<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MESA issues - mm actually displays]]></title><description><![CDATA[<p dir="auto">Saw this error in <code>npm start</code>. Quick search says that these typically rnder a black screen - I am actually seeing MM, so what does this error mean?</p>
<pre><code>MESA-LOADER: failed to retrieve device information
../../buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n &lt; size() failed: vector[] index out of bounds[27159:1223/223830.134308:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
../../buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n &lt; size() failed: vector[] index out of bounds[27202:1223/223831.357228:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
[27159:1223/223831.363276:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
[27202:1223/223832.163432:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
]]></description><link>https://forum.magicmirror.builders/topic/18294/mesa-issues-mm-actually-displays</link><generator>RSS for Node</generator><lastBuildDate>Fri, 07 Aug 2026 22:22:14 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18294.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 24 Dec 2023 03:48:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MESA issues - mm actually displays on Sun, 24 Dec 2023 12:08:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nakulbende" aria-label="Profile: nakulbende">@<bdi>nakulbende</bdi></a> turn off use of the GPU.</p>
<p dir="auto">add</p>
<pre><code>export ELECTRON_DISABLE_GPU=1
<p dir="auto">to the place where you do<br />
npm start</p>
<p dir="auto">add that line before the npm start</p>
<p dir="auto">in next release Jan 1,<br />
we are doing this by default a d adding a new<br />
ELECTRON_ENABLE_GPU=1</p>
<p dir="auto">as no one is really using the GPU</p>
]]></description><link>https://forum.magicmirror.builders/post/113565</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113565</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 24 Dec 2023 12:08:36 GMT</pubDate></item><item><title><![CDATA[Reply to MESA issues - mm actually displays on Sun, 24 Dec 2023 04:24:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nakulbende" aria-label="Profile: nakulbende">@<bdi>nakulbende</bdi></a> 90% of the time this can be ignored. If you’re getting your mirror up on screen, there’s no issue.</p>
]]></description><link>https://forum.magicmirror.builders/post/113557</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113557</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Sun, 24 Dec 2023 04:24:50 GMT</pubDate></item></channel></rss>
