<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[magicmirror [DEBUG] config syntax error]]></title><description><![CDATA[<p dir="auto">I am running MM in a docker container.  Everything has been fine up until today.</p>
<p dir="auto">I have run <strong>npm run config:check</strong> from inside the container and it says my config is completely fine.  However although the logs eventually say “ready to go” - it is not.  I cannot get to the webpage -nothing, the container appears to have crashed.</p>
<p dir="auto">Any ideas please.</p>
<p dir="auto">copy default modules to host …<br />
copy css files to host …<br />
chown modules and config folder …<br />
enable mouse cursor …<br />
timezone is Europe/London<br />
start magicmirror</p>
<p dir="auto">magicmirror@2.25.0 server<br />
node ./serveronly<br />
[02.11.2023 16:08.13.554] [LOG]   Starting MagicMirror: v2.25.0<br />
[02.11.2023 16:08.13.555] [LOG]   Loading config …<br />
[02.11.2023 16:08.13.556] [DEBUG] config template file not exists, no envsubst<br />
[02.11.2023 16:08.13.557] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: daily is not defined<br />
at Object. (/opt/magic_mirror/config/config.js:91:6)<br />
at Module._compile (node:internal/modules/cjs/loader:1241:14)<br />
at Module._extensions…js (node:internal/modules/cjs/loader:1295:10)<br />
at Module.load (node:internal/modules/cjs/loader:1091:32)<br />
at Module._load (node:internal/modules/cjs/loader:938:12)<br />
at Module.require (node:internal/modules/cjs/loader:1115:19)<br />
at require (node:internal/modules/helpers:130:18)<br />
at loadConfig (/opt/magic_mirror/js/app.js:117:14)<br />
at App.start (/opt/magic_mirror/js/app.js:247:18)<br />
at Object. (/opt/magic_mirror/serveronly/index.js:4:5)<br />
at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:83:12)<br />
at node:internal/main/run_main_module:23:47<br />
[02.11.2023 16:08.13.558] [LOG]   Loading module helpers …<br />
[02.11.2023 16:08.13.560] [LOG]   Initializing new module helper …<br />
[02.11.2023 16:08.13.560] [LOG]   Module helper loaded: updatenotification<br />
[02.11.2023 16:08.13.561] [LOG]   No helper found for module: helloworld.<br />
[02.11.2023 16:08.13.561] [LOG]   All module helpers loaded.<br />
[02.11.2023 16:08.13.563] [LOG]   Starting server on port 8080 …<br />
[02.11.2023 16:08.13.570] [LOG]   Server started …<br />
[02.11.2023 16:08.13.570] [LOG]   Connecting socket for: updatenotification<br />
[02.11.2023 16:08.13.571] [LOG]   Starting module helper: updatenotification<br />
[02.11.2023 16:08.13.571] [LOG]   Sockets connected &amp; modules started …<br />
[02.11.2023 16:08.13.571] [LOG]<br />
Ready to go! Please point your browser to: <a href="http://localhost:8080" target="_blank" rel="noopener noreferrer nofollow ugc">http://localhost:8080</a></p>
]]></description><link>https://forum.magicmirror.builders/topic/18142/magicmirror-debug-config-syntax-error</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 17:24:25 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18142.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 02 Nov 2023 16:12:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to magicmirror [DEBUG] config syntax error on Thu, 02 Nov 2023 16:42:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Awesome, been puzzling for ages over this.  What a difference two " makes make.</p>
<p dir="auto">Thank you for being a second set of eyes.</p>
]]></description><link>https://forum.magicmirror.builders/post/112265</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112265</guid><dc:creator><![CDATA[jamesvcc]]></dc:creator><pubDate>Thu, 02 Nov 2023 16:42:56 GMT</pubDate></item><item><title><![CDATA[Reply to magicmirror [DEBUG] config syntax error on Thu, 02 Nov 2023 16:50:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jamesvcc" aria-label="Profile: jamesvcc">@<bdi>jamesvcc</bdi></a> said in <a href="/post/112265">magicmirror [DEBUG] config syntax error</a>:</p>
<p dir="auto">What a difference two " makes make</p>
<p dir="auto">yep, computers are SOOOOOO picky!!.. lol</p>
<p dir="auto">glad its working now</p>
]]></description><link>https://forum.magicmirror.builders/post/112266</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112266</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 02 Nov 2023 16:50:25 GMT</pubDate></item><item><title><![CDATA[Reply to magicmirror [DEBUG] config syntax error on Thu, 02 Nov 2023 16:42:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Awesome, been puzzling for ages over this.  What a difference two " makes make.</p>
]]></description><link>https://forum.magicmirror.builders/post/112265</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112265</guid><dc:creator><![CDATA[jamesvcc]]></dc:creator><pubDate>Thu, 02 Nov 2023 16:42:56 GMT</pubDate></item><item><title><![CDATA[Reply to magicmirror [DEBUG] config syntax error on Thu, 02 Nov 2023 16:16:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jamesvcc" aria-label="Profile: jamesvcc">@<bdi>jamesvcc</bdi></a> could you edit the config.js and look at lines 88-92</p>
<pre><code> daily is not defined  &lt;----  what is daily?  (if its meant to be a literal, it has to be in quotes)
at Object. (/opt/magic_mirror/config/config.js:91:6)  &lt;---- on line 91
]]></description><link>https://forum.magicmirror.builders/post/112264</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112264</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 02 Nov 2023 16:16:02 GMT</pubDate></item></channel></rss>
