<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Carousel; Two of the Same Module?]]></title><description><![CDATA[<p dir="auto">I am using the default Calendar module in my setup. I have two distinct entries in my config, one that shows my family calendar, and one that shows my calendar. Currently they are stacked on top of each other and both display one above the other.</p>
<p dir="auto">I have started using MMM-Carousel to rotate modules through my display, and I’d like to show one of my calendars, and then rotate to the other.</p>
<p dir="auto">Is there a way to reference one calendar module or the other, specifically?</p>
]]></description><link>https://forum.magicmirror.builders/topic/18218/mmm-carousel-two-of-the-same-module</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 16:07:45 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18218.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 Dec 2023 22:07:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Carousel; Two of the Same Module? on Thu, 17 Apr 2025 23:06:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dathbe" aria-label="Profile: dathbe">@<bdi>dathbe</bdi></a> my MMM-Config module doesn’t understand the carouselId inside the module config. . just cause you CAN  code  it doesn’t mean you should</p>
]]></description><link>https://forum.magicmirror.builders/post/125949</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125949</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 17 Apr 2025 23:06:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel; Two of the Same Module? on Thu, 17 Apr 2025 23:04:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dathbe" aria-label="Profile: dathbe">@<bdi>dathbe</bdi></a> i added display times to carousel too</p>
]]></description><link>https://forum.magicmirror.builders/post/125948</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125948</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 17 Apr 2025 23:04:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel; Two of the Same Module? on Thu, 17 Apr 2025 22:24:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I like the idea of scheduling display times for pages.</p>
<p dir="auto">Most of the rest of this it seems like I can do with Carousel–including giving the pages sensible names, and labeling certain modules to correspond with those pages–if, perhaps, in a bit more clunky way.</p>
]]></description><link>https://forum.magicmirror.builders/post/125947</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125947</guid><dc:creator><![CDATA[dathbe]]></dc:creator><pubDate>Thu, 17 Apr 2025 22:24:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel; Two of the Same Module? on Tue, 30 Dec 2025 02:10:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dathbe" aria-label="Profile: dathbe">@<bdi>dathbe</bdi></a> I like the flexibility of pages,  you can use the module classes: property<br />
outside the module config for multiple instances of the same module<br />
(and use the same value in custom.css selectors)</p>
<p dir="auto">I updated the doc on how to use a fixed page name structure</p>
<p dir="auto">“page1”,<br />
“page2”,<br />
“page3”</p>
<p dir="auto">and use those values in  the classes: of the modules you want to group together</p>
<p dir="auto">I always had trouble remembering, is THIS module on page 2 or 3?<br />
have to go back and look at the config(using module names)<br />
and then back down, lose my place, repeat</p>
<p dir="auto">now the module itself lists the page its on…<br />
no id’s, no weird settings,</p>
<p dir="auto">my forks of pages, Carousel and ModulesGroupsRotation all provide a property to have different display times for different pages.</p>
<p dir="auto">and the page name can be anything</p>
<p dir="auto">Mom, Dad, joe, finance, power mgmt, …  so it helps you organize the data (for me at least)</p>
]]></description><link>https://forum.magicmirror.builders/post/125787</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125787</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 30 Dec 2025 02:10:26 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel; Two of the Same Module? on Sat, 12 Apr 2025 19:56:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dathbe" aria-label="Profile: dathbe">@<bdi>dathbe</bdi></a> roughly the same . the buttons are a separate modules</p>
<p dir="auto">and because it uses classes , the duplicates are easier</p>
]]></description><link>https://forum.magicmirror.builders/post/125784</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125784</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 12 Apr 2025 19:56:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel; Two of the Same Module? on Sat, 12 Apr 2025 19:07:56 GMT]]></title><description><![CDATA[<p dir="auto">Is there any functional difference between MMM-Pages and MMM-Carousel?  I’m using Carousel, but just stumbled across Pages and am wondering if the grass is greener on that side…</p>
]]></description><link>https://forum.magicmirror.builders/post/125782</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125782</guid><dc:creator><![CDATA[dathbe]]></dc:creator><pubDate>Sat, 12 Apr 2025 19:07:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel; Two of the Same Module? on Mon, 04 Dec 2023 21:30:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a>,</p>
<p dir="auto">Thank you! That was the issue. My eye did not catch that in the documentation. I appreciate your time and your patience.</p>
<p dir="auto">JD.</p>
]]></description><link>https://forum.magicmirror.builders/post/113040</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113040</guid><dc:creator><![CDATA[JeffreyDaro]]></dc:creator><pubDate>Mon, 04 Dec 2023 21:30:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel; Two of the Same Module? on Mon, 04 Dec 2023 20:13:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jeffreydaro" aria-label="Profile: JeffreyDaro">@<bdi>JeffreyDaro</bdi></a> The carouselId has to be in the config part. Like this:</p>
<pre><code class="language-js">{
      	carouselId: "cal1",
      	carouselId: "cal2",
]]></description><link>https://forum.magicmirror.builders/post/113035</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113035</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Mon, 04 Dec 2023 20:13:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel; Two of the Same Module? on Mon, 04 Dec 2023 14:47:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a> Thank you for responding.  I started working on the carouselID’s but I am struggling a bit to get that to work.</p>
<p dir="auto">I was experimenting with both classes and carouselID:</p>
<pre><code>{
            module: "MMM-Carousel",
            position: "bottom_bar", // Required to draw in position
                mode: "slides",
                ignoreModules: ["MMM-GooglePhotos"],
                transitionInterval: 40000,
                slideTransitionSpeed: 3000,
                slides: {
                    main: ["clock", "weather"],
                    "slide2": ["clock", "weather", "compliments"],
                    "slide3": ["clock", "MMM-NFL"],
                    "slide4": [{ name: "calendar", carouselId: "cal1", classes:"cal1" }, "MMM-NFL"],
                    "slide5": [{ name: "calendar", carouselId: "cal2", classes: "cal2" }, "weather"]
<p dir="auto">And as an example, my first calendar on the screen…</p>
<pre><code>{
            carouselId: "cal1",
            classes: "cal1",
<p dir="auto">And my second…</p>
<pre><code>{
            carouselId: "cal2",
            classes: "cal2",
]]></description><link>https://forum.magicmirror.builders/post/113016</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113016</guid><dc:creator><![CDATA[JeffreyDaro]]></dc:creator><pubDate>Mon, 04 Dec 2023 14:47:05 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel; Two of the Same Module? on Sat, 02 Dec 2023 13:19:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jeffreydaro" aria-label="Profile: JeffreyDaro">@<bdi>JeffreyDaro</bdi></a> That’s possible with MMM-Carousel. Look for <code>carouselId</code> in the README file :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/112987</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112987</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Sat, 02 Dec 2023 13:19:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel; Two of the Same Module? on Sat, 02 Dec 2023 00:13:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>, thank you…I will give that a try.</p>
]]></description><link>https://forum.magicmirror.builders/post/112978</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112978</guid><dc:creator><![CDATA[JeffreyDaro]]></dc:creator><pubDate>Sat, 02 Dec 2023 00:13:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel; Two of the Same Module? on Fri, 01 Dec 2023 23:40:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jeffreydaro" aria-label="Profile: JeffreyDaro">@<bdi>JeffreyDaro</bdi></a> i don’t know carousel very well, but it uses module names as class names… you could give another class for an instance with the classes:“someodd_string”,<br />
attribute on the module, and then use THAT string in the carousel config…</p>
<p dir="auto">I mostly use MMM-Pages, and i have documented another way to use it with the classes attribute, see the doc in my fork for the second method<br />
<a href="https://github.com/sdetweil/MMM-pages" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MMM-pages</a></p>
<p dir="auto">i think my ‘page1’,‘page2’ … approach will work the same with carousel…</p>
]]></description><link>https://forum.magicmirror.builders/post/112974</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/112974</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 Dec 2023 23:40:25 GMT</pubDate></item></channel></rss>
