<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Pir-Sensor - Display remains black]]></title><description><![CDATA[<p dir="auto">Hello everyone,</p>
<p dir="auto">I just repaired my connection of the PIR Sensor and the Pi. Doing so i thought this should be it and the sensor work again.</p>
<p dir="auto">However: For some reason the Module is not working as intended.</p>
<p dir="auto"><strong>Intention:</strong><br />
Monitor being on for 20s when movement has been registered</p>
<p dir="auto"><strong>Current behavior:</strong><br />
Either being ONLY when movement is detected or CONSTANTLY on</p>
<p dir="auto"><strong>Status Quo:</strong><br />
The old code i have used and worked is as follows:</p>
<pre><code>{
	module: 'MMM-PIR-Sensor',
		     sensorPin: 14,
		     powerSaving: true,
	             OffDelay: 20000,
<p dir="auto">Doing so will have the monitor turned off instantly unless i move.</p>
<pre><code>{
		     sensorPin: 14,
		     powerSaving: true,
	             powerSavingDelay: 15,
<p dir="auto">this code will have the MM on “forever” (well i havent been standing infront of the mirror for minutes… so i cant tell if forever…) at least not after 15s</p>
<p dir="auto">I am a bit at a loss as to what has changed… i have not updated any modules or the MM… reconecting the pin 17 to the sensor was all I did…</p>
<p dir="auto">Any help is highly appreciated</p>
]]></description><link>https://forum.magicmirror.builders/topic/18138/mmm-pir-sensor-display-remains-black</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 12:56:17 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18138.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 01 Nov 2023 10:46:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Pir-Sensor - Display remains black on Wed, 01 Nov 2023 12:53:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Thanks for the links. I ran the 2nd script and it came back with constant “motion detected” and “motion stopped” while there was I wasnt moving.</p>
<p dir="auto">Which is a bit strange as the only thing i did was reconnect the existing cable to pin 17… (the soldering came off)</p>
]]></description><link>https://forum.magicmirror.builders/post/112227</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112227</guid><dc:creator><![CDATA[Kastore]]></dc:creator><pubDate>Wed, 01 Nov 2023 12:53:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Pir-Sensor - Display remains black on Sat, 09 Dec 2023 13:36:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kastore" aria-label="Profile: Kastore">@<bdi>Kastore</bdi></a></p>
<p dir="auto">One question: du u use a pull-down or pull-up resistor?</p>
<p dir="auto">If not this might be ur problem, the gpio will detect random activation, it really needs a pull-up or pull-down resistor to work properly.</p>
<p dir="auto">Hope it helps a bit.</p>
]]></description><link>https://forum.magicmirror.builders/post/113123</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113123</guid><dc:creator><![CDATA[diverdennis]]></dc:creator><pubDate>Sat, 09 Dec 2023 13:36:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Pir-Sensor - Display remains black on Wed, 01 Nov 2023 13:31:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Just tried it with another pin (pin 20) and the results are completly different. So i am not sure what to make out of the infos i get from the script.</p>
<p dir="auto">Gosh this is such a bummer that the sensor for some reason decided to quit…</p>
<p dir="auto">Guess i will have to build in a switch or something to turn on the  mirror for X minutes and use the existing script for it</p>
]]></description><link>https://forum.magicmirror.builders/post/112230</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112230</guid><dc:creator><![CDATA[Kastore]]></dc:creator><pubDate>Wed, 01 Nov 2023 13:31:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Pir-Sensor - Display remains black on Wed, 01 Nov 2023 12:54:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kastore" aria-label="Profile: Kastore">@<bdi>Kastore</bdi></a> at least you know its not the MagicMirror module…</p>
]]></description><link>https://forum.magicmirror.builders/post/112228</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112228</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 01 Nov 2023 12:54:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Pir-Sensor - Display remains black on Wed, 01 Nov 2023 12:53:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
]]></description><link>https://forum.magicmirror.builders/post/112227</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112227</guid><dc:creator><![CDATA[Kastore]]></dc:creator><pubDate>Wed, 01 Nov 2023 12:53:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Pir-Sensor - Display remains black on Wed, 01 Nov 2023 12:24:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kastore" aria-label="Profile: Kastore">@<bdi>Kastore</bdi></a> I think the sensor is having trouble.</p>
<p dir="auto">I would test it outside MagicMirror to insure it’s working correctly.</p>
<p dir="auto">there are a few python scripts you can use.<br />
a Google search brings up two as the first choices</p>
<p dir="auto"><img src="/assets/uploads/files/1698841488765-screenshot_20231101_072300_chrome.jpg" alt="Screenshot_20231101_072300_Chrome.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/112226</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112226</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 01 Nov 2023 12:24:50 GMT</pubDate></item></channel></rss>
