<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New installation but even default is displayed]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I have just installed <code>https://github.com/sdetweil/MagicMirror_scripts</code><br />
MagicMirror2 is booting, I can see the splashscreen but then nothing is displayed. I did not add any module yet, no API-Keys it’s just the new installed MM.<br />
Here is the pm2 log mm</p>
<pre><code>~/MagicMirror $ pm2 log mm
[TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
/home/pi/.pm2/logs/mm-out.log last 15 lines:
1|mm       | [06.01.2024 12:07.46.129] [LOG]   Loading config ...
1|mm       | [06.01.2024 12:07.46.138] [DEBUG] config template file not exists, no envsubst
1|mm       | [06.01.2024 12:07.46.216] [LOG]   Loading module helpers ...
1|mm       | [06.01.2024 12:07.46.255] [LOG]   No helper found for module: alert.
1|mm       | [06.01.2024 12:07.46.750] [LOG]   Initializing new module helper ...
1|mm       | [06.01.2024 12:07.46.752] [LOG]   Module helper loaded: updatenotification
1|mm       | [06.01.2024 12:07.46.815] [LOG]   No helper found for module: clock.
1|mm       | [06.01.2024 12:07.48.676] [LOG]   Initializing new module helper ...
1|mm       | [06.01.2024 12:07.48.678] [LOG]   Module helper loaded: calendar
1|mm       | [06.01.2024 12:07.48.724] [LOG]   No helper found for module: compliments.
1|mm       | [06.01.2024 12:07.48.726] [LOG]   No helper found for module: weather.
1|mm       | [06.01.2024 12:07.49.978] [LOG]   Initializing new module helper ...
1|mm       | [06.01.2024 12:07.49.979] [LOG]   Module helper loaded: newsfeed
1|mm       | [06.01.2024 12:07.49.980] [LOG]   All module helpers loaded.
1|mm       | [06.01.2024 12:07.50.118] [LOG]   Starting server on port 8080 ...
/home/pi/.pm2/logs/mm-error.log last 15 lines:
1|mm       |   errno: -98,
1|mm       |   syscall: 'listen',
1|mm       |   address: '::1',
1|mm       |   port: 8080
1|mm       | }
1|mm       | [06.01.2024 12:07.55.424] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
1|mm       | [06.01.2024 12:07.55.435] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
1|mm       | Warning: vkCreateInstance: Found no drivers!
1|mm       | Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
1|mm       |     at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
1|mm       |     at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
1|mm       |     at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
1|mm       |     at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
1|mm       |     at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
1|mm       |
<p dir="auto">Can anybody tell me what I do not see?</p>
<p dir="auto">Manfred</p>
]]></description><link>https://forum.magicmirror.builders/topic/18348/new-installation-but-even-default-is-displayed</link><generator>RSS for Node</generator><lastBuildDate>Sat, 12 Sep 2026 10:55:15 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18348.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 06 Jan 2024 11:26:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New installation but even default is displayed on Sat, 06 Jan 2024 16:00:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kupperma" aria-label="Profile: kupperma">@<bdi>kupperma</bdi></a> run my backup/restore script… it saves all that and can be loaded up to github and versioned and restored from there</p>
<p dir="auto"><a href="https://github.com/sdetweil/MagicMirror-backup-restore" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror-backup-restore</a></p>
<p dir="auto">it saves links to all the modules and restores from the links</p>
]]></description><link>https://forum.magicmirror.builders/post/114022</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114022</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 06 Jan 2024 16:00:31 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Mon, 22 Jan 2024 18:10:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kupperma" aria-label="Profile: kupperma">@<bdi>kupperma</bdi></a> awesome… thanks for the feedback</p>
]]></description><link>https://forum.magicmirror.builders/post/114834</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114834</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 22 Jan 2024 18:10:12 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Mon, 22 Jan 2024 18:09:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Thank you again.<br />
MM2 is up and running.</p>
]]></description><link>https://forum.magicmirror.builders/post/114833</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114833</guid><dc:creator><![CDATA[kupperma]]></dc:creator><pubDate>Mon, 22 Jan 2024 18:09:15 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Sat, 06 Jan 2024 16:00:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kupperma" aria-label="Profile: kupperma">@<bdi>kupperma</bdi></a> run my backup/restore script… it saves all that and can be loaded up to github and versioned and restored from there</p>
]]></description><link>https://forum.magicmirror.builders/post/114022</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114022</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 06 Jan 2024 16:00:31 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Sat, 06 Jan 2024 15:25:17 GMT]]></title><description><![CDATA[<p dir="auto">I start over!<br />
Thanks for the checklist.<br />
I wont loose much for my custom.css , config.js I have the code copied in a textfile. The modules I would have to reinstall but thats ok.</p>
<p dir="auto">Thank you for your time.<br />
Manfred</p>
]]></description><link>https://forum.magicmirror.builders/post/114021</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114021</guid><dc:creator><![CDATA[kupperma]]></dc:creator><pubDate>Sat, 06 Jan 2024 15:25:17 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Sat, 06 Jan 2024 15:22:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kupperma" aria-label="Profile: kupperma">@<bdi>kupperma</bdi></a> can u reboot? does anything change?  again weird…</p>
<p dir="auto">did you have MM running before? what would you lose starting over?</p>
<p dir="auto">IF you start over,<br />
new flash<br />
boot, skip updates,<br />
reboot turn on ssh</p>
<p dir="auto">then run my install  script… it will update system, install node, then mm…</p>
]]></description><link>https://forum.magicmirror.builders/post/114017</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114017</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 06 Jan 2024 15:22:18 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Sat, 06 Jan 2024 15:17:20 GMT]]></title><description><![CDATA[<p dir="auto">I know what you mean:</p>
<p dir="auto">in an earlier installation I could move the mouse and the menubar got visible or I could press F11 and the menubar got visible. But now nothing works.<br />
So should I reinstall raspian and start from the beginning or is there a work a round?</p>
]]></description><link>https://forum.magicmirror.builders/post/114016</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114016</guid><dc:creator><![CDATA[kupperma]]></dc:creator><pubDate>Sat, 06 Jan 2024 15:17:20 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Sat, 06 Jan 2024 15:15:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kupperma" aria-label="Profile: kupperma">@<bdi>kupperma</bdi></a> ok, on the menu bar there is a terminal window, click that</p>
]]></description><link>https://forum.magicmirror.builders/post/114013</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114013</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 06 Jan 2024 15:15:01 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Sat, 06 Jan 2024 15:14:23 GMT]]></title><description><![CDATA[<p dir="auto">The display does not react to ctrl-alt-t and there is no terminal visible.</p>
]]></description><link>https://forum.magicmirror.builders/post/114012</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114012</guid><dc:creator><![CDATA[kupperma]]></dc:creator><pubDate>Sat, 06 Jan 2024 15:14:23 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Sat, 06 Jan 2024 15:13:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kupperma" aria-label="Profile: kupperma">@<bdi>kupperma</bdi></a> said in <a href="/post/114009">New installation but even default is displayed</a>:</p>
<p dir="auto">Ok this does not work.</p>
<p dir="auto">what does not work?</p>
]]></description><link>https://forum.magicmirror.builders/post/114011</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114011</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 06 Jan 2024 15:13:12 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Tue, 23 Jan 2024 02:19:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kupperma" aria-label="Profile: kupperma">@<bdi>kupperma</bdi></a> I ONLY use SSH to install MM… never use the actual display.</p>
<p dir="auto">have pi 0w, 02w, 3, 4,5 odroid, jetson nano, chromebox, chromebook,<br />
and multiple virtual machines under vmware</p>
<p dir="auto">NEVER seen npm run start say successful but not see it on screen…</p>
<p dir="auto">also, on the screen if u can,<br />
ctrl-c to stop the in ssh version<br />
on screen<br />
cd ~/Magicmirror<br />
npm start</p>
]]></description><link>https://forum.magicmirror.builders/post/114010</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114010</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 23 Jan 2024 02:19:49 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Sat, 06 Jan 2024 15:12:43 GMT]]></title><description><![CDATA[<p dir="auto">Yes I have_<br />
Ok this does not work.<br />
So it seems to be raspianOS failure.</p>
]]></description><link>https://forum.magicmirror.builders/post/114009</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114009</guid><dc:creator><![CDATA[kupperma]]></dc:creator><pubDate>Sat, 06 Jan 2024 15:12:43 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Sat, 06 Jan 2024 15:10:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kupperma" aria-label="Profile: kupperma">@<bdi>kupperma</bdi></a> weird…</p>
<p dir="auto">do you have keyboard to pi system  desktop?</p>
<p dir="auto">if so, ctrl-alt-t to open a terminal window and do</p>
<p dir="auto">echo $DISPLAY</p>
]]></description><link>https://forum.magicmirror.builders/post/114008</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114008</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 06 Jan 2024 15:10:09 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Sat, 06 Jan 2024 15:09:02 GMT]]></title><description><![CDATA[<p dir="auto">This is an pi 3 Model B V1.2<br />
the HDMI is about 2 Centimeters right to the MicroUSB Power input.</p>
<p dir="auto">I updated to raspianOS bookworm first.<br />
Manfred</p>
]]></description><link>https://forum.magicmirror.builders/post/114007</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114007</guid><dc:creator><![CDATA[kupperma]]></dc:creator><pubDate>Sat, 06 Jan 2024 15:09:02 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Sat, 06 Jan 2024 15:05:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kupperma" aria-label="Profile: kupperma">@<bdi>kupperma</bdi></a> which kind of pi?  if Pi 4/5 is the port on the left (closest to power) hdmi port?</p>
]]></description><link>https://forum.magicmirror.builders/post/114006</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114006</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 06 Jan 2024 15:05:30 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Sat, 06 Jan 2024 15:04:08 GMT]]></title><description><![CDATA[<p dir="auto">Sorry forgot to answer:<br />
I am on the raspberrypi over ssh.</p>
<p dir="auto">The Display is connected directly via the HDMI Port of the pi . All equipment is right at arm distance, because I’m setting it up first before staching it behind the actual mirror.<br />
But I am on the pi via ssh so that later I can do updates and probably adding new modules .</p>
]]></description><link>https://forum.magicmirror.builders/post/114005</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114005</guid><dc:creator><![CDATA[kupperma]]></dc:creator><pubDate>Sat, 06 Jan 2024 15:04:08 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Sat, 06 Jan 2024 14:58:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kupperma" aria-label="Profile: kupperma">@<bdi>kupperma</bdi></a> cool… thats good… tell me about the physical  system hookup<br />
where is the physical display?</p>
]]></description><link>https://forum.magicmirror.builders/post/114004</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114004</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 06 Jan 2024 14:58:29 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Sat, 06 Jan 2024 14:57:24 GMT]]></title><description><![CDATA[<p dir="auto">Here is the output:</p>
<pre><code>npm start
&gt; magicmirror@2.26.0 start
&gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
[06.01.2024 15:56.41.020] [LOG]   Starting MagicMirror: v2.26.0
[06.01.2024 15:56.41.030] [LOG]   Loading config ...
[06.01.2024 15:56.41.035] [DEBUG] config template file not exists, no envsubst
[06.01.2024 15:56.41.042] [LOG]   Loading module helpers ...
[06.01.2024 15:56.41.044] [LOG]   No helper found for module: alert.
[06.01.2024 15:56.41.095] [LOG]   Initializing new module helper ...
[06.01.2024 15:56.41.097] [LOG]   Module helper loaded: updatenotification
[06.01.2024 15:56.41.098] [LOG]   No helper found for module: clock.
[06.01.2024 15:56.41.376] [LOG]   Initializing new module helper ...
[06.01.2024 15:56.41.378] [LOG]   Module helper loaded: calendar
[06.01.2024 15:56.41.380] [LOG]   No helper found for module: compliments.
[06.01.2024 15:56.41.381] [LOG]   No helper found for module: weather.
[06.01.2024 15:56.41.580] [LOG]   Initializing new module helper ...
[06.01.2024 15:56.41.581] [LOG]   Module helper loaded: newsfeed
[06.01.2024 15:56.41.581] [LOG]   All module helpers loaded.
[06.01.2024 15:56.41.597] [LOG]   Starting server on port 8080 ...
[06.01.2024 15:56.42.098] [LOG]   Server started ...
[06.01.2024 15:56.42.099] [LOG]   Connecting socket for: updatenotification
[06.01.2024 15:56.42.101] [LOG]   Starting module helper: updatenotification
[06.01.2024 15:56.42.102] [LOG]   Connecting socket for: calendar
[06.01.2024 15:56.42.103] [LOG]   Starting node helper for: calendar
[06.01.2024 15:56.42.104] [LOG]   Connecting socket for: newsfeed
[06.01.2024 15:56.42.105] [LOG]   Starting node helper for: newsfeed
[06.01.2024 15:56.42.106] [LOG]   Sockets connected &amp; modules started ...
[06.01.2024 15:56.42.132] [LOG]   Launching application.
[06.01.2024 15:56.45.490] [LOG]   Create new calendarfetcher for url: https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics - Interval: 604800000
[06.01.2024 15:56.45.911] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
[06.01.2024 15:56.45.924] [INFO]  updatenotification: Updater Class Loaded!
[06.01.2024 15:56.45.926] [INFO]  updatenotification: Checking PM2 using...
[06.01.2024 15:56.45.931] [INFO]  Checking git for module: MagicMirror
[06.01.2024 15:56.47.527] [INFO]  Calendar-Fetcher: Broadcasting 12 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
[06.01.2024 15:56.47.822] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
[06.01.2024 15:56.48.421] [INFO]  updatenotification: You are not using pm2
]]></description><link>https://forum.magicmirror.builders/post/114003</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114003</guid><dc:creator><![CDATA[kupperma]]></dc:creator><pubDate>Sat, 06 Jan 2024 14:57:24 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Sat, 06 Jan 2024 14:55:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kupperma" aria-label="Profile: kupperma">@<bdi>kupperma</bdi></a> where are you doing the pm2 start?</p>
<p dir="auto">on the MM system screen in a terminal window<br />
over ssh<br />
over vnc<br />
???</p>
<p dir="auto">lets try this, without pm2 involved</p>
<pre><code>pm2 stop all
cd ~/MagicMirror
npm start
]]></description><link>https://forum.magicmirror.builders/post/114002</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114002</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 06 Jan 2024 14:55:44 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Sat, 06 Jan 2024 14:53:47 GMT]]></title><description><![CDATA[<p dir="auto">I deleted mm</p>
<p dir="auto">But no, MagicMirror does not appear.<br />
pm2 status looks like that now:</p>
<pre><code>~/MagicMirror $ pm2 status
│ id  │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
│ 0   │ MagicMirror    │ default     │ 2.26.0  │ fork    │ 4369     │ 6m     │ 0    │ online    │ 0%       │ 2.8mb    │ pi       │ disabled │
]]></description><link>https://forum.magicmirror.builders/post/114001</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114001</guid><dc:creator><![CDATA[kupperma]]></dc:creator><pubDate>Sat, 06 Jan 2024 14:53:47 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Sat, 06 Jan 2024 14:50:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kupperma" aria-label="Profile: kupperma">@<bdi>kupperma</bdi></a> and did that bring up MagicMirror?</p>
<p dir="auto">if so,  you can delete the mm  definition</p>
<pre><code>pm2  delete mm
pm2 save
<p dir="auto">watching<br />
the system maybe doesn’t  that support… in my json file I request it</p>
]]></description><link>https://forum.magicmirror.builders/post/114000</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114000</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 06 Jan 2024 14:50:43 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Sat, 06 Jan 2024 14:48:54 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I did what you asked:</p>
<pre><code>pm2 start MagicMirror
[PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
[PM2] [MagicMirror](0) ✓
[PM2] Process successfully started
│ 0   │ MagicMirror    │ default     │ 2.26.0  │ fork    │ 4369     │ 0s     │ 0    │ online    │ 0%       │ 2.8mb    │ pi       │ disabled │
│ 1   │ mm             │ default     │ N/A     │ fork    │ 0        │ 0      │ 1    │ stopped   │ 0%       │ 0b       │ pi       │ disabled │
<p dir="auto">I wonder why “watching” is disabled.</p>
]]></description><link>https://forum.magicmirror.builders/post/113999</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113999</guid><dc:creator><![CDATA[kupperma]]></dc:creator><pubDate>Sat, 06 Jan 2024 14:48:54 GMT</pubDate></item><item><title><![CDATA[Reply to New installation but even default is displayed on Sat, 06 Jan 2024 13:32:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kupperma" aria-label="Profile: kupperma">@<bdi>kupperma</bdi></a> was this a new SD card install?</p>
<p dir="auto">that error means some other app is using port 8080.</p>
<p dir="auto">mm is not the name of my pm2 mm task, so it sounds like you tried the manual  way and it is running too</p>
<pre><code>pm2 status
<p dir="auto">will show the managed apps</p>
]]></description><link>https://forum.magicmirror.builders/post/113994</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113994</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 06 Jan 2024 13:32:33 GMT</pubDate></item></channel></rss>
