<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-SantaTracker]]></title><description><![CDATA[<p dir="auto">I created a quick module that will map Santa as he travels around the world Christmas Eve to distribute presents. This is a quick &amp; dirty module that uses the data from Google’s Santa Tracker suite of applications.<br />
<img src="/assets/uploads/files/1703441455524-screenshot.png" alt="ScreenShot.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">Santa’s location updates every minute. Grab the code at <a href="https://github.com/BrianHepler/MMM-SantaTracker.git" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-SantaTracker</a></p>
]]></description><link>https://forum.magicmirror.builders/topic/18298/mmm-santatracker</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 23:51:51 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18298.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 24 Dec 2023 18:11:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-SantaTracker on Sat, 13 Dec 2025 02:17:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> there was a forum update, one of many trying to be current.  One of the recent changes turned off digests, maybe it turned off notifications.</p>
<p dir="auto">I dont use them, do I can’t tell</p>
]]></description><link>https://forum.magicmirror.builders/post/129228</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129228</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 13 Dec 2025 02:17:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SantaTracker on Sat, 13 Dec 2025 02:03:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmmallday" aria-label="Profile: mmmallday">@<bdi>mmmallday</bdi></a> - I don’t know why I’m not getting notifications from the forum but I’m just now seeing these replies to the thread.</p>
<p dir="auto"><strong>Thank you</strong> for your work in updating the module. I’ve merged your pull request into the baseline. I encourage everyone to update the module and check out the new features.</p>
]]></description><link>https://forum.magicmirror.builders/post/129227</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129227</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Sat, 13 Dec 2025 02:03:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SantaTracker on Thu, 04 Dec 2025 02:19:27 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://github.com/wlans/MMM-SantaTracker" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/wlans/MMM-SantaTracker</a></p>
]]></description><link>https://forum.magicmirror.builders/post/129181</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129181</guid><dc:creator><![CDATA[mmmallday]]></dc:creator><pubDate>Thu, 04 Dec 2025 02:19:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SantaTracker on Thu, 04 Dec 2025 01:49:52 GMT]]></title><description><![CDATA[<p dir="auto">Also updates the override time so you can see the journey when doing override</p>
]]></description><link>https://forum.magicmirror.builders/post/129180</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129180</guid><dc:creator><![CDATA[mmmallday]]></dc:creator><pubDate>Thu, 04 Dec 2025 01:49:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SantaTracker on Thu, 04 Dec 2025 01:48:29 GMT]]></title><description><![CDATA[<p dir="auto">said in <a href="/post/129153">MMM-SantaTracker</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> said in <a href="/post/122155">MMM-SantaTracker</a>:</p>
<p dir="auto"><strong>Update for 2024!</strong></p>
<ul>
<li>Latest version has a more robust image loading which should cut down on missing images.</li>
<li>Implemented the <code>overTime</code> variable, which will allow you to override the calculated date &amp; time for Santa’s trip. This is useful for testing beforehand.</li>
</ul>
<p dir="auto">Merry Christmas!</p>
<p dir="auto">Are you updating for 2025?</p>
<p dir="auto">I forked it and made some speed increases and made processing happen in a node helper which helps if you use magic mirror in server mode. My my powerful server does all the processing and keeps it off the client. Will push up my code</p>
]]></description><link>https://forum.magicmirror.builders/post/129179</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129179</guid><dc:creator><![CDATA[mmmallday]]></dc:creator><pubDate>Thu, 04 Dec 2025 01:48:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SantaTracker on Tue, 02 Dec 2025 22:59:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a><br />
Following for updates on if your module, will be even better in 2025.???</p>
]]></description><link>https://forum.magicmirror.builders/post/129155</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129155</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Tue, 02 Dec 2025 22:59:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SantaTracker on Tue, 02 Dec 2025 12:19:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> said in <a href="/post/122155">MMM-SantaTracker</a>:</p>
<ul>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/129153</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129153</guid><dc:creator><![CDATA[mmmallday]]></dc:creator><pubDate>Tue, 02 Dec 2025 12:19:39 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SantaTracker on Sun, 29 Dec 2024 16:15:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> I think it would be nice if you would add it to the module list: <a href="https://github.com/MagicMirrorOrg/MagicMirror/wiki/3rd-party-modules" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MagicMirrorOrg/MagicMirror/wiki/3rd-party-modules</a> 🎅</p>
]]></description><link>https://forum.magicmirror.builders/post/122288</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122288</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Sun, 29 Dec 2024 16:15:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SantaTracker on Sun, 29 Dec 2024 13:21:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> amazing. I had this idea too but got lost in the details. What API you using? My idea was to have a lat and long and countdown to when Santa is coming there. Feel free to steal it.</p>
]]></description><link>https://forum.magicmirror.builders/post/122282</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122282</guid><dc:creator><![CDATA[mmmallday]]></dc:creator><pubDate>Sun, 29 Dec 2024 13:21:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SantaTracker on Mon, 23 Dec 2024 23:58:25 GMT]]></title><description><![CDATA[<p dir="auto"><strong>Update for 2024!</strong></p>
<ul>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/122155</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122155</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Mon, 23 Dec 2024 23:58:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SantaTracker on Sun, 24 Dec 2023 19:17:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> cool!</p>
<p dir="auto">wish I had little ones!</p>
]]></description><link>https://forum.magicmirror.builders/post/113571</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113571</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 24 Dec 2023 19:17:19 GMT</pubDate></item></channel></rss>
