<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Incorrect Clock module time after update to latest MM]]></title><description><![CDATA[<p dir="auto">After updating to latest version of MM I noticed the default clock display the incorrect hour.  Exactly 5 hrs ahead.  Have been running the same MM pi for 5 plus years with no issue.<br />
Things I’ve done o remedy:</p>
<ul>
<li>
<p dir="auto">checked the Raspberry pi localization settings which are set  to US - timezone Eastern</p>
</li>
<li>
<p dir="auto">validated pi is displaying correct time</p>
</li>
<li>
<p dir="auto">googled this issue to find that others had corrected this by inserting the following in<br />
config.js</p>
<p dir="auto">config {<br />
timezone:“America/New_York”,<br />
}</p>
</li>
</ul>
<p dir="auto">this did not correct the time.</p>
<p dir="auto">What do I need to do to get the time to display properly?</p>
]]></description><link>https://forum.magicmirror.builders/topic/18272/incorrect-clock-module-time-after-update-to-latest-mm</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 10:58:48 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18272.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 15 Dec 2023 00:16:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Incorrect Clock module time after update to latest MM on Mon, 18 Dec 2023 20:50:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nschertz" aria-label="Profile: nschertz">@<bdi>nschertz</bdi></a> No worries. Little errors like that happen to all of us.</p>
]]></description><link>https://forum.magicmirror.builders/post/113458</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113458</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Mon, 18 Dec 2023 20:50:14 GMT</pubDate></item><item><title><![CDATA[Reply to Incorrect Clock module time after update to latest MM on Mon, 18 Dec 2023 01:13:52 GMT]]></title><description><![CDATA[<p dir="auto">D’oh. I found my issue… I inadvertently typed Config: instead of lower case config:</p>
<p dir="auto">Issued resolved. Thx for taking time to respond. Sorry to have troubled you.</p>
<p dir="auto">Norb</p>
]]></description><link>https://forum.magicmirror.builders/post/113438</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113438</guid><dc:creator><![CDATA[nschertz]]></dc:creator><pubDate>Mon, 18 Dec 2023 01:13:52 GMT</pubDate></item><item><title><![CDATA[Reply to Incorrect Clock module time after update to latest MM on Mon, 18 Dec 2023 00:49:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nschertz" aria-label="Profile: nschertz">@<bdi>nschertz</bdi></a> can you show the clock module definition from config js.</p>
]]></description><link>https://forum.magicmirror.builders/post/113431</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113431</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 18 Dec 2023 00:49:48 GMT</pubDate></item><item><title><![CDATA[Reply to Incorrect Clock module time after update to latest MM on Mon, 18 Dec 2023 00:33:22 GMT]]></title><description><![CDATA[<p dir="auto">I added this configuration code to the clock module portion within config.js. Is that the corct place?</p>
]]></description><link>https://forum.magicmirror.builders/post/113427</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113427</guid><dc:creator><![CDATA[nschertz]]></dc:creator><pubDate>Mon, 18 Dec 2023 00:33:22 GMT</pubDate></item><item><title><![CDATA[Reply to Incorrect Clock module time after update to latest MM on Mon, 18 Dec 2023 00:31:03 GMT]]></title><description><![CDATA[<p dir="auto">I added this to the clock module portion with in config.js. Is that the correct place?</p>
]]></description><link>https://forum.magicmirror.builders/post/113426</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113426</guid><dc:creator><![CDATA[nschertz]]></dc:creator><pubDate>Mon, 18 Dec 2023 00:31:03 GMT</pubDate></item><item><title><![CDATA[Reply to Incorrect Clock module time after update to latest MM on Fri, 15 Dec 2023 00:35:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nschertz" aria-label="Profile: nschertz">@<bdi>nschertz</bdi></a> that goes in the clock module  right?</p>
]]></description><link>https://forum.magicmirror.builders/post/113374</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113374</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 15 Dec 2023 00:35:54 GMT</pubDate></item></channel></rss>
