<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bookworm, Pi &amp; VENV]]></title><description><![CDATA[<p dir="auto">You all may have already addressed this and if so can you point me to the appropriate Topic?</p>
<p dir="auto">I am working on a different project and since I didn’t want to blow up what I had already done I installed what turned out to be the new Debian/Pi OS on a spare Pi<br />
I ran headlong into this virtual environment requirement or VENV.<br />
Is that going to cause problems installing modules because it whipped me installing environmental sensors and being able to install their corresponding drivers.  Seems that the Bookworm edition of Pi OS  is likely not going see a difference between an Adafruit sensor driver and a MM module but maybe can.  Waaaay beyond me.</p>
]]></description><link>https://forum.magicmirror.builders/topic/18152/bookworm-pi-venv</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 08:15:21 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18152.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Nov 2023 22:47:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bookworm, Pi &amp; VENV on Wed, 08 Nov 2023 00:29:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Dig that.  First thought was “exactly what major value does that bring to the table?”<br />
So loading Python packages from the PYPI package repository breaks Python.<br />
That’s a good one.</p>
]]></description><link>https://forum.magicmirror.builders/post/112376</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112376</guid><dc:creator><![CDATA[ankonaskiff17]]></dc:creator><pubDate>Wed, 08 Nov 2023 00:29:20 GMT</pubDate></item><item><title><![CDATA[Reply to Bookworm, Pi &amp; VENV on Tue, 07 Nov 2023 23:27:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ankonaskiff17" aria-label="Profile: ankonaskiff17">@<bdi>ankonaskiff17</bdi></a> yeh  everybody trying to keep their stuff running when the floor gets ripped out from under them</p>
]]></description><link>https://forum.magicmirror.builders/post/112372</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112372</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 07 Nov 2023 23:27:25 GMT</pubDate></item><item><title><![CDATA[Reply to Bookworm, Pi &amp; VENV on Tue, 07 Nov 2023 23:21:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> They left RealVNC out in the cold initially but looks like RealVNC solved their problem.<br />
There was an apology note put out by RealVNC which was mostly “we apologize to the Raspberry Pi community but we are working as hard as we can to allow you to continue using RealVNC”</p>
<p dir="auto">I have no idea what relation different companies have to be part of the default installation of Pi OS  but seeing that  note I immediately thought RealVNC was trying to push on <a href="http://RaspberryPi.org" target="_blank" rel="noopener noreferrer nofollow ugc">RaspberryPi.org</a> and Pi called their bluff</p>
]]></description><link>https://forum.magicmirror.builders/post/112371</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112371</guid><dc:creator><![CDATA[ankonaskiff17]]></dc:creator><pubDate>Tue, 07 Nov 2023 23:21:11 GMT</pubDate></item><item><title><![CDATA[Reply to Bookworm, Pi &amp; VENV on Tue, 07 Nov 2023 22:50:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ankonaskiff17" aria-label="Profile: ankonaskiff17">@<bdi>ankonaskiff17</bdi></a> you could add the venv command to the .profile or .bashrc so it would be executed on every terminal session then it would be setup before mm runs</p>
<p dir="auto">the <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> is a bash script so<br />
.bashrc gets run before the script runs</p>
]]></description><link>https://forum.magicmirror.builders/post/112370</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112370</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 07 Nov 2023 22:50:16 GMT</pubDate></item></channel></rss>
