 14:06:34 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Tue, 31 Oct 2023 14:02:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  I did this<br />
hash -r<br />
which node<br />
which n</p>
hash -r<br />
node -v</p>
]]></description><link>https://forum.magicmirror.builders/post/112207</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112207</guid><dc:creator><![CDATA[DarkV]]></dc:creator><pubDate>Tue, 31 Oct 2023 14:02:50 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Tue, 31 Oct 2023 13:59:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darkv" aria-label="Profile: DarkV">@<bdi>DarkV</bdi></a> cool… i didn’t expect that it,  i’m glad!!</p>
]]></description><link>https://forum.magicmirror.builders/post/112206</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112206</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 31 Oct 2023 13:59:06 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Tue, 31 Oct 2023 13:55:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I don’t know what happened, but the reply is above. Many thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/112205</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112205</guid><dc:creator><![CDATA[DarkV]]></dc:creator><pubDate>Tue, 31 Oct 2023 13:55:35 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Tue, 31 Oct 2023 13:53:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darkv" aria-label="Profile: DarkV">@<bdi>DarkV</bdi></a>   before you jump off the bridge!  try this</p>
<pre><code>sudo apt-get remove nodejs npm -y
hash -r
<p dir="auto">make sure gone<br />
which node</p>
<pre><code>then
<p dir="auto">sudo apt-get install nodejs:armv7l<br />
node -v</p>
<pre><code></code></pre>
]]></description><link>https://forum.magicmirror.builders/post/112204</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112204</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 31 Oct 2023 13:53:36 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Tue, 31 Oct 2023 13:52:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> All is OK. I am so grateful for all of your assistance. In my opinion, what you performed was alchemy or witchcraft. I’ve been attempting to identify the problem and have made multiple unsuccessful attempts. An old picture I had from a few months ago was my saviour. My wife was becoming tired of my futile attempts at updating.<br />
You have brought me happiness and protected me from madness. That’s a significant victory.<img src="/assets/uploads/files/1698760360008-screenshot-2023-10-31-135119-resized.png" alt="Screenshot 2023-10-31 135119.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/112203</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112203</guid><dc:creator><![CDATA[DarkV]]></dc:creator><pubDate>Tue, 31 Oct 2023 13:52:49 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Tue, 31 Oct 2023 13:49:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darkv" aria-label="Profile: DarkV">@<bdi>DarkV</bdi></a>  never mind that won’t work… need node and npm to install n…  grr…</p>
<p dir="auto">ok, only way out is to redo the sd card<br />
backup your MM<br />
see <a href="https://github.com/sdetweil/MagicMirror-backup-restore" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror-backup-restore</a></p>
<p dir="auto">copy the backup folder MM_backup off the sd card (it can save to github too)</p>
<p dir="auto">reflash the sd card with latest os<br />
boot, no updates,<br />
run install script to install MM<br />
verify it runs<br />
restore your config using my restore script (can restore directly from github too)</p>
<p dir="auto">test</p>
<p dir="auto">sorry, the nodejs guys made a mess of this as they changed the node install process too… and it doesn’t work.</p>
]]></description><link>https://forum.magicmirror.builders/post/112202</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112202</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 31 Oct 2023 13:49:10 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Tue, 31 Oct 2023 13:37:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darkv" aria-label="Profile: DarkV">@<bdi>DarkV</bdi></a> man this is a pain</p>
<p dir="auto">one more try</p>
hash -r
which node
which n
<pre><code>sudo apt-get install n
<pre><code>sudo n 20.8.0	--arch armv7l
hash -r
node -v
<p dir="auto">should say V20.8.0</p>
<p dir="auto">i notice that I didn’t copy this little part from the install script…</p>
<p dir="auto">please let me know</p>
]]></description><link>https://forum.magicmirror.builders/post/112201</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112201</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 31 Oct 2023 13:37:30 GMT</pubDate></item><item><title><![CDATA[Reply to Failed Update on Tue, 31 Oct 2023 13:18:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/112199">Failed Update</a>:</p>
<p dir="auto">file /bin/bash</p>
<p dir="auto">unior@MAGIC-MIRROR:~ $ bash -c  “$(curl -sL <a href="https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh</a>)” apply<br />
curl: (18) transfer closed with 23780100 bytes remaining to read<br />
xz: (stdin): Unexpected end of input<br />
tar: Unexpected EOF in archive<br />
tar: Error is not recoverable: exiting now</p>
<p dir="auto">Error: failed to download archive for 20.8.0</p>
<p dir="auto">doing test run = false<br />
Installed Node version: v20.5.1<br />
Installing Node.js …<br />
Reading package lists… Done<br />
Building dependency tree… Done<br />
Reading state information… Done<br />
nodejs is already the newest version (20.5.1-deb-1nodesource1).<br />
The following packages were automatically installed and are no longer required:<br />
libfuse2 raspinfo<br />
Use ‘sudo apt autoremove’ to remove them.<br />
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.<br />
node version is<br />
Node.js installation Done! version=v20.5.1<br />
npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See <a href="https://v8.dev/blog/math-random" target="_blank" rel="noopener noreferrer nofollow ugc">https://v8.dev/blog/math-random</a> for details.</p>
]]></description><link>https://forum.magicmirror.builders/post/112200</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112200</guid><dc:creator><![CDATA[DarkV]]></dc:creator><pubDate>Tue, 31 Oct 2023 13:18:52 GMT</pubDate></item></channel></rss>
