<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I can’t update my MM, it’s a node problem but I can’t solve it.<br />
<a href="https://forum.bugsounet.fr/topic/1595/i-can-t-update-my-mm-and-mm-disappears-from-my-screen-after-reboot?_=1699014781024" target="_blank" rel="noopener noreferrer nofollow ugc">here’s what I did with no results…</a><br />
What do you recommend ?<br />
Thank you for your help</p>
]]></description><link>https://forum.magicmirror.builders/topic/18144/node-problem-i-can-t-update-my-mm-and-mm-disappears-from-my-screen-after-reboot</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 14:01:45 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18144.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Nov 2023 12:38:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Sun, 05 Nov 2023 15:31:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a> now another module… DHT-Sensor missing a library</p>
<p dir="auto">go to the module folder and</p>
<p dir="auto">see this topic</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
]]></description><link>https://forum.magicmirror.builders/post/112315</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112315</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 05 Nov 2023 15:31:26 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Tue, 07 Nov 2023 13:12:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a> thank you! perfect</p>
]]></description><link>https://forum.magicmirror.builders/post/112359</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112359</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 07 Nov 2023 13:12:54 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Tue, 07 Nov 2023 12:48:40 GMT]]></title><description><![CDATA[<p dir="auto">here it is :<br />
<img src="/assets/uploads/files/1699361317036-sans-titre.png" alt="Sans titre.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/112357</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112357</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Tue, 07 Nov 2023 12:48:40 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Tue, 07 Nov 2023 11:25:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a><br />
If your MM worked fine and you don’t have any MUST-UPDATE needs, Just don’t update . Leave it as it was.</p>
]]></description><link>https://forum.magicmirror.builders/post/112355</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112355</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Tue, 07 Nov 2023 11:25:11 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Tue, 07 Nov 2023 11:24:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a> just one command  run in terminal</p>
<p dir="auto">returns amount of memory being used</p>
<p dir="auto">my scripts use this an depend on the English text,<br />
trying to make sure it comes out in English is all.</p>
<p dir="auto">has no affect on system</p>
]]></description><link>https://forum.magicmirror.builders/post/112354</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112354</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 07 Nov 2023 11:24:43 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Tue, 07 Nov 2023 11:05:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Hello,<br />
it scares me, my MM has been working perfectly lately. I’m worried that by making this script it will upset something. what is it to do and should it be done directly in the terminal or in the MM folder?</p>
]]></description><link>https://forum.magicmirror.builders/post/112353</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112353</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Tue, 07 Nov 2023 11:05:50 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Mon, 06 Nov 2023 15:23:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a></p>
<p dir="auto">can either of you run this on your French systems</p>
<pre><code>LC_ALL=C  free -m
<p dir="auto">should output in english</p>
]]></description><link>https://forum.magicmirror.builders/post/112334</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112334</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 06 Nov 2023 15:23:39 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Sun, 05 Nov 2023 17:09:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> sure, that why i use my “Installer core”. All script are inside, I just have to call it ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/112320</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112320</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Sun, 05 Nov 2023 17:09:33 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Sun, 05 Nov 2023 17:07:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> if the module is installed in the base folder, but not referenced In package.json it will be removed on next npm install for security</p>
<p dir="auto">I check for rebuild not refresh…  will fix upgrade</p>
]]></description><link>https://forum.magicmirror.builders/post/112319</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112319</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 05 Nov 2023 17:07:12 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Sun, 05 Nov 2023 16:53:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> that’s why I write +/- the same with <code>npm run refresh</code> for the same problem (some libraries disappear with the change of mode version  or need to be rebuilded) but it’s limited to my own modules</p>
]]></description><link>https://forum.magicmirror.builders/post/112318</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112318</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Sun, 05 Nov 2023 16:53:45 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Sun, 05 Nov 2023 16:01:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a> thank you. upgrade script should have done npm install for the dht-sensor module.  will check why not</p>
]]></description><link>https://forum.magicmirror.builders/post/112317</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112317</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 05 Nov 2023 16:01:08 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Sun, 05 Nov 2023 15:40:41 GMT]]></title><description><![CDATA[<p dir="auto">I do</p>
<pre><code>cd ~/MagicMirror/modules/MMM-DHT-Sensor
npm install
<p dir="auto">then</p>
npm start
<pre><code>cd ~/MagicMirror/modules/MMM-GoogleAssistant
npm run update
npm run refresh
<pre><code>pm2 restart 0
<pre><code>sudo reboot now
<p dir="auto">and finally everything works well</p>
<p dir="auto">thank you for your help</p>
]]></description><link>https://forum.magicmirror.builders/post/112316</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112316</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Sun, 05 Nov 2023 15:40:41 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Sun, 05 Nov 2023 15:31:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a> now another module… DHT-Sensor missing a library</p>
]]></description><link>https://forum.magicmirror.builders/post/112315</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112315</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 05 Nov 2023 15:31:26 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Sun, 05 Nov 2023 15:02:10 GMT]]></title><description><![CDATA[<pre><code>pi@raspberrypi:~ $ ^&lsqb;&lsqb;200~bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
bash: $'\E[200~bash' : commande introuvable
pi@raspberrypi:~ $ cd ~/MagicMirror
pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
update log will be in /home/pi/MagicMirror/installers/upgrade.log
doing test run = false
Node currently installed. Checking version number.
Minimum Node version: v20.8.0
Installed Node version: v20.8.0
Check current Node installation ...
No Node.js upgrade necessary.
Check current NPM installation ...
NPM currently installed. Checking version number.
Minimum npm version: V10.1.0
Installed npm version: V10.1.0
No npm upgrade necessary.
force: ligne 450 : [: -le : opérateur unaire attendu
saving custom.css
upgrading from version 2.25.0 to 2.25.0
fetching latest revisions
updating MagicMirror runtime, please wait
&gt; magicmirror@2.25.0 postinstall
&gt; npm run install-vendor &amp;&amp; npm run install-fonts &amp;&amp; echo "MagicMirror² installation finished successfully!
&gt; "
&gt; magicmirror@2.25.0 install-vendor
&gt; echo "Installing vendor files ...
&gt; " &amp;&amp; cd vendor &amp;&amp; npm install --loglevel=error --no-audit --no-fund --no-update-notifier
up to date in 7s
&gt; magicmirror@2.25.0 install-fonts
&gt; echo "Installing fonts ...
&gt; " &amp;&amp; cd fonts &amp;&amp; npm install --loglevel=error --no-audit --no-fund --no-update-notifier
up to date in 47s
&gt; magicmirror@2.25.0 prepare
&gt; [ -f node_modules/.bin/husky ] &amp;&amp; husky install || echo no husky installed.
no husky installed.
added 334 packages in 3m
97 packages are looking for funding
  run `npm fund` for details
Checking for modules with removed libraries
updating dependencies for active modules with package.json files
	processing for module EXT-UpdateNotification please wait
npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
&gt; EXT-UpdateNotification@2.1.0 preinstall
&gt; installer/preinstall.sh
Welcome to EXT-UpdateNotification v2.1.0
No root checking...
Checking EXT-UpdateNotification: pi/pi
Checking MagicMirror: pi/pi
Checking OS...
OS Detected: linux-gnueabihf (raspbian 11 aarch64)
Installing all npm libraries...
&gt; EXT-UpdateNotification@2.1.0 postinstall
&gt; installer/postinstall.sh
Minify Main code
Found: 8 files to minify
Process File: ../EXT-UpdateNotification.js
Process File: ../node_helper.js
Process File: ../components/update.js
Process File: ../components/parseData.js
Process File: ../components/npmCheck.js
Process File: ../components/loadLibraries.js
Process File: ../components/gitCheck.js
Process File: ../components/check.js
Done
Support is now moved in a dedicated Server: https://forum.bugsounet.fr
@bugsounet
EXT-UpdateNotification is now installed !
added 248 packages, and audited 249 packages in 26s
39 packages are looking for funding
found 0 vulnerabilities
	processing complete for module EXT-UpdateNotification
	processing for module MMM-GoogleAssistant please wait
&gt; MMM-GoogleAssistant@5.4.0 preinstall
Welcome to MMM-GoogleAssistant v5.4.0
No root checking...
Checking MMM-GoogleAssistant: pi/pi
Checking OS...
&gt; MMM-GoogleAssistant@5.4.0 postinstall
&gt; installer/postinstall.sh -m -b
Minify Main code...
Found: 27 files to minify
Process File: ../MMM-GoogleAssistant.js
Process File: ../components/shellExec.js
Process File: ../components/searchOnGoogle.js
Process File: ../components/screenParser.js
Process File: ../components/recipes.js
Process File: ../components/proto-loader.js
Process File: ../components/platform.js
Process File: ../components/lpcm16.js
Process File: ../components/googleSearch.js
Process File: ../components/googleAssistant.js
Process File: ../components/embedded-assistant.js
Process File: ../components/conversation.js
Process File: ../components/configMerge.js
Process File: ../components/auth.js
Process File: ../components/assistantSearch.js
Process File: ../components/assistantResponse.js
Process File: ../components/assistantConverse.js
Process File: ../components/activateProcess.js
Process File: ../components/activateAssistant.js
Process File: ../components/Hooks.js
Process File: ../components/Gateway.js
Process File: ../components/GAConfig.js
Process File: ../components/BufferToMP3.js
Process File: ../components/Assistant.js
Done
@bugsounet
MMM-GoogleAssistant is now installed !
added 158 packages in 16s
52 packages are looking for funding
	processing complete for module MMM-GoogleAssistant
	processing for module EXT-Alert please wait
&gt; EXT-Alert@1.2.3 preinstall
Welcome to EXT-Alert v1.2.3
No root checking...
Checking EXT-Alert: pi/pi
Checking OS...
&gt; EXT-Alert@1.2.3 postinstall
Minify Main code...
Found: 5 files to minify
Process File: ../EXT-Alert.js
Process File: ../components/AlertInit.js
Process File: ../components/AlertDisplay.js
Process File: ../components/AlertCommander.js
Done
@bugsounet
EXT-Alert is now installed !
added 42 packages in 5s
13 packages are looking for funding
	processing complete for module EXT-Alert
	processing for module EXT-Bring please wait
&gt; EXT-Bring@1.2.2 preinstall
Welcome to EXT-Bring v1.2.2
No root checking...
Checking EXT-Bring: pi/pi
Checking OS...
&gt; EXT-Bring@1.2.2 postinstall
Minify Main code...
Process File: ../EXT-Bring.js
Process File: ../components/bring-lib.js
Done
@bugsounet
EXT-Bring is now installed !
added 50 packages in 13s
16 packages are looking for funding
	processing complete for module EXT-Bring
	processing for module EXT-Browser please wait
&gt; EXT-Browser@1.2.3 preinstall
Welcome to EXT-Browser v1.2.3
No root checking...
Checking EXT-Browser: pi/pi
Checking OS...
&gt; EXT-Browser@1.2.3 postinstall
Minify Main code...
Found: 3 files to minify
Process File: ../EXT-Browser.js
Process File: ../components/BrowserDisplay.js
Done
@bugsounet
EXT-Browser is now installed !
	processing complete for module EXT-Browser
	processing for module EXT-Detector please wait
npm ERR! code 255
npm ERR! path /home/pi/MagicMirror/modules/EXT-Detector
npm ERR! command failed
npm ERR! command sh -c installer/postinstall.sh -r -m -b
npm ERR! Prepare snowboy library...
npm ERR! installer/postinstall.sh: ligne 40: tsc : commande introuvable
npm ERR! Failed!
npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_54_13_403Z-debug-0.log
	processing complete for module EXT-Detector
	processing for module EXT-Librespot please wait
&gt; EXT-Librespot@1.2.5 preinstall
Welcome to EXT-Librespot v1.2.5
No root checking...
Checking EXT-Librespot: pi/pi
Checking OS...
&gt; EXT-Librespot@1.2.5 postinstall
Minify Main code...
Found: 2 files to minify
Process File: ../EXT-Librespot.js
Done
@bugsounet
EXT-Librespot is now installed !
added 195 packages in 18s
25 packages are looking for funding
	processing complete for module EXT-Librespot
	processing for module EXT-Photos please wait
&gt; EXT-Photos@1.1.3 preinstall
Welcome to EXT-Photos v1.1.3
No root checking...
Checking EXT-Photos: pi/pi
Checking OS...
&gt; EXT-Photos@1.1.3 postinstall
Minify Main code...
Process File: ../EXT-Photos.js
Done
@bugsounet
EXT-Photos is now installed !
	processing complete for module EXT-Photos
	processing for module EXT-RadioPlayer please wait
&gt; EXT-RadioPlayer@1.1.6 preinstall
&gt; installer/preinstall.sh -d 'vlc'
Welcome to EXT-RadioPlayer v1.1.6
No root checking...
Checking EXT-RadioPlayer: pi/pi
Checking OS...
Checking all dependencies...
All Dependencies needed are installed !
&gt; EXT-RadioPlayer@1.1.6 postinstall
Minify Main code...
Process File: ../EXT-RadioPlayer.js
Done
@bugsounet
EXT-RadioPlayer is now installed !
added 50 packages in 9s
14 packages are looking for funding
	processing complete for module EXT-RadioPlayer
	processing for module EXT-ScreenManager please wait
&gt; EXT-ScreenManager@1.1.0 preinstall
Welcome to EXT-ScreenManager v1.1.0
No root checking...
Checking EXT-ScreenManager: pi/pi
Checking OS...
&gt; EXT-ScreenManager@1.1.0 postinstall
Minify Main code
Process File: ../EXT-ScreenManager.js
Done
@bugsounet
EXT-ScreenManager is now installed !
added 64 packages, and audited 65 packages in 13s
	processing complete for module EXT-ScreenManager
	processing for module EXT-Spotify please wait
&gt; EXT-Spotify@2.3.3 preinstall
Welcome to EXT-Spotify v2.3.3
No root checking...
Checking EXT-Spotify: pi/pi
Checking OS...
&gt; EXT-Spotify@2.3.3 postinstall
Minify Main code...
Found: 6 files to minify
Process File: ../EXT-Spotify.js
Process File: ../components/spotifyLib.js
Process File: ../components/spotifyClass.js
Process File: ../components/JSPanel.js
Process File: ../components/CanvasLyrics.js
Done
@bugsounet
EXT-Spotify is now installed !
added 143 packages in 14s
48 packages are looking for funding
	processing complete for module EXT-Spotify
	processing for module Gateway please wait
npm ERR! code 255
npm ERR! path /home/pi/MagicMirror/modules/Gateway
npm ERR! Minify Main code...
npm ERR! node:internal/modules/cjs/loader:1051
npm ERR!   throw err;
npm ERR!   ^
npm ERR!
npm ERR! Error: Cannot find module 'esbuild'
npm ERR! Require stack:
npm ERR! - /home/pi/MagicMirror/modules/Gateway/installer/minify.js
npm ERR!     at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
npm ERR!     at Module._load (node:internal/modules/cjs/loader:901:27)
npm ERR!     at Module.require (node:internal/modules/cjs/loader:1115:19)
npm ERR!     at require (node:internal/modules/helpers:130:18)
npm ERR!     at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/Gateway/installer/minify.js:6:17)
npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1241:14)
npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1295:10)
npm ERR!     at Module.load (node:internal/modules/cjs/loader:1091:32)
npm ERR!     at Module._load (node:internal/modules/cjs/loader:938:12)
npm ERR!     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:83:12) {
npm ERR!   code: 'MODULE_NOT_FOUND',
npm ERR!   requireStack: [ '/home/pi/MagicMirror/modules/Gateway/installer/minify.js' ]
npm ERR! }
npm ERR!
npm ERR! Node.js v20.8.0
npm ERR! Minify Failed!
npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_55_27_131Z-debug-0.log
	processing complete for module Gateway
	processing for module MMM-DHT-Sensor please wait
rebuilt dependencies successfully
	processing complete for module MMM-DHT-Sensor
	processing for module MMM-RainForecast-FR please wait
added 9 packages, and audited 10 packages in 2s
1 package is looking for funding
	processing complete for module MMM-RainForecast-FR
	processing for module MMM-TomTomTraffic please wait
up to date, audited 1 package in 949ms
	processing complete for module MMM-TomTomTraffic
	processing for module MMM-MovieListings please wait
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
added 47 packages, and audited 48 packages in 7s
2 moderate severity vulnerabilities
Some issues need review, and may require choosing
a different dependency.
Run `npm audit` for details.
	processing complete for module MMM-MovieListings
	processing for module MMM-MarineWeather please wait
added 4 packages, and audited 5 packages in 2s
	processing complete for module MMM-MarineWeather
restoring custom.css
pi@raspberrypi:~/MagicMirror $ pm2 stop 0
[PM2] Applying action stopProcessId on app [0](ids: [ '0' ])
[PM2] [MagicMirror](0) ✓
│ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
│ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
pi@raspberrypi:~/MagicMirror $ cd ~/MagicMirror
npm start
&gt; magicmirror@2.25.0 start
&gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
[05.11.2023 15:59.49.467] [LOG]   Starting MagicMirror: v2.25.0
[05.11.2023 15:59.49.477] [LOG]   Loading config ...
[05.11.2023 15:59.49.483] [DEBUG] config template file not exists, no envsubst
[05.11.2023 15:59.49.489] [LOG]   Loading module helpers ...
[05.11.2023 15:59.49.492] [LOG]   No helper found for module: alert.
[05.11.2023 15:59.49.508] [LOG]   Initializing new module helper ...
[05.11.2023 15:59.49.511] [LOG]   Module helper loaded: EXT-UpdateNotification
[05.11.2023 15:59.49.514] [LOG]   No helper found for module: clock.
[05.11.2023 15:59.49.832] [LOG]   Initializing new module helper ...
[05.11.2023 15:59.49.833] [LOG]   Module helper loaded: calendar
[05.11.2023 15:59.49.838] [LOG]   Initializing new module helper ...
[05.11.2023 15:59.49.839] [LOG]   Module helper loaded: MMM-GoogleAssistant
[05.11.2023 15:59.49.841] [LOG]   Initializing new module helper ...
[05.11.2023 15:59.49.841] [LOG]   Module helper loaded: EXT-Alert
[05.11.2023 15:59.49.847] [LOG]   Initializing new module helper ...
[05.11.2023 15:59.49.847] [LOG]   Module helper loaded: EXT-Bring
[05.11.2023 15:59.49.850] [LOG]   Initializing new module helper ...
[05.11.2023 15:59.49.850] [LOG]   Module helper loaded: EXT-Browser
[05.11.2023 15:59.49.863] [LOG]   Initializing new module helper ...
[05.11.2023 15:59.49.863] [LOG]   Module helper loaded: EXT-Detector
[05.11.2023 15:59.50.191] [LOG]   Initializing new module helper ...
[05.11.2023 15:59.50.191] [LOG]   Module helper loaded: EXT-Librespot
[05.11.2023 15:59.50.193] [LOG]   Initializing new module helper ...
[05.11.2023 15:59.50.194] [LOG]   Module helper loaded: EXT-Photos
[05.11.2023 15:59.50.196] [LOG]   Initializing new module helper ...
[05.11.2023 15:59.50.196] [LOG]   Module helper loaded: EXT-RadioPlayer
[05.11.2023 15:59.50.216] [LOG]   Initializing new module helper ...
[05.11.2023 15:59.50.216] [LOG]   Module helper loaded: EXT-ScreenManager
[05.11.2023 15:59.50.444] [LOG]   Initializing new module helper ...
[05.11.2023 15:59.50.444] [LOG]   Module helper loaded: EXT-Spotify
[05.11.2023 15:59.50.453] [LOG]   Initializing new module helper ...
[05.11.2023 15:59.50.453] [LOG]   Module helper loaded: Gateway
[05.11.2023 15:59.50.458] [ERROR] (node:17290) UnhandledPromiseRejectionWarning: Error: Cannot find module 'node-dht-sensor'
Require stack:
- /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_helper.js
    at node:internal/modules/cjs/loader:1084:15
    at Function.&lt;anonymous&gt; (node:electron/js2c/browser_init:2:117419)
    at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
    at node:internal/modules/cjs/loader:929:27
    at Function._load (node:electron/js2c/asar_bundle:2:13327)
    at Module.require (node:internal/modules/cjs/loader:1150:19)
    at require (node:internal/modules/cjs/helpers:110:18)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_helper.js:11:16)
    at Module._compile (node:internal/modules/cjs/loader:1271:14)
    at Object..js (node:internal/modules/cjs/loader:1326:10)
    at Module.load (node:internal/modules/cjs/loader:1126:32)
    at node:internal/modules/cjs/loader:967:12
    at loadModule (/home/pi/MagicMirror/js/app.js:180:19)
(Use `electron --trace-warnings ...` to show where the warning was created)
[05.11.2023 15:59.50.459] [ERROR] (node:17290) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
[17290:1105/155951.307489:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
MESA-LOADER: failed to retrieve device information
MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: Ne peut ouvrir le fichier d'objet partagé: Permission non accordée (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
failed to load driver: kms_swrast
MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: Ne peut ouvrir le fichier d'objet partagé: Permission non accordée (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
failed to load swrast driver
]]></description><link>https://forum.magicmirror.builders/post/112314</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112314</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Sun, 05 Nov 2023 15:02:10 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Sun, 05 Nov 2023 14:44:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a> you need the word</p>
<p dir="auto">force</p>
<p dir="auto">added on the end of the upgrade command</p>
]]></description><link>https://forum.magicmirror.builders/post/112313</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112313</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 05 Nov 2023 14:44:29 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Sun, 05 Nov 2023 14:39:20 GMT]]></title><description><![CDATA[<p dir="auto">I do :</p>
<pre><code>pi@raspberrypi:~ $ cd ~/MagicMirror
doing test run = true, NO updates will be applied!
saving custom.css
	skipped processing for EXT-UpdateNotification, doing test run
	skipped processing for MMM-GoogleAssistant, doing test run
	skipped processing for EXT-Alert, doing test run
	skipped processing for EXT-Bring, doing test run
	skipped processing for EXT-Browser, doing test run
	skipped processing for EXT-Detector, doing test run
	skipped processing for EXT-Librespot, doing test run
	skipped processing for EXT-Photos, doing test run
	skipped processing for EXT-RadioPlayer, doing test run
	skipped processing for EXT-ScreenManager, doing test run
	skipped processing for EXT-Spotify, doing test run
	skipped processing for Gateway, doing test run
	skipped processing for MMM-DHT-Sensor, doing test run
	skipped processing for MMM-RainForecast-FR, doing test run
	skipped processing for MMM-TomTomTraffic, doing test run
	skipped processing for MMM-MovieListings, doing test run
	skipped processing for MMM-MarineWeather, doing test run
saving custom.css
&gt; "
up to date in 3s
up to date in 4s
no husky installed.
added 334 packages in 2m
No root checking...
Checking OS...
Minify Main code
Done
@bugsounet
added 248 packages, and audited 249 packages in 50s
No root checking...
Checking OS...
Minify Main code...
Done
@bugsounet
added 158 packages in 32s
No root checking...
Checking OS...
Minify Main code...
Done
@bugsounet
added 42 packages in 12s
No root checking...
Checking OS...
Minify Main code...
Done
@bugsounet
added 50 packages in 14s
No root checking...
Checking OS...
Minify Main code...
Done
@bugsounet
added 42 packages in 7s
npm ERR! code 255
npm ERR! Failed!
npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_31_50_369Z-debug-0.log
No root checking...
Checking OS...
Minify Main code...
Done
@bugsounet
added 195 packages in 26s
No root checking...
Checking OS...
Minify Main code...
Done
@bugsounet
added 42 packages in 8s
No root checking...
Checking OS...
Minify Main code...
Done
@bugsounet
added 50 packages in 11s
No root checking...
Checking OS...
Minify Main code
Done
@bugsounet
added 64 packages, and audited 65 packages in 12s
No root checking...
Checking OS...
Minify Main code...
Done
@bugsounet
added 143 packages in 23s
npm ERR! code 255
npm ERR!   throw err;
npm ERR!   ^
npm ERR!
npm ERR! }
npm ERR!
npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_33_29_808Z-debug-0.log
added 9 packages, and audited 10 packages in 3s
up to date, audited 1 package in 2s
added 47 packages, and audited 48 packages in 8s
]]></description><link>https://forum.magicmirror.builders/post/112312</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112312</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Sun, 05 Nov 2023 14:39:20 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Sun, 05 Nov 2023 14:19:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a></p>
<p dir="auto"><img src="/assets/uploads/files/1699193908321-screenshot_20231105_081717_chrome.jpg" alt="Screenshot_20231105_081717_Chrome.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1699193920240-screenshot_20231105_081726_chrome.jpg" alt="Screenshot_20231105_081726_Chrome.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">yes  that module is missing a library</p>
<p dir="auto">if you run my upgrade script with force,  it should fix it</p>
]]></description><link>https://forum.magicmirror.builders/post/112311</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112311</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 05 Nov 2023 14:19:45 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Sun, 05 Nov 2023 14:16:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a> one command at a time</p>
<p dir="auto">show results of each one at a time</p>
]]></description><link>https://forum.magicmirror.builders/post/112310</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112310</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 05 Nov 2023 14:16:27 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Sun, 05 Nov 2023 14:01:02 GMT]]></title><description><![CDATA[<p dir="auto">If I anderstand my MM is up to date and node is up to date too.<br />
So Why my MM didn’t launch ?..</p>
]]></description><link>https://forum.magicmirror.builders/post/112309</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112309</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Sun, 05 Nov 2023 14:01:02 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Sun, 05 Nov 2023 13:59:26 GMT]]></title><description><![CDATA[<p dir="auto">The result :</p>
<pre><code>pi@raspberrypi:~/MagicMirror $ pm2 stop all
cd ~/MagicMirror
npm run install-mm
npm start
[PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
&gt; magicmirror@2.25.0 install-mm
&gt; npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
npm WARN config only Use `--omit=dev` to omit dev dependencies from the install.
&gt; "
up to date in 1s
up to date in 1s
no husky installed.
up to date in 14s
[05.11.2023 14:46.59.755] [LOG]   Starting MagicMirror: v2.25.0
[05.11.2023 14:46.59.761] [LOG]   Loading config ...
[05.11.2023 14:46.59.767] [DEBUG] config template file not exists, no envsubst
[05.11.2023 14:46.59.775] [LOG]   Loading module helpers ...
[05.11.2023 14:46.59.778] [LOG]   No helper found for module: alert.
[05.11.2023 14:46.59.800] [LOG]   Initializing new module helper ...
[05.11.2023 14:46.59.801] [LOG]   Module helper loaded: EXT-UpdateNotification
[05.11.2023 14:46.59.803] [LOG]   No helper found for module: clock.
[05.11.2023 14:47.00.090] [LOG]   Initializing new module helper ...
[05.11.2023 14:47.00.091] [LOG]   Module helper loaded: calendar
[05.11.2023 14:47.00.098] [LOG]   Initializing new module helper ...
[05.11.2023 14:47.00.099] [LOG]   Module helper loaded: MMM-GoogleAssistant
[05.11.2023 14:47.00.103] [LOG]   Initializing new module helper ...
[05.11.2023 14:47.00.103] [LOG]   Module helper loaded: EXT-Alert
[05.11.2023 14:47.00.115] [LOG]   Initializing new module helper ...
[05.11.2023 14:47.00.116] [LOG]   Module helper loaded: EXT-Bring
[05.11.2023 14:47.00.127] [LOG]   Initializing new module helper ...
[05.11.2023 14:47.00.127] [LOG]   Module helper loaded: EXT-Browser
[05.11.2023 14:47.00.142] [LOG]   Initializing new module helper ...
[05.11.2023 14:47.00.142] [LOG]   Module helper loaded: EXT-Detector
[05.11.2023 14:47.00.595] [LOG]   Initializing new module helper ...
[05.11.2023 14:47.00.596] [LOG]   Module helper loaded: EXT-Librespot
[05.11.2023 14:47.00.599] [LOG]   Initializing new module helper ...
[05.11.2023 14:47.00.599] [LOG]   Module helper loaded: EXT-Photos
[05.11.2023 14:47.00.603] [LOG]   Initializing new module helper ...
[05.11.2023 14:47.00.603] [LOG]   Module helper loaded: EXT-RadioPlayer
[05.11.2023 14:47.00.638] [LOG]   Initializing new module helper ...
[05.11.2023 14:47.00.638] [LOG]   Module helper loaded: EXT-ScreenManager
[05.11.2023 14:47.00.967] [LOG]   Initializing new module helper ...
[05.11.2023 14:47.00.968] [LOG]   Module helper loaded: EXT-Spotify
[05.11.2023 14:47.00.975] [LOG]   Initializing new module helper ...
[05.11.2023 14:47.00.975] [LOG]   Module helper loaded: Gateway
[05.11.2023 14:47.00.998] [LOG]   Initializing new module helper ...
[05.11.2023 14:47.00.999] [LOG]   Module helper loaded: MMM-DHT-Sensor
[05.11.2023 14:47.00.999] [LOG]   No helper found for module: MMM-WeatherOrNot.
[05.11.2023 14:47.01.093] [LOG]   Initializing new module helper ...
[05.11.2023 14:47.01.094] [LOG]   Module helper loaded: MMM-RainForecast-FR
[05.11.2023 14:47.01.094] [LOG]   No helper found for module: MMM-TomTomTraffic.
[05.11.2023 14:47.01.594] [LOG]   Initializing new module helper ...
[05.11.2023 14:47.01.595] [LOG]   Module helper loaded: MMM-MovieListings
[05.11.2023 14:47.01.600] [ERROR] (node:12072) UnhandledPromiseRejectionWarning: Error: Cannot find module 'node-fetch'
Require stack:
- /home/pi/MagicMirror/modules/MMM-MarineWeather/node_helper.js
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-MarineWeather/node_helper.js:14:15)
[05.11.2023 14:47.01.601] [ERROR] (node:12072) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
[12072:1105/144701.952277:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
<p dir="auto">And MM didn’t launch…</p>
]]></description><link>https://forum.magicmirror.builders/post/112308</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112308</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Sun, 05 Nov 2023 13:59:26 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Sun, 05 Nov 2023 13:45:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a></p>
<p dir="auto">do</p>
<pre><code>pm2 stop all
cd ~/MagicMirror
npm run install-mm
npm start
<p dir="auto">please confirm results</p>
]]></description><link>https://forum.magicmirror.builders/post/112307</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112307</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 05 Nov 2023 13:45:24 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Sun, 05 Nov 2023 13:42:15 GMT]]></title><description><![CDATA[<p dir="auto">My node version is 20.8.0 but i don’t know to launch my MM…<br />
<img src="/assets/uploads/files/1699191675429-sans-titre.png" alt="Sans titre.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">MM didn’t start…</p>
]]></description><link>https://forum.magicmirror.builders/post/112306</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112306</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Sun, 05 Nov 2023 13:42:15 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Sun, 05 Nov 2023 13:33:22 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1699191199607-sans-titre.png" alt="Sans titre.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/112305</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112305</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Sun, 05 Nov 2023 13:33:22 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Sat, 04 Nov 2023 13:43:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikko14" aria-label="Profile: RIKKO14">@<bdi>RIKKO14</bdi></a> DO NOT RUN INSTALL…</p>
<p dir="auto">run UPGRADE with force</p>
<p dir="auto">I will look for how to fix the gpg key problem</p>
<p dir="auto">execute these commands,  (copy paste)</p>
<pre><code>curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
NODE_MAJOR=18
echo "deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_$NODE_MAJOR.x nodistro main" | sudo tee /etc/apt/sources.list.d/nodesource.list
<p dir="auto">then do</p>
<pre><code>sudo apt-get update
]]></description><link>https://forum.magicmirror.builders/post/112300</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112300</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 04 Nov 2023 13:43:00 GMT</pubDate></item><item><title><![CDATA[Reply to node problem :  I can&#x27;t update my MM and MM disappears from my screen after reboot on Sat, 04 Nov 2023 13:24:09 GMT]]></title><description><![CDATA[<pre><code>pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"force
$$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
$$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
$$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
$$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
$$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
$$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
\__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                        \______/
install log being saved to /home/pi/install.log
Updating packages ...
W: Erreur de GPG : https://deb.nodesource.com/node_18.x nodistro InRelease : Les signatures suivantes n'ont pas pu être vérifiées car la clé publique n'est pas disponible : NO_PUBKEY 2F59B5F99B1BE0B4
E: Le dépôt https://deb.nodesource.com/node_18.x nodistro InRelease n'est pas signé.
Update failed, retrying installation ...
Installing helper tools ...
It seems like MagicMirror is already installed.
To prevent overwriting, the installer will be aborted.
Please rename the ~/MagicMirror folder and try again.
pi@raspberrypi:~ $
]]></description><link>https://forum.magicmirror.builders/post/112299</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112299</guid><dc:creator><![CDATA[RIKKO14]]></dc:creator><pubDate>Sat, 04 Nov 2023 13:24:09 GMT</pubDate></item></channel></rss>
