<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Scenes2]]></title><description><![CDATA[<p dir="auto">Hi<br />
I’m currently building my first mirror and experimenting with third-party modules.<br />
For example MMM-Scenes2. I don’t know if the behaviour is correct. The scenes change as desired. After a certain time, the loop stops at the first scene. I want the cycle to be endless.<br />
Is this behaviour intended? Do I need to adjust my configuration? Does anyone have any tips?<br />
My configuration</p>
<pre><code>{
                        module: "MMM-Scenes2",
                        position: 'bottom_bar', // Position of indicator
                                activeIndicator: " ^|^s",
                                inactiveIndicator: " ^|^w",
                                defaultEnter: {
                                        animation:  "bounceInUp", /* "zoomInUp" */
                                defaultExit: {
                                        animation: "hinge",
                                scenario: [ // `scenario` is REQUIRED
                                        { // First scene definition
                                                exit: [
        role: "role_date",
        animation: "bounceOutDown",
        role: "role_germanclock",
                                                enter: ["role_alert",
                                                        "role_notification",
                                                        "role_clock",
                                                        "role_calendar",
                                                        "role_weather_current",
                                                        "role_weather_forecast"
                                        { // Second scene definition
                                                exit: ["role_alert",
                                                        "role_clock",
                                                        "role_calendar",
                                                enter: [
        role: "role_date",
        animation: "zoomInUp",
]]></description><link>https://forum.magicmirror.builders/topic/18266/mmm-scenes2</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 01:08:05 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18266.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 Dec 2023 16:14:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Scenes2 on Tue, 28 May 2024 14:43:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/babene1" aria-label="Profile: Babene1">@<bdi>Babene1</bdi></a><br />
Congrat. Happy to hear that. (Mine is not guilty! :D)</p>
]]></description><link>https://forum.magicmirror.builders/post/117983</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117983</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Tue, 28 May 2024 14:43:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Tue, 28 May 2024 14:42:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a><br />
Yes, I think the problem is due to the “MMM-iFrameReload” module. I’m now using the module “MMM-SmartWebDisplay” so far no problem :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/117982</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117982</guid><dc:creator><![CDATA[Babene1]]></dc:creator><pubDate>Tue, 28 May 2024 14:42:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Tue, 28 May 2024 14:10:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ric" aria-label="Profile: ric">@<bdi>ric</bdi></a><br />
Yes, you should try adding one / removing one for all combinations.  It would be a very tedious task and requires persistence.</p>
]]></description><link>https://forum.magicmirror.builders/post/117981</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117981</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Tue, 28 May 2024 14:10:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Tue, 28 May 2024 08:58:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a><br />
do i understand correctly that the Transition/Animation, could be to blame? So I would have to switch off the transitions for the two modules (MMM-BackgroundSlideshow und MMM-Carousel).<br />
I’ll test it like this</p>
]]></description><link>https://forum.magicmirror.builders/post/117977</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117977</guid><dc:creator><![CDATA[ric]]></dc:creator><pubDate>Tue, 28 May 2024 08:58:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Mon, 27 May 2024 14:36:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/babene1" aria-label="Profile: Babene1">@<bdi>Babene1</bdi></a><br />
Do you mean iFrame related module may have the issue?</p>
]]></description><link>https://forum.magicmirror.builders/post/117972</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117972</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Mon, 27 May 2024 14:36:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Mon, 27 May 2024 14:30:33 GMT]]></title><description><![CDATA[<p dir="auto">Result of my test:</p>
<ul>
<li>
<p dir="auto">ListenpunktUsing “external_broqwser=firefox” no improvement, after about 1 hour no changes from the modul.</p>
</li>
<li>
<p dir="auto">ListenpunktWith “animation: null”, no improvement, after about 1 hour no changes from the modul.</p>
</li>
<li>
<p dir="auto">ListenpunktWith default clock and calendar, no problem (test run about 2,5 hours)</p>
</li>
</ul>
<p dir="auto">Next test, with just an iframe module and the MMM-Simple Logo module. This module combination could be a solution for me</p>
]]></description><link>https://forum.magicmirror.builders/post/117971</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117971</guid><dc:creator><![CDATA[Babene1]]></dc:creator><pubDate>Mon, 27 May 2024 14:30:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Mon, 27 May 2024 07:05:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ric" aria-label="Profile: ric">@<bdi>ric</bdi></a><br />
Chrome(Chromium) is notorious for memory leaks. On Transition/Animation, this kind of error is often reported in some environments (+ some GPU driver issues). Sometimes, a newer version looks like it solves this issue, but the issue returns in subsequent versions again.<br />
If you have more memory, this symptom seems relieving, but not absolutely.</p>
]]></description><link>https://forum.magicmirror.builders/post/117968</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117968</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Mon, 27 May 2024 07:05:30 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Sun, 26 May 2024 15:56:45 GMT]]></title><description><![CDATA[<p dir="auto">I have switched to MMM-Carousel and experimented with it. It ran for a few days without any problems. Then I installed more modules and customised my configuration. And now the problem is occurring again. The last scene hangs at some point, so I was afraid it might be this one: MMM-BackgroundSlideshow. However, you are not using this, so it is unlikely to be due to this.</p>
<p dir="auto">My next steps:</p>
<ol>
<li>disable MMM-BackgroundSlideshow.</li>
<li>completely reinstall everything and only install the modules I want to have at the end and then not change anything else. Let’s see if I will be successful.</li>
</ol>
]]></description><link>https://forum.magicmirror.builders/post/117961</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117961</guid><dc:creator><![CDATA[ric]]></dc:creator><pubDate>Sun, 26 May 2024 15:56:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Fri, 24 May 2024 12:56:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/babene1" aria-label="Profile: Babene1">@<bdi>Babene1</bdi></a><br />
It’s been updated, but I’m not expecting much. Because timers are rarely used in my code(only two), I don’t think that was the cause of the problem. Anyway, I fixed it so that when the timer is used, it is turned off as soon as possible.</p>
]]></description><link>https://forum.magicmirror.builders/post/117927</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117927</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Fri, 24 May 2024 12:56:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Fri, 24 May 2024 12:14:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/babene1" aria-label="Profile: Babene1">@<bdi>Babene1</bdi></a><br />
To disable animation, you can set <code>animation: null</code> in <code>defaultEnter</code> definition or each scene role definition.</p>
<pre><code class="language-js">/* example for default behaviour */
defaultEnter: {
  animation: null,
  duration: 1000,
  gap: 0,
/* example for each scene definition */
scenario: [
    enter: {
      role: "role1",
      animation: null,
<p dir="auto">I’m suspecting Chrome’s memory leaks. These factors may cause memory leaks.</p>
<ul>
<li>improper handling timer</li>
<li>CSS transition/Animation</li>
</ul>
<p dir="auto">I’ll modify some code to confirm to clear out garbage timer. Wait a little.</p>
<p dir="auto">By the way, can you test the default clock module instead of MMM-iFrame Things? (To make things clearer)</p>
]]></description><link>https://forum.magicmirror.builders/post/117926</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117926</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Fri, 24 May 2024 12:14:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Fri, 24 May 2024 10:09:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a></p>
<p dir="auto">Thank you for your answer, I agree with you, I also think that the error message has nothing to do with the problem.<br />
Error message is written to the log after the start and the freezing of the module happens after about 1 hour.</p>
<p dir="auto">I used the default animation, unfortunately I don’t know how to remove the animation completely.<br />
Have also removed the MMM remote control module.<br />
So there are only three modules left, MMM-Scenes2, MMM-iFrameReload and MMM-iFrameReload2</p>
<p dir="auto">I switched off WLan-power Save and deactivated IPV6.</p>
<p dir="auto">No improvement, no improvement.</p>
<p dir="auto">Next tests will be longer times and I will use a different browser.</p>
<p dir="auto">Other test scenarios ?</p>
]]></description><link>https://forum.magicmirror.builders/post/117925</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117925</guid><dc:creator><![CDATA[Babene1]]></dc:creator><pubDate>Fri, 24 May 2024 10:09:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Thu, 23 May 2024 13:57:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/babene1" aria-label="Profile: Babene1">@<bdi>Babene1</bdi></a><br />
I researched about that error message.<br />
The error messages seemed not to be the module or logic issue but the GPU/System issue.  (Usually in -nix machines about graphic drivers.)</p>
<p dir="auto">However, I’m not sure the error message is related to your symptom actually.  There is a chance these two things could be independent.</p>
<p dir="auto">What I suggest for the test is;</p>
<ul>
<li>use simpler animation effects or no animation.</li>
<li>give a longer life for the scene.</li>
<li>Remove all other 3rd party modules, except default modules (clock, …)</li>
</ul>
<p dir="auto">If it helps, we can progress from it anyhow.<br />
But if not; I think I rarely have things to do.</p>
]]></description><link>https://forum.magicmirror.builders/post/117921</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117921</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Thu, 23 May 2024 13:57:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Thu, 23 May 2024 09:22:35 GMT]]></title><description><![CDATA[<p dir="auto">I have the same problem, after about 1 hour there is no change of modules.<br />
I also want a constant change of MMM-iframeReload and MMM-iframeReload2 module</p>
<p dir="auto">MagicMirror Version 2.27, Rapsberry PI 4 – 4 GB<br />
My Config:</p>
<pre><code>/* MagicMirror² Config Sample
 * By Michael Teeuw https://michaelteeuw.nl
 * MIT Licensed.
 * see https://docs.magicmirror.builders/configuration/introduction.html
 * and https://docs.magicmirror.builders/modules/configuration.html
 * You can use environment variables using a `config.js.template` file instead of `config.js`
 * which will be converted to `config.js` while starting. For more information
 * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
let config = {
	address: "0.0.0.0",	// Address to listen on, can be:
	port: 8080,
	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.178.249", "192.168.178.49"], // Set [] to allow all IP addresses
	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
	language: "de",
	locale: "de-DE",
	timeFormat: 24,
	units: "metric",
	electronOptions: {
		webPreferences: {
		  webviewTag: true,
			module: "alert",
			module: "clock",
			position: "top_left"
		// https://github.com/TheBogueRat/MMM-iFrameReload
		module: 'MMM-iFrameReload',
		position: 'top_left',	// This can be any of the regions.
		classes: "SEITE_ZWEI",
		//header: 'Rezept des Tages',
				url: http://test/Anzeigetafeln/Anzeige1.html,
				width: "1900px", // Optional. Default: 100%
				height: "1080px", //Optional. Default: 100px
				refreshInterval: 100
			module: 'MMM-iFrameReload2',
			classes: "Welcome SEITE_EINS",
					url: http://test/Anzeigetafeln/Logo.html,
					refreshInterval: 3600
				// https://github.com/MMRIZE/MMM-Scenes2
				position: "bottom_bar",
					life: 1000 * 10,
					activeIndicator: ' ',
					inactiveIndicator: ' ',
					scenario: [
							exit: ["SEITE_ZWEI"],
							enter: ["SEITE_EINS"],
							life: 1000 * 10,
							exit: ["SEITE_EINS"],
							enter: ["SEITE_ZWEI"],
							life: 1000 * 45,
			// https://github.com/Jopyth/MMM-Remote-Control
			module: 'MMM-Remote-Control',
			// uncomment the following line to show the URL of the remote control on the mirror
			// position: 'bottom_left',
			// you can hide this module afterwards from the remote control itself
				customCommand: {
					//monitorStatusCommand: 'rm -rf .config/Electron',
					monitorStatusCommand: '~pi/restartBrowsercache.sh'
				},  // Optional, See "Using Custom Commands" below
				showModuleApiMenu: false, // Optional, Enable the Module Controls menu
				secureEndpoints: true, // Optional, See API/README.md
				// uncomment any of the lines below if you're gonna use it
				customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
				// apiKey: "", // Optional, See API/README.md for details
				// classes: {} // Optional, See "Custom Classes" below
<p dir="auto">I insert the line in my <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a>:</p>
<p dir="auto">export ELECTRON_DISABLE_GPU=1</p>
<p dir="auto">pm2 Log:</p>
<p dir="auto">[1965:0521/220109.925300:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)<br />
[1965:0521/220109.925398:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)</p>
<p dir="auto">uname -a<br />
Linux raspberryanzeige1 6.1.0-rpi8-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.73-1+rpt1 (2024-01-25) aarch64 GNU/Linux</p>
<p dir="auto">file /bin/bash<br />
/bin/bash: ELF 64-bit LSB pie executable, ARM aarch64, version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-aarch64.so.1, BuildID[sha1]=198ac6b0cc01bf774c5746a36a6fd31dead9bda5, for GNU/Linux 3.7.0, stripped</p>
<p dir="auto">Does anyone have any idea what I can do? Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/117917</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117917</guid><dc:creator><![CDATA[Babene1]]></dc:creator><pubDate>Thu, 23 May 2024 09:22:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Sat, 16 Dec 2023 11:20:06 GMT]]></title><description><![CDATA[<p dir="auto">Very strange. I have created a third scene. Now it is already running for several hours.</p>
]]></description><link>https://forum.magicmirror.builders/post/113393</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113393</guid><dc:creator><![CDATA[ric]]></dc:creator><pubDate>Sat, 16 Dec 2023 11:20:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Fri, 15 Dec 2023 01:06:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a><br />
Thanks anyway.</p>
<p dir="auto">Would you say it’s the Pi version? Software/hardware version? Could this be fixed with a Chromium update in the future?</p>
]]></description><link>https://forum.magicmirror.builders/post/113375</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113375</guid><dc:creator><![CDATA[ric]]></dc:creator><pubDate>Fri, 15 Dec 2023 01:06:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Thu, 14 Dec 2023 16:14:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ric" aria-label="Profile: ric">@<bdi>ric</bdi></a><br />
Log says nothing suspicious. I suspect Chromium graphic memory leak issues due to last parts of error-log.<br />
In that case, I have nothing to help. Sorry.</p>
]]></description><link>https://forum.magicmirror.builders/post/113331</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113331</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Thu, 14 Dec 2023 16:14:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Thu, 14 Dec 2023 16:02:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a><br />
I have changed the animations. New: fadeIn/fadeOut<br />
I have installed MMM-LogExt.<br />
MagicMirror is running and I will keep an eye on it. As soon as it stops running correctly, I will post the logs.<br />
Thank you</p>
<p dir="auto">Current log entry</p>
<pre><code>pi@magicmirror:~/MagicMirror $ pm2 logs MagicMirror
[TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
/home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
0|MagicMir | [29109:1214/163910.531720:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
0|MagicMir | [29109:1214/163910.534010:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
0|MagicMir | [29109:1214/163910.535596:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
0|MagicMir | [29109:1214/163910.536560:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
0|MagicMir | [29109:1214/163910.537412:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
0|MagicMir | [29109:1214/163910.539776:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
0|MagicMir | [29109:1214/163910.540617:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
0|MagicMir | [29109:1214/163910.541337:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
0|MagicMir | [29109:1214/163910.542083:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
0|MagicMir | [29109:1214/163910.542859:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
0|MagicMir | [29109:1214/163910.543568:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
0|MagicMir | [29109:1214/163910.544310:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
0|MagicMir | [29109:1214/163912.238616:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
0|MagicMir | [29109:1214/163912.240892:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
0|MagicMir | [29109:1214/163923.075684:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
/home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
0|MagicMirror  | [14.12.2023 16:56.57.386] [LOG]   [library.mjs:174:9] [SCENE] Scene transition starts: scene_2
0|MagicMirror  | [14.12.2023 16:57.00.007] [LOG]   [library.mjs:178:9] [SCENE] Scene will live: scene_2 60000
0|MagicMirror  | [14.12.2023 16:58.00.036] [LOG]   [library.mjs:174:9] [SCENE] Scene transition starts: scene_1
0|MagicMirror  | [14.12.2023 16:58.02.697] [LOG]   [library.mjs:178:9] [SCENE] Scene will live: scene_1 60000
0|MagicMirror  | [14.12.2023 16:59.02.696] [LOG]   [library.mjs:174:9] [SCENE] Scene transition starts: scene_2
0|MagicMirror  | [14.12.2023 16:59.05.324] [LOG]   [library.mjs:178:9] [SCENE] Scene will live: scene_2 60000
0|MagicMirror  | [14.12.2023 16:59.15.816] [LOG]   [weather.js:166:7] New weather information available.
0|MagicMirror  | [14.12.2023 16:59.15.952] [LOG]   [weather.js:166:7] New weather information available.
0|MagicMirror  | [14.12.2023 17:00.05.325] [LOG]   [library.mjs:174:9] [SCENE] Scene transition starts: scene_1
0|MagicMirror  | [14.12.2023 17:00.07.959] [LOG]   [library.mjs:178:9] [SCENE] Scene will live: scene_1 60000
0|MagicMirror  | [14.12.2023 17:01.07.968] [LOG]   [library.mjs:174:9] [SCENE] Scene transition starts: scene_2
0|MagicMirror  | [14.12.2023 17:01.10.602] [LOG]   [library.mjs:178:9] [SCENE] Scene will live: scene_2 60000
0|MagicMirror  | [14.12.2023 17:02.10.614] [LOG]   [library.mjs:174:9] [SCENE] Scene transition starts: scene_1
0|MagicMirror  | [14.12.2023 17:02.13.263] [LOG]   [library.mjs:178:9] [SCENE] Scene will live: scene_1 60000
<p dir="auto">Is MMM-LogExt working correctly or do I need to adjust something?</p>
]]></description><link>https://forum.magicmirror.builders/post/113313</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113313</guid><dc:creator><![CDATA[ric]]></dc:creator><pubDate>Thu, 14 Dec 2023 16:02:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Thu, 14 Dec 2023 13:48:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ric" aria-label="Profile: ric">@<bdi>ric</bdi></a><br />
And, your log is just backend log, I need front-end log.<br />
You can see front-end log by;</p>
<ul>
<li>installing MMM-LogExt</li>
<li>Or, dev-console of your MM screen, not terminal. (with <code>npm run start:dev</code>, you can see dev-console panel on your MM screen.)</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/113304</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113304</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Thu, 14 Dec 2023 13:48:21 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Thu, 14 Dec 2023 13:46:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ric" aria-label="Profile: ric">@<bdi>ric</bdi></a><br />
Maybe there would be some memory leaks on the chromium.<br />
Can you test it again with more simple animations?(Just fadeIn, fadeOut) Some version of Chromium is known for possible memory leaking on transitions.</p>
]]></description><link>https://forum.magicmirror.builders/post/113303</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113303</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Thu, 14 Dec 2023 13:46:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Thu, 14 Dec 2023 08:52:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ric" aria-label="Profile: ric">@<bdi>ric</bdi></a> said in <a href="/post/113287">MMM-Scenes2</a>:</p>
<p dir="auto">[5658:1213/232023.441362:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)</p>
<p dir="auto">I’m not sure whether this error is related to your symptom but refer to this.<br />
<a href="https://forum.magicmirror.builders/topic/18076/failed-to-export-buffer-to-dma_buf-no-such-file-or-directory">https://forum.magicmirror.builders/topic/18076/failed-to-export-buffer-to-dma_buf-no-such-file-or-directory</a></p>
<p dir="auto">And for ;</p>
<p dir="auto">[5658:1213/232033.074222:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!</p>
<p dir="auto">It also seems related to the GPU/GL issue of electron/chromium.<br />
<a href="https://github.com/electron/electron/issues/32760" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/electron/electron/issues/32760</a></p>
<p dir="auto">Hmmm, for those issues, I cannot help.</p>
<p dir="auto">If you find something other from the log, report it again.</p>
]]></description><link>https://forum.magicmirror.builders/post/113299</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113299</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Thu, 14 Dec 2023 08:52:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Thu, 14 Dec 2023 07:51:11 GMT]]></title><description><![CDATA[<p dir="auto">After several hours, the loop is blocked again.<br />
But there is not much to see in the log.</p>
<p dir="auto">I have deleted the log ~/.pm2/logs and started it again. I can also post this afterwards.</p>
<pre><code>pi@magicmirror:~/MagicMirror $ npm run start:dev
&gt; magicmirror@2.25.0 start:dev
&gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js dev
[13.12.2023 23:55.22.997] [LOG]   Starting MagicMirror: v2.25.0
[13.12.2023 23:55.23.002] [LOG]   Loading config ...
[13.12.2023 23:55.23.005] [DEBUG] config template file not exists, no envsubst
[13.12.2023 23:55.23.010] [LOG]   Loading module helpers ...
[13.12.2023 23:55.23.012] [LOG]   No helper found for module: alert.
[13.12.2023 23:55.23.037] [LOG]   Initializing new module helper ...
[13.12.2023 23:55.23.038] [LOG]   Module helper loaded: updatenotification
[13.12.2023 23:55.23.039] [LOG]   No helper found for module: clock.
[13.12.2023 23:55.23.109] [LOG]   Initializing new module helper ...
[13.12.2023 23:55.23.110] [LOG]   Module helper loaded: MMM-text-clock
[13.12.2023 23:55.23.336] [LOG]   Initializing new module helper ...
[13.12.2023 23:55.23.336] [LOG]   Module helper loaded: calendar
[13.12.2023 23:55.23.337] [LOG]   No helper found for module: weather.
[13.12.2023 23:55.23.351] [LOG]   Initializing new module helper ...
[13.12.2023 23:55.23.352] [LOG]   Module helper loaded: MMM-Scenes2
[13.12.2023 23:55.23.352] [LOG]   All module helpers loaded.
[13.12.2023 23:55.23.360] [LOG]   Starting server on port 8080 ...
[13.12.2023 23:55.23.755] [LOG]   Server started ...
[13.12.2023 23:55.23.756] [LOG]   Connecting socket for: updatenotification
[13.12.2023 23:55.23.757] [LOG]   Starting module helper: updatenotification
[13.12.2023 23:55.23.757] [LOG]   Connecting socket for: MMM-text-clock
[13.12.2023 23:55.23.758] [LOG]   Starting module helper: MMM-text-clock
[13.12.2023 23:55.23.758] [LOG]   Connecting socket for: calendar
[13.12.2023 23:55.23.759] [LOG]   Starting node helper for: calendar
[13.12.2023 23:55.23.759] [LOG]   Connecting socket for: MMM-Scenes2
[13.12.2023 23:55.24.018] [LOG]   Sockets connected &amp; modules started ...
[13.12.2023 23:55.24.126] [LOG]   Launching application.
[6004:1213/235525.303520:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[6004:1213/235525.304075:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[6004:1213/235525.304482:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[6004:1213/235525.304869:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[6004:1213/235525.305244:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[6004:1213/235525.305713:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[6004:1213/235525.306098:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[6004:1213/235525.307820:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[6004:1213/235525.308207:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[6004:1213/235525.308576:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[6004:1213/235525.308928:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[6004:1213/235525.309269:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[6004:1213/235525.309644:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[6004:1213/235525.310007:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[13.12.2023 23:55.27.245] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics - Interval: 3600000
[13.12.2023 23:55.27.382] [LOG]   Create new calendarfetcher for url: https://onlinekalender.info/feiertage/schweiz.ics - Interval: 3600000
[13.12.2023 23:55.27.389] [INFO]  Checking git for module: MMM-text-clock
[13.12.2023 23:55.28.161] [INFO]  Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics.
[13.12.2023 23:55.28.195] [INFO]  Checking git for module: MMM-Scenes2
[13.12.2023 23:55.28.616] [INFO]  Checking git for module: MagicMirror
[13.12.2023 23:55.30.046] [INFO]  Calendar-Fetcher: Broadcasting 3 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics.
[6004:1213/235535.089417:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
[6004:1213/235537.084669:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
[6004:1213/235540.087744:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
[14.12.2023 00:55.28.404] [INFO]  Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics.
[14.12.2023 00:55.30.993] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics.
[14.12.2023 01:55.28.639] [INFO]  Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics.
[14.12.2023 01:55.31.758] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics.
[14.12.2023 02:55.28.843] [INFO]  Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics.
[14.12.2023 02:55.32.503] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics.
[14.12.2023 03:55.29.056] [INFO]  Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics.
[14.12.2023 03:55.33.226] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics.
[14.12.2023 04:55.29.269] [INFO]  Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics.
[14.12.2023 04:55.33.880] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics.
[14.12.2023 05:55.29.449] [INFO]  Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics.
[14.12.2023 05:55.34.466] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics.
[14.12.2023 06:55.29.648] [INFO]  Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics.
[14.12.2023 06:55.35.144] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics.
[14.12.2023 07:55.29.860] [INFO]  Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics.
[14.12.2023 07:55.35.877] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/xxxxxxxx/basic.ics.
]]></description><link>https://forum.magicmirror.builders/post/113301</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113301</guid><dc:creator><![CDATA[ric]]></dc:creator><pubDate>Thu, 14 Dec 2023 07:51:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Wed, 13 Dec 2023 22:49:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a><br />
Thank you for your patience.<br />
Now magicmirror is running in debug mode. So far it runs as it should.</p>
[13.12.2023 23:20.19.284] [LOG]   Starting MagicMirror: v2.25.0
[13.12.2023 23:20.19.289] [LOG]   Loading config ...
[13.12.2023 23:20.19.293] [DEBUG] config template file not exists, no envsubst
[13.12.2023 23:20.19.298] [LOG]   Loading module helpers ...
[13.12.2023 23:20.19.300] [LOG]   No helper found for module: alert.
[13.12.2023 23:20.19.325] [LOG]   Initializing new module helper ...
[13.12.2023 23:20.19.326] [LOG]   Module helper loaded: updatenotification
[13.12.2023 23:20.19.327] [LOG]   No helper found for module: clock.
[13.12.2023 23:20.19.399] [LOG]   Initializing new module helper ...
[13.12.2023 23:20.19.400] [LOG]   Module helper loaded: MMM-text-clock
[13.12.2023 23:20.19.627] [LOG]   Initializing new module helper ...
[13.12.2023 23:20.19.628] [LOG]   Module helper loaded: calendar
[13.12.2023 23:20.19.628] [LOG]   No helper found for module: weather.
[13.12.2023 23:20.19.643] [LOG]   Initializing new module helper ...
[13.12.2023 23:20.19.643] [LOG]   Module helper loaded: MMM-Scenes2
[13.12.2023 23:20.19.643] [LOG]   All module helpers loaded.
[13.12.2023 23:20.19.651] [LOG]   Starting server on port 8080 ...
[13.12.2023 23:20.20.122] [LOG]   Server started ...
[13.12.2023 23:20.20.122] [LOG]   Connecting socket for: updatenotification
[13.12.2023 23:20.20.123] [LOG]   Starting module helper: updatenotification
[13.12.2023 23:20.20.123] [LOG]   Connecting socket for: MMM-text-clock
[13.12.2023 23:20.20.124] [LOG]   Starting module helper: MMM-text-clock
[13.12.2023 23:20.20.124] [LOG]   Connecting socket for: calendar
[13.12.2023 23:20.20.125] [LOG]   Starting node helper for: calendar
[13.12.2023 23:20.20.125] [LOG]   Connecting socket for: MMM-Scenes2
[13.12.2023 23:20.20.425] [LOG]   Sockets connected &amp; modules started ...
[13.12.2023 23:20.20.576] [LOG]   Launching application.
[5658:1213/232023.441848:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[5658:1213/232023.442182:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[5658:1213/232023.442478:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[5658:1213/232023.442771:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[5658:1213/232023.443062:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[5658:1213/232023.443344:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[5658:1213/232023.444865:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[5658:1213/232023.445175:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[5658:1213/232023.445471:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[5658:1213/232023.445828:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[5658:1213/232023.446143:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[5658:1213/232023.446421:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[5658:1213/232023.446686:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
[13.12.2023 23:20.25.506] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/xxxxxxxxxxxxx/basic.ics - Interval: 3600000
[13.12.2023 23:20.25.672] [LOG]   Create new calendarfetcher for url: https://onlinekalender.info/feiertage/schweiz.ics - Interval: 3600000
[13.12.2023 23:20.25.678] [INFO]  Checking git for module: MMM-text-clock
[13.12.2023 23:20.26.283] [INFO]  Calendar-Fetcher: Broadcasting 26 events from https://onlinekalender.info/feiertage/schweiz.ics.
[13.12.2023 23:20.26.344] [INFO]  Checking git for module: MMM-Scenes2
[13.12.2023 23:20.26.553] [INFO]  Checking git for module: MagicMirror
[13.12.2023 23:20.28.191] [INFO]  Calendar-Fetcher: Broadcasting 3 events from https://calendar.google.com/xxxxxxxxxxxxx/basic.ics.
[5658:1213/232037.073720:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
[5658:1213/232039.081014:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
<p dir="auto">I’ll let it run until something suspicious is output and then report back.<br />
Thank you very much</p>
]]></description><link>https://forum.magicmirror.builders/post/113287</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113287</guid><dc:creator><![CDATA[ric]]></dc:creator><pubDate>Wed, 13 Dec 2023 22:49:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Scenes2 on Wed, 13 Dec 2023 19:24:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a> said in <a href="/post/113275">MMM-Scenes2</a>:</p>
Install MMM-LogExt; that module would help deliver your front-end log to the backend log. If you are using pm2, you can see the log  in <code>~/.pm2/logs</code> or somewhere. (I’m not sure about your environment.)</p>
<p dir="auto">pm2 only captures backend log,</p>
<p dir="auto">nothing captures front end log unless your LogExt is installed.</p>
]]></description><link>https://forum.magicmirror.builders/post/113276</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113276</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 13 Dec 2023 19:24:58 GMT</pubDate></item></channel></rss>
