<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[v2.26.0]]></title><description><![CDATA[<h2>[2.26.0] - 01-01-2024</h2>
<p dir="auto"><a href="https://github.com/MichMich/MagicMirror/releases/tag/v2.26.0" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/releases/tag/v2.26.0</a></p>
<p dir="auto">Thanks to: <a class="plugin-mentions-user plugin-mentions-a" href="/user/bnitkin" aria-label="Profile: bnitkin">@<bdi>bnitkin</bdi></a>, <a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a>, @dependabot, @jkriegshauser, @kaennchenstruggle, <a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a> and <a class="plugin-mentions-user plugin-mentions-a" href="/user/ybbet" aria-label="Profile: Ybbet">@<bdi>Ybbet</bdi></a>.</p>
<p dir="auto">Special thanks to @khassel, <a class="plugin-mentions-user plugin-mentions-a" href="/user/rejas" aria-label="Profile: rejas">@<bdi>rejas</bdi></a> and <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> for taking over most (if not all) of the work on this release as project collaborators. This version would not be there without their effort. Thank you guys! You are awesome!</p>
<p dir="auto">This release also marks the latest release by Michael Teeuw. For more info, please read the following post: <a href="https://forum.magicmirror.builders/topic/18329/a-new-chapter-for-magicmirror-the-community-takes-the-lead">A New Chapter for MagicMirror: The Community Takes the Lead</a>.</p>
<h3>Added</h3>
<ul>
<li>Added update notification updater (for 3rd party modules)</li>
<li>Added node 21 to the test matrix</li>
<li>Added transform object to calendar:customEvents</li>
<li>Added ESLint rules for jest (including jest/expect-expect and jest/no-done-callback)</li>
</ul>
<h3>Removed</h3>
<ul>
<li>Removed Codecov workflow (not working anymore, other workflow required) (#3107)</li>
<li>Removed titleReplace from calendar, replaced + extended by customEvents (backward compatibility included) (#3249)</li>
<li>Removed failing unit test (#3254)</li>
<li>Removed some unused variables</li>
</ul>
<h3>Updated</h3>
<ul>
<li>Update electron to v27 and update other dependencies as well as github actions</li>
<li>Update newsfeed: Use <code>html-to-text</code> instead of regex for transform description</li>
<li>Review ESLint config (#3269)</li>
<li>Updated dependencies</li>
<li>Clock module: optionally display current moon phase in addition to rise/set times</li>
<li>electron is now per default started without gpu, if needed it must be enabled with new env var <code>ELECTRON_ENABLE_GPU=1</code> on startup (#3226)</li>
<li>Replace prettier by stylistic in ESLint config to lint JavaScript (and disable some rules for <code>config/config.js*</code> files)</li>
<li>Update node-ical to v0.17.1 and fix tests</li>
</ul>
<h3>Fixed</h3>
<ul>
<li>Avoid fade out/in on updateDom when many calendars are used</li>
<li>Fix the option eventClass on customEvents.</li>
<li>Fix yr API version in locationforecast and sunrise call (#3227)</li>
<li>Fix cloneObject() function to respect RegExp (#3237)</li>
<li>Fix newsfeed module for feeds using “a10:updated” tag (#3238)</li>
<li>Fix issue template (#3167)</li>
<li>Fix #3256 filter out bad results from rrule.between</li>
<li>Fix calendar events sometimes not respecting deleted events (#3250)</li>
<li>Fix electron loadurl locally on Windows when address “0.0.0.0” (#2550)</li>
<li>Fix updatanotification (update_helper.js): catch error if reponse is not an JSON format (check PM2)</li>
<li>Fix missing typeof in calendar module</li>
<li>Fix style issues after prettier update</li>
<li>Fix calendar test (#3291) by moving “Exdate check” from e2e to electron to run on a Thursday</li>
<li>Fix calendar config params <code>fetchInterval</code> and <code>excludedEvents</code> were never used from single calendar config (#3297)</li>
<li>Fix MM_PORT variable not used in electron and allow full path for MM_CONFIG_FILE variable (#3302)</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/topic/18330/v2-26-0</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 01:21:08 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18330.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 Jan 2024 14:39:54 GMT</pubDate><ttl>60</ttl></channel></rss>
