<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Wrap event title MMM-CalendarExt3]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/16690/mmm-calendarext3">MMM-CalendarExt3</a></p>
<p dir="auto">Hello,</p>
<p dir="auto">Can you share a CSS or Node.js script that that wraps event titles into 2 or more lines when it does not fit in the cell?</p>
<p dir="auto">Thanks very much.</p>
]]></description><link>https://forum.magicmirror.builders/topic/18160/wrap-event-title-mmm-calendarext3</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 03:29:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18160.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Nov 2023 07:35:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Wrap event title MMM-CalendarExt3 on Mon, 13 Nov 2023 16:23:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a><br />
Thanks for your reply and suggestions. I was able to wrap the text but unable to make to event size to auto adjust its height which resulted in the text being unreadable. I will follow your suggestions and work on alternatives.<br />
I appreciate you for all the time dedicated to building this module.<br />
Excellent work. :smiling_face:</p>
]]></description><link>https://forum.magicmirror.builders/post/112501</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112501</guid><dc:creator><![CDATA[muhsintt]]></dc:creator><pubDate>Mon, 13 Nov 2023 16:23:26 GMT</pubDate></item><item><title><![CDATA[Reply to Wrap event title MMM-CalendarExt3 on Mon, 13 Nov 2023 13:14:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/muhsintt" aria-label="Profile: muhsintt">@<bdi>muhsintt</bdi></a> said in <a href="/post/112475">Wrap event title MMM-CalendarExt3</a>:</p>
<p dir="auto">I don’t agree that kind of wrapped multi-lines are useful.</p>
<p dir="auto">Because it’s ugly and wastes space(unless using a 4K screen), it is not easy to glance at, and it is hard to recognise events.  Just two-line wrapping may not be sufficient to display long titles. (How about 3 lines? Or 4 lines? no ends…)<br />
So, I intentionally designed this module like the current one looks. It is an old legacy concept from MMM-CalendarExt, (and MMM-CalendarExt2, …) All other major calendar applications on desktop or mobile keep the one-liner in month-type view. (Google Calendar, Apple calendar, MS Outlook, Fantastical, …)</p>
<p dir="auto">Anyway, usually, MM is regarded as just a dashboard to glance at, not a Franklin organizer.</p>
<p dir="auto">Even though 2liners could be possible with some tricks(I tried once), technically, It needs a ton of heavy CSS and JS tweaks. If you are not an expert, you probably ruin the whole look.</p>
<p dir="auto">I totally understand this ellipsed title may not be enough to read. What I suggest alternately are;</p>
<ul>
<li>Use colour and symbols to distinguish some events.</li>
<li>Use abbreviations to shorten long titles.<br />
(For above two approaches, you can handle events with prepared handlers of this module)</li>
<li>Shorten time format. (<code>22</code> is better than <code>10:00 PM</code>)</li>
<li>Use <code>popover</code> feature to see details of the event. (When your MM device supports touch/click)</li>
<li>Use other sidekick modules to look for details, like MMM-CalendarExt3Agenda, Or the default calendar module.</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/112478</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112478</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Mon, 13 Nov 2023 13:14:27 GMT</pubDate></item></channel></rss>
