<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Initial Install]]></title><description><![CDATA[<p dir="auto">Hello all. Let me preface this by saying I’m a noob. I’m working through the install and when trying to manually download and install the latest Node.js I’m a bit stuck. There use to be a line to copy and now it directs you to documentation and I’m a bit stuck on what to use. I have a raspberry pi 3b. I know I should use Linux documentation but not sure where to go from there. Again I’m still learning so apologies in advance for the noob question. Any help would be much appreciated</p>
]]></description><link>https://forum.magicmirror.builders/topic/18274/initial-install</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 21:49:54 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18274.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 17 Dec 2023 22:48:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Initial Install on Mon, 18 Dec 2023 00:47:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brownlkt" aria-label="Profile: Brownlkt">@<bdi>Brownlkt</bdi></a> use my script, mentioned as the 1st alternative install method</p>
<p dir="auto"><a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
<p dir="auto">make a new SD card, boot, set the userid, network, skip updates, reboot<br />
enable ssh</p>
<p dir="auto">connect from your PC, copy/paste the install command from the web page.</p>
<p dir="auto">answer a couple questions later</p>
]]></description><link>https://forum.magicmirror.builders/post/113428</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113428</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 18 Dec 2023 00:47:47 GMT</pubDate></item><item><title><![CDATA[Reply to Initial Install on Mon, 18 Dec 2023 08:41:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brownlkt" aria-label="Profile: Brownlkt">@<bdi>Brownlkt</bdi></a> glad you made progress.</p>
<p dir="auto">lots to know at the beginning. some of it more tricky than it should be.</p>
]]></description><link>https://forum.magicmirror.builders/post/113446</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113446</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 18 Dec 2023 08:41:41 GMT</pubDate></item><item><title><![CDATA[Reply to Initial Install on Mon, 18 Dec 2023 03:16:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you so much for your help. I was trying to do it manually but I’m clearly not there yet ;-) Much appreciation from someone still in the learning phase.</p>
]]></description><link>https://forum.magicmirror.builders/post/113445</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113445</guid><dc:creator><![CDATA[Brownlkt]]></dc:creator><pubDate>Mon, 18 Dec 2023 03:16:12 GMT</pubDate></item><item><title><![CDATA[Reply to Initial Install on Mon, 18 Dec 2023 02:12:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks! Giving it a go now.</p>
]]></description><link>https://forum.magicmirror.builders/post/113443</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113443</guid><dc:creator><![CDATA[Brownlkt]]></dc:creator><pubDate>Mon, 18 Dec 2023 02:12:04 GMT</pubDate></item><item><title><![CDATA[Reply to Initial Install on Mon, 18 Dec 2023 00:47:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brownlkt" aria-label="Profile: Brownlkt">@<bdi>Brownlkt</bdi></a> use my script, mentioned as the 1st alternative install method</p>
enable ssh</p>
]]></description><link>https://forum.magicmirror.builders/post/113428</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113428</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 18 Dec 2023 00:47:47 GMT</pubDate></item></channel></rss>
