<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Upgrading from micro SD to M2 SSD]]></title><description><![CDATA[<p dir="auto">I would like to do a fresh install on anM2  SSD to improve speed of my mirror.  I’m currently running an older 32bit OS on a micro SD.<br />
Is there any way to know if upgrading to a 64bit OS on an M2SSD would cause conflicts?  Apologizes for the noob question.</p>
]]></description><link>https://forum.magicmirror.builders/topic/18123/upgrading-from-micro-sd-to-m2-ssd</link><generator>RSS for Node</generator><lastBuildDate>Fri, 14 Aug 2026 19:31:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18123.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 25 Oct 2023 14:17:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Upgrading from micro SD to M2 SSD on Wed, 25 Oct 2023 14:47:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: Nneuland">@<bdi>Nneuland</bdi></a> yeh, that link</p>
<pre><code>Made sure I was running updated client and host,
and that wayland is NOT  running
instead of X11, nothing
<p dir="auto">line split and emphasis on NOT is mine</p>
]]></description><link>https://forum.magicmirror.builders/post/112067</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112067</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 25 Oct 2023 14:47:55 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrading from micro SD to M2 SSD on Wed, 25 Oct 2023 14:43:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Thank you for the reply, Sam.<br />
I am indeed using a 4.  AND vnc is my connection, unfortunately.</p>
<p dir="auto">This reddit thread mentions possible fixes for that.  <a href="https://www.reddit.com/r/raspberry_pi/comments/175dw97/comment/k4fia8o/?share_id=TNg-oqa439pj6ZLxNBGMP&amp;utm_content=2&amp;utm_medium=android_app&amp;utm_name=androidcss&amp;utm_source=share&amp;utm_term=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.reddit.com/r/raspberry_pi/comments/175dw97/comment/k4fia8o/?share_id=TNg-oqa439pj6ZLxNBGMP&amp;utm_content=2&amp;utm_medium=android_app&amp;utm_name=androidcss&amp;utm_source=share&amp;utm_term=1</a></p>
<p dir="auto">I imagine booting and running off of the M2 would be faster, and more space, but havent tried yet.</p>
]]></description><link>https://forum.magicmirror.builders/post/112066</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112066</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Wed, 25 Oct 2023 14:43:53 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrading from micro SD to M2 SSD on Wed, 25 Oct 2023 14:23:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: Nneuland">@<bdi>Nneuland</bdi></a> there were some gpio problems on the early 64 bit versions, I haven’t tested any myself…  so if you have devices attached to the gpio I would suggest testing on an sd card first…</p>
<p dir="auto">also, if your pi is a 4, then the 64 bit uses a new graphics display manager, wayland, instead of x11… and currently vnc  is broken</p>
<p dir="auto">make a backup of your mm setup…<br />
see <a href="https://github.com/sdetweil/MagicMirror-backup-restore" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror-backup-restore</a></p>
<p dir="auto">use my install script for new install.<br />
see <a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
<p dir="auto">my pi4 I boot off sd card, but run off a USB SSD stick… this was built before the boot from USB support was available…<br />
(it works so I don’t fiddle with it)</p>
]]></description><link>https://forum.magicmirror.builders/post/112065</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112065</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 25 Oct 2023 14:23:26 GMT</pubDate></item></channel></rss>
