<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[DFRobot mmWave Human Presence Detection Sensor]]></title><description><![CDATA[<p dir="auto">I’ve bought a couple <a href="https://www.dfrobot.com/product-2282.html" target="_blank" rel="noopener noreferrer nofollow ugc">DFRobot mmWave sensors</a> and intend to use that to trigger the screen of my Magic Mirror.</p>
<p dir="auto">But the only wire schemas I can find are for the ESPHome or an Arduino, while I would like to wire it directly to the GPIO ports of my Raspberry Pi 4 that’s running Magic Mirror.</p>
<p dir="auto">I’ve looked at the <a href="https://github.com/Tom-Hirschberger/MMM-Screen-Powersave-Notification" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-Screen-Powersave-Notification</a> that uses a HC-SR501 PIR sensor, but I couldn’t work out how to make that work with an mmWave sensor. The PIR sensor uses a single wire to trigger the screen, while the mmWave sensor also uses a serial connection.</p>
<p dir="auto">Anybody have any suggestions how to get started? Of course I can just use the PIR Sensor instead, but I like to use the mmWave sensor because I can hide it in the frame.</p>
]]></description><link>https://forum.magicmirror.builders/topic/18156/dfrobot-mmwave-human-presence-detection-sensor</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 17:24:00 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18156.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 Nov 2023 16:20:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to DFRobot mmWave Human Presence Detection Sensor on Sat, 11 Nov 2023 16:49:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pietervanharen" aria-label="Profile: pietervanharen">@<bdi>pietervanharen</bdi></a> typically there are only 3 wires</p>
<p dir="auto">power  (pin 6)<br />
ground (pin5)<br />
signal (pin 4)</p>
<p dir="auto">so, power and ground should be easy, and picking an available gpio port should also be easy</p>
<p dir="auto">and if you want to.program change it’s behavior the you would connect pins 1 and 2</p>
<p dir="auto"><img src="/assets/uploads/files/1699721254471-screenshot_20231111_104643_chrome.jpg" alt="Screenshot_20231111_104643_Chrome.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/112427</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112427</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 11 Nov 2023 16:49:43 GMT</pubDate></item></channel></rss>
