<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Homewizard P1 meter]]></title><description><![CDATA[<p dir="auto">I like to see some data from the Homewizard P1 meter on my mirror.<br />
There is an local api which can be turned on in the app.<br />
In a browser i get the current data with http://IP_P1_meter/api/v1/telegram<br />
Unfortunately my coding skills are not that great.</p>
<p dir="auto">Hope someone like to create it</p>
]]></description><link>https://forum.magicmirror.builders/topic/18342/homewizard-p1-meter</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 20:46:01 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18342.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 04 Jan 2024 10:49:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Homewizard P1 meter on Wed, 27 Nov 2024 15:44:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a> that says you changed a file in the module, which you aren’t supposed to do.</p>
<p dir="auto">git status would have shown the changed file(s)<br />
git diff would have shown you the exact changes</p>
<p dir="auto">git reset --hard HEAD</p>
<p dir="auto">will force all the changes to be lost and the repo restored to the last commit<br />
(and allow you to git pull)</p>
]]></description><link>https://forum.magicmirror.builders/post/121582</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121582</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 27 Nov 2024 15:44:46 GMT</pubDate></item><item><title><![CDATA[Reply to Homewizard P1 meter on Wed, 27 Nov 2024 15:14:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a><br />
Currently I’ve installed it with a work-around.</p>
]]></description><link>https://forum.magicmirror.builders/post/121581</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121581</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Wed, 27 Nov 2024 15:14:12 GMT</pubDate></item><item><title><![CDATA[Reply to Homewizard P1 meter on Tue, 26 Nov 2024 17:53:07 GMT]]></title><description><![CDATA[<p dir="auto">I try to install with</p>
<pre><code>git pull https://github.com/Hoaxr/MMM-HomeWizard.git
<p dir="auto">This failes. i got errors</p>
<pre><code>remote: Counting objects: 100% (24/24), done.
remote: Compressing objects: 100% (22/22), done.
remote: Total 24 (delta 6), reused 12 (delta 0), pack-reused 0 (from 0)
Unpacking objects: 100% (24/24), 7.95 KiB | 232.00 KiB/s, done.
From https://github.com/Hoaxr/MMM-HomeWizard
 * branch            HEAD       -&gt; FETCH_HEAD
hint: You have divergent branches and need to specify how to reconcile them.
hint: You can do so by running one of the following commands sometime before
hint: your next pull:
hint:
hint:   git config pull.rebase false  # merge
hint:   git config pull.rebase true   # rebase
hint:   git config pull.ff only       # fast-forward only
hint:
hint: You can replace "git config" with "git config --global" to set a default
hint: preference for all repositories. You can also pass --rebase, --no-rebase,
hint: or --ff-only on the command line to override the configured default per
hint: invocation.
fatal: Need to specify how to reconcile divergent branches.
]]></description><link>https://forum.magicmirror.builders/post/121562</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121562</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Tue, 26 Nov 2024 17:53:07 GMT</pubDate></item><item><title><![CDATA[Reply to Homewizard P1 meter on Wed, 09 Oct 2024 06:33:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vansman" aria-label="Profile: vansman">@<bdi>vansman</bdi></a>  it starts working again. After a few days the information is returned at the screen. No idea why.</p>
]]></description><link>https://forum.magicmirror.builders/post/120504</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120504</guid><dc:creator><![CDATA[vansman]]></dc:creator><pubDate>Wed, 09 Oct 2024 06:33:25 GMT</pubDate></item><item><title><![CDATA[Reply to Homewizard P1 meter on Sat, 05 Oct 2024 08:59:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hoaxr" aria-label="Profile: Hoaxr">@<bdi>Hoaxr</bdi></a> Mine is also stopped working. Try to set the url in whitelist but that seems to do nothing with it.<br />
When copy the url in the browser i get the information on  my screen so the url is right and working at the rasberry.<br />
Only see the header on my mirror no data.</p>
]]></description><link>https://forum.magicmirror.builders/post/120355</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120355</guid><dc:creator><![CDATA[vansman]]></dc:creator><pubDate>Sat, 05 Oct 2024 08:59:07 GMT</pubDate></item><item><title><![CDATA[Reply to Homewizard P1 meter on Wed, 14 Aug 2024 07:50:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ctl073" aria-label="Profile: CTL073">@<bdi>CTL073</bdi></a> still works fine here. Not sure what errors you get?</p>
]]></description><link>https://forum.magicmirror.builders/post/119243</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119243</guid><dc:creator><![CDATA[Hoaxr]]></dc:creator><pubDate>Wed, 14 Aug 2024 07:50:20 GMT</pubDate></item><item><title><![CDATA[Reply to Homewizard P1 meter on Sat, 27 Jul 2024 11:35:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hoaxr" aria-label="Profile: Hoaxr">@<bdi>Hoaxr</bdi></a> Hi, this one stopped working due to various issues. Any possibility to fix this?</p>
]]></description><link>https://forum.magicmirror.builders/post/119004</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119004</guid><dc:creator><![CDATA[CTL073]]></dc:creator><pubDate>Sat, 27 Jul 2024 11:35:59 GMT</pubDate></item><item><title><![CDATA[Reply to Homewizard P1 meter on Tue, 12 Mar 2024 21:25:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hoaxr" aria-label="Profile: Hoaxr">@<bdi>Hoaxr</bdi></a> Thanks! It works.<br />
I added some dataRequest’s in Homewizard.js. (current voltage - total export)</p>
<p dir="auto">What i like to see is a daily use of energy. In the API list i see a timestamp but my coding skills are very low.</p>
<p dir="auto">I also tried to add the data from the watermeter. This data comes from another local ip adres. When adding the dataRequest.active_liter_lpm the display returns a Null number.<br />
So tried add an second ip in config.js but then the first ip is ignored, so all electricity and gas return a Null number. (the value of the watermeter then displayed correct.)<br />
But a nice start that i have some info on my mirror.<br />
Thanks so far</p>
]]></description><link>https://forum.magicmirror.builders/post/116241</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116241</guid><dc:creator><![CDATA[vansman]]></dc:creator><pubDate>Tue, 12 Mar 2024 21:25:04 GMT</pubDate></item><item><title><![CDATA[Reply to Homewizard P1 meter on Wed, 17 Jan 2024 16:17:51 GMT]]></title><description><![CDATA[<p dir="auto">Here you go:<br />
<a href="https://github.com/Hoaxr/MMM-HomeWizard" target="_blank" rel="noopener noreferrer nofollow ugc">Github MMM-HomeWizard</a></p>
<p dir="auto">For now very simple, but it’s something :)</p>
]]></description><link>https://forum.magicmirror.builders/post/114652</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114652</guid><dc:creator><![CDATA[Hoaxr]]></dc:creator><pubDate>Wed, 17 Jan 2024 16:17:51 GMT</pubDate></item><item><title><![CDATA[Reply to Homewizard P1 meter on Wed, 17 Jan 2024 12:22:11 GMT]]></title><description><![CDATA[<p dir="auto">Hi, i just received mine, and i was also search for this.<br />
Yesterday i started to create my first module and it seems to show me data.<br />
I need to make it more clean and add more from the api. But shouldn’t take to long i think. I will keep you posted and will put it on github when i think it’s releasable :p.</p>
<p dir="auto">If you have anything you would like to see let me know so in can see if it’s possible from my end</p>
]]></description><link>https://forum.magicmirror.builders/post/114628</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114628</guid><dc:creator><![CDATA[Hoaxr]]></dc:creator><pubDate>Wed, 17 Jan 2024 12:22:11 GMT</pubDate></item></channel></rss>
