<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Magicmirror not using monitor for display]]></title><description><![CDATA[<p dir="auto">Hi<br />
Not sure why but when I launch Magicmirror on bookworm with RPI4, the monitor display is on only for a few seconds when the pi is booting up but then just goes blank. When i use VNC, i see the MagicMirror as normal. If i stop MagicMirror, i can see desktop on VNC but the monitor is still off. It only ever comes on for about 5sec when i boot the Pi. How can i troubleshoot this?</p>
]]></description><link>https://forum.magicmirror.builders/topic/18303/magicmirror-not-using-monitor-for-display</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 02:33:26 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18303.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 25 Dec 2023 21:37:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Magicmirror not using monitor for display on Mon, 25 Dec 2023 22:32:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Worked it out! the monitor would just lose signal straight after the boot screen everytime. Turned out i just needed to change the resolution to a lower one, so i’m guessing my monitor was too old to support whatever resolution Bookworm was trying to push</p>
]]></description><link>https://forum.magicmirror.builders/post/113598</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113598</guid><dc:creator><![CDATA[rama3124]]></dc:creator><pubDate>Mon, 25 Dec 2023 22:32:31 GMT</pubDate></item><item><title><![CDATA[Reply to Magicmirror not using monitor for display on Mon, 25 Dec 2023 22:17:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rama3124" aria-label="Profile: rama3124">@<bdi>rama3124</bdi></a> tell us more.<br />
mm black screen is typically a module problem</p>
]]></description><link>https://forum.magicmirror.builders/post/113597</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113597</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 25 Dec 2023 22:17:25 GMT</pubDate></item></channel></rss>
