<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-CollegeFootballTop 25]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/17289/mmm-college-top-25">MMM College top 25</a><br />
Hi, I installed the MMM-CollegeFootballTop25 but when I go to run it I get this and it wont start. vandam3b@raspberrypi:~/MagicMirror $ npm start</p>
<p dir="auto">magicmirror@2.25.0 start<br />
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js</p>
<p dir="auto">[17.11.2023 17:09.12.845] [LOG]   Starting MagicMirror: v2.25.0<br />
[17.11.2023 17:09.12.864] [LOG]   Loading config …<br />
[17.11.2023 17:09.12.873] [DEBUG] config template file not exists, no envsubst<br />
[17.11.2023 17:09.12.886] [LOG]   Loading module helpers …<br />
[17.11.2023 17:09.12.892] [LOG]   No helper found for module: alert.<br />
[17.11.2023 17:09.12.954] [LOG]   Initializing new module helper …<br />
[17.11.2023 17:09.12.956] [LOG]   Module helper loaded: updatenotification<br />
[17.11.2023 17:09.12.960] [LOG]   No helper found for module: clock.<br />
[17.11.2023 17:09.13.535] [LOG]   Initializing new module helper …<br />
[17.11.2023 17:09.13.538] [LOG]   Module helper loaded: calendar<br />
[17.11.2023 17:09.13.548] [LOG]   No helper found for module: compliments.<br />
[17.11.2023 17:09.13.551] [LOG]   No helper found for module: weather.<br />
[17.11.2023 17:09.13.583] [LOG]   Initializing new module helper …<br />
[17.11.2023 17:09.13.585] [LOG]   Module helper loaded: MMM-MyScoreboard<br />
[17.11.2023 17:09.13.600] [LOG]   Initializing new module helper …<br />
[17.11.2023 17:09.13.601] [LOG]   Module helper loaded: MMM-ImageSlideshow<br />
[17.11.2023 17:09.15.041] [LOG]   Initializing new module helper …<br />
[17.11.2023 17:09.15.043] [LOG]   Module helper loaded: MMM-History<br />
[17.11.2023 17:09.15.060] [ERROR] (node:10256) UnhandledPromiseRejectionWarning: ReferenceError: NodeHelper is not defined<br />
at Object. (/home/vandam3b/MagicMirror/modules/MMM-CollegeFootballTop25/node_helper.js:19:18)<br />
at Module._compile (node:internal/modules/cjs/loader:1271:14)<br />
at Object…js (node:internal/modules/cjs/loader:1326:10)<br />
at Module.load (node:internal/modules/cjs/loader:1126:32)<br />
at node:internal/modules/cjs/loader:967:12<br />
at Function._load (node:electron/js2c/asar_bundle:2:13327)<br />
at Module.require (node:internal/modules/cjs/loader:1150:19)<br />
at require (node:internal/modules/cjs/helpers:110:18)<br />
at loadModule (/home/vandam3b/MagicMirror/js/app.js:180:19)<br />
at loadModules (/home/vandam3b/MagicMirror/js/app.js:210:10)<br />
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)<br />
at async App.start (/home/vandam3b/MagicMirror/js/app.js:258:3)<br />
(Use <code>electron --trace-warnings ...</code> to show where the warning was created)<br />
[17.11.2023 17:09.15.061] [ERROR] (node:10256) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag <code>--unhandled-rejections=strict</code> (see <a href="https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode" target="_blank" rel="noopener noreferrer nofollow ugc">https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode</a>). (rejection id: 1)<br />
[10256:1117/170916.908663:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files<br />
MESA-LOADER: failed to retrieve device information<br />
This is what I put in the Config.js file<br />
{<br />
module: “MMM-CollegeFootballTop25”,<br />
position: “lower_third”,<br />
config: {<br />
headertext: “College Top 25”,<br />
}<br />
},<br />
Any help would be appreciated.</p>
]]></description><link>https://forum.magicmirror.builders/topic/18184/mmm-collegefootballtop-25</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 11:59:48 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18184.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Nov 2023 22:13:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-CollegeFootballTop 25 on Sat, 18 Nov 2023 13:05:58 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for your reply , you are  great help. Sorry for the double post I just wasn’t sure I hit the reply button. Rookie mistake. Thanks again for your help.</p>
]]></description><link>https://forum.magicmirror.builders/post/112633</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112633</guid><dc:creator><![CDATA[vandam3b]]></dc:creator><pubDate>Sat, 18 Nov 2023 13:05:58 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CollegeFootballTop 25 on Sat, 18 Nov 2023 02:49:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vandam3b" aria-label="Profile: vandam3b">@<bdi>vandam3b</bdi></a> I do not know about the data source the module uses.  the modules is 5 years since last update.</p>
]]></description><link>https://forum.magicmirror.builders/post/112626</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112626</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 18 Nov 2023 02:49:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CollegeFootballTop 25 on Sat, 18 Nov 2023 00:40:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vandam3b" aria-label="Profile: vandam3b">@<bdi>vandam3b</bdi></a> posts for users with less than reputation 2 are reviewed before being posted.  I review every post</p>
<p dir="auto">patience</p>
<p dir="auto">this module IS 5 years old</p>
]]></description><link>https://forum.magicmirror.builders/post/112621</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112621</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 18 Nov 2023 00:40:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CollegeFootballTop 25 on Fri, 17 Nov 2023 23:14:41 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, I appreciate it. It loads but now says “Awaiting Update” maybe the module does not work anymore. Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/112619</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112619</guid><dc:creator><![CDATA[vandam3b]]></dc:creator><pubDate>Fri, 17 Nov 2023 23:14:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CollegeFootballTop 25 on Fri, 17 Nov 2023 22:34:20 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, I really appreciate it. It loads but now says “Awaiting update” so maybe this module is no longer good?</p>
]]></description><link>https://forum.magicmirror.builders/post/112618</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112618</guid><dc:creator><![CDATA[vandam3b]]></dc:creator><pubDate>Fri, 17 Nov 2023 22:34:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CollegeFootballTop 25 on Fri, 17 Nov 2023 22:26:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vandam3b" aria-label="Profile: vandam3b">@<bdi>vandam3b</bdi></a> this module is missing a line of code</p>
<p dir="auto">add this as line 1 of the node_helper.js</p>
<pre><code>const NodeHelper = require("node_helper")
]]></description><link>https://forum.magicmirror.builders/post/112617</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112617</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 17 Nov 2023 22:26:38 GMT</pubDate></item></channel></rss>
