<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Issues with MMM-PIR]]></title><description><![CDATA[<p dir="auto">Hi<br />
I’m completely new to this.<br />
I have a Pi 5 on Magicmirror.<br />
I installed MMM-Pir when ir runs the countdown but it displays 2 errors top of screen, pir has no effect countdown expires and turns of the screen.<br />
Unable to recover without rebooting<br />
Errors on screen :<br />
EINVAL: Invalid argument, write<br />
Command failed: /usr/bin/vcgencommand display_power</p>
]]></description><link>https://forum.magicmirror.builders/topic/18372/issues-with-mmm-pir</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 20:30:32 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18372.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 10 Jan 2024 17:55:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Issues with MMM-PIR on Fri, 22 Mar 2024 08:55:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> thank you changing to pir_mode 1 fixed the problem.  Just for awareness I am running on a RPi 3 B+ Rev 1.3 hence why I didn’t do this sooner.</p>
]]></description><link>https://forum.magicmirror.builders/post/116523</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116523</guid><dc:creator><![CDATA[diccon]]></dc:creator><pubDate>Fri, 22 Mar 2024 08:55:26 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with MMM-PIR on Fri, 22 Mar 2024 08:29:29 GMT]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">I am using Bugsounet’s version</p>
<p dir="auto">Thanks for the help</p>
]]></description><link>https://forum.magicmirror.builders/post/116522</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116522</guid><dc:creator><![CDATA[diccon]]></dc:creator><pubDate>Fri, 22 Mar 2024 08:29:29 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with MMM-PIR on Wed, 20 Mar 2024 05:27:51 GMT]]></title><description><![CDATA[<p dir="auto">Hi, check <code>pir_mode</code> feature in readme <a href="https://github.com/bugsounet/MMM-Pir/blob/master/README.md" target="_blank" rel="noopener noreferrer nofollow ugc">readme</a></p>
<p dir="auto">by default <code>pir_mode</code> is on mode 0<br />
With pi 4 and pi 5, you can have <code>EINVAL: invalid argument, write</code> error<br />
In this case<br />
you have to use with pi 4: <code>pir_mode: 1,</code><br />
with pi 5 <code>pir_mode: 2,</code></p>
]]></description><link>https://forum.magicmirror.builders/post/116471</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116471</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Wed, 20 Mar 2024 05:27:51 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with MMM-PIR on Wed, 20 Mar 2024 03:18:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/diccon" aria-label="Profile: diccon">@<bdi>diccon</bdi></a> which MMM-PIR?</p>
]]></description><link>https://forum.magicmirror.builders/post/116467</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116467</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 20 Mar 2024 03:18:06 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with MMM-PIR on Tue, 19 Mar 2024 22:17:53 GMT]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">I have had MMM-Pir module running perfectly for months.  When I updated my RPi 3B+ to the latest updates this week the module produce the same error message</p>
<p dir="auto">Pir Error Detected: EINVAL: invalid argument, write</p>
<p dir="auto">I have tried reinstalling the module but no luck.</p>
<p dir="auto">Any help greatly appreciated</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/116463</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116463</guid><dc:creator><![CDATA[diccon]]></dc:creator><pubDate>Tue, 19 Mar 2024 22:17:53 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with MMM-PIR on Mon, 29 Jan 2024 00:25:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chancetime" aria-label="Profile: ChanceTime">@<bdi>ChanceTime</bdi></a> bookworm on pi4 or 5 uses a different window manager, Wayland,  and requires different commands</p>
<p dir="auto">you can go back to xorg  by using the raspi-config command</p>
]]></description><link>https://forum.magicmirror.builders/post/115102</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/115102</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 29 Jan 2024 00:25:13 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with MMM-PIR on Sun, 28 Jan 2024 23:48:55 GMT]]></title><description><![CDATA[<p dir="auto">Is anyone able to get MMM-PIR successfully running on Bookworm? Feels like every option I’ve tried to turn my screen on and off after the PIR senses movement has been a struggle with no results. I’ve confirmed with tests that my sensor is working, but all the old ways to trigger the display on-off behaviour seem to not be running. I’m on a Pi4 running 12 with Wayland.</p>
<p dir="auto">Unfortunately I can’t go back to 11 because 10 worked like a dream, and 11 for some reason i could never successfully troubleshoot would refuse to load a taskbar in. Hardware seems to be working fine again in 12…</p>
<p dir="auto">I can post my config if it helps. Thanks for the hard work, bugsounet. :)</p>
]]></description><link>https://forum.magicmirror.builders/post/115100</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/115100</guid><dc:creator><![CDATA[ChanceTime]]></dc:creator><pubDate>Sun, 28 Jan 2024 23:48:55 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with MMM-PIR on Fri, 19 Jan 2024 20:07:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schris88" aria-label="Profile: schris88">@<bdi>schris88</bdi></a><br />
Thx for the info, I guess a lot of the modules require reworking for the Pi 5.<br />
Unfortunately I do not have the ability, totally new to the Pi and programming.</p>
]]></description><link>https://forum.magicmirror.builders/post/114734</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114734</guid><dc:creator><![CDATA[eyesallin]]></dc:creator><pubDate>Fri, 19 Jan 2024 20:07:18 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with MMM-PIR on Fri, 19 Jan 2024 09:34:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eyesallin" aria-label="Profile: eyesallin">@<bdi>eyesallin</bdi></a> yes it´s an “issue” with the pi5 as the os is now using wayland as graphical environment instead of x11  which was used forever, a lot of tools are written for it and now need to be updated to work with wayland. You will find a lot of scenarios where there is no updated tool or alternative for the pi5 atm. The switch was done end of 2023 so it´s very new.</p>
]]></description><link>https://forum.magicmirror.builders/post/114727</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114727</guid><dc:creator><![CDATA[schris88]]></dc:creator><pubDate>Fri, 19 Jan 2024 09:34:16 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with MMM-PIR on Thu, 18 Jan 2024 18:43:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eyesallin" aria-label="Profile: eyesallin">@<bdi>eyesallin</bdi></a><br />
I’m beginning to think that all this is Pi 5 related.<br />
Also changing to mode 10 as previously stated screws with the weather modules which don’t load. Remove MMM-PIR from config and everything works fine.<br />
It doesn’t help that I’m completely new to all this.</p>
]]></description><link>https://forum.magicmirror.builders/post/114710</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114710</guid><dc:creator><![CDATA[eyesallin]]></dc:creator><pubDate>Thu, 18 Jan 2024 18:43:05 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with MMM-PIR on Wed, 17 Jan 2024 13:59:37 GMT]]></title><description><![CDATA[<p dir="auto">your config looks good thus far, if you´re not getting it to run you can try my solution which is currently running like a charm</p>
<p dir="auto">I installed it with MMM-Pir-Sensor-light and changed the code to use wayland,<br />
to toggle the display on Pi5 this is working on a fresh OS install</p>
<p dir="auto">WAYLAND_DISPLAY=“wayland-1” wlr-randr --output HDMI-A-1 --off<br />
WAYLAND_DISPLAY=“wayland-1” wlr-randr --output HDMI-A-1 --on</p>
<p dir="auto">possible outputs HDMI-A-1 (the one right next to usb-c), HDMI-A-2</p>
<p dir="auto">If you monitor turns back on by itself after ~10 secs add “vc4.force_hotplug=1”(1=hmdi1 / 2=hdmi2 / 3=both) to the end of your /boot/firmware/cmdline.txt without creating a new line</p>
<p dir="auto">All I did was change the command in activate and deactivate display function in the node_helper.js and added the cmdline parameter (dont forget to reboot)</p>
]]></description><link>https://forum.magicmirror.builders/post/114633</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114633</guid><dc:creator><![CDATA[schris88]]></dc:creator><pubDate>Wed, 17 Jan 2024 13:59:37 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with MMM-PIR on Wed, 17 Jan 2024 09:37:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a></p>
<p dir="auto">Thanks for your patience, this is what i get.</p>
<p dir="auto">admin@garyspi:~ $ groups<br />
admin adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi<br />
admin@garyspi:~ $</p>
]]></description><link>https://forum.magicmirror.builders/post/114626</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114626</guid><dc:creator><![CDATA[eyesallin]]></dc:creator><pubDate>Wed, 17 Jan 2024 09:37:34 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with MMM-PIR on Tue, 16 Jan 2024 18:05:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ingo916" aria-label="Profile: ingo916">@<bdi>ingo916</bdi></a><br />
Config</p>
<pre><code>		{
			module: 'MMM-Pir',
			position: 'top_left',
				debug: false,
				delay: 2 * 60 * 1000,
				turnOffDisplay: true,
				mode: 10,
				ecoMode: true,
				displayCounter: false,
				//displayCounter: true,
				displayBar: false,
				//displayBar: true,
				displayStyle: "Circle",
				displayLastPresence: false,
				//displayLastPresence: true,
				lastPresenceTimeFormat: "LL H:mm",
				mode6_gpio: 20,
				mode6_clearGpioValue: true,
				pir_gpio: 22,
				//pir_gpio: 21,
				pir_reverseValue: false,
				xrandrForceRotation: "normal",
				wrandrForceRotation: "normal"
]]></description><link>https://forum.magicmirror.builders/post/114592</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114592</guid><dc:creator><![CDATA[ingo916]]></dc:creator><pubDate>Tue, 16 Jan 2024 18:05:19 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with MMM-PIR on Tue, 16 Jan 2024 18:02:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ingo916" aria-label="Profile: ingo916">@<bdi>ingo916</bdi></a></p>
<pre><code>pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/bugsounet/MMM-Pir
Cloning into 'MMM-Pir'...
remote: Enumerating objects: 546, done.
remote: Counting objects: 100% (136/136), done.
remote: Compressing objects: 100% (111/111), done.
remote: Total 546 (delta 79), reused 47 (delta 24), pack-reused 410
Receiving objects: 100% (546/546), 287.37 KiB | 2.79 MiB/s, done.
Resolving deltas: 100% (308/308), done.
pi@raspberrypi:~/MagicMirror/modules $ cd MMM-Pir/
pi@raspberrypi:~/MagicMirror/modules/MMM-Pir $ npm install
npm WARN deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
&gt; MMM-Pir@1.1.2 preinstall
&gt; installer/preinstall.sh -d 'unclutter cec-utils ddcutil build-essential'
Welcome to MMM-Pir v1.1.2
No root checking...
Checking MMM-Pir: pi/pi
Checking MagicMirror: pi/pi
Checking OS...
OS Detected: linux-gnu (debian 12 aarch64)
Checking all dependencies...
Updating package...
Missing package: unclutter
Missing package: cec-utils
Missing package: ddcutil
Installing missing package...
Hit:1 http://deb.debian.org/debian bookworm InRelease
Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following additional packages will be installed:
  libcec6 libp8-platform2 unclutter-startup
The following NEW packages will be installed:
  cec-utils ddcutil libcec6 libp8-platform2 unclutter unclutter-startup
0 upgraded, 6 newly installed, 0 to remove and 0 not upgraded.
Need to get 549 kB of archives.
After this operation, 2,084 kB of additional disk space will be used.
Get:1 http://deb.debian.org/debian bookworm/main arm64 libp8-platform2 arm64 2.1.0.1+dfsg1-4 [20.9 kB]
Get:2 http://deb.debian.org/debian bookworm/main arm64 ddcutil arm64 1.4.1-1 [286 kB]
Get:3 http://deb.debian.org/debian bookworm/main arm64 unclutter arm64 8-25 [15.6 kB]
Get:4 http://deb.debian.org/debian bookworm/main arm64 unclutter-startup all 8-25 [8,860 B]
Get:5 http://archive.raspberrypi.com/debian bookworm/main arm64 libcec6 arm64 6.0.2-5+rpt2 [188 kB]
Get:6 http://archive.raspberrypi.com/debian bookworm/main arm64 cec-utils arm64 6.0.2-5+rpt2 [30.0 kB]
Fetched 549 kB in 1s (469 kB/s)
Preconfiguring packages ...
Selecting previously unselected package libp8-platform2:arm64.
(Reading database ... 154590 files and directories currently installed.)
Preparing to unpack .../0-libp8-platform2_2.1.0.1+dfsg1-4_arm64.deb ...
Unpacking libp8-platform2:arm64 (2.1.0.1+dfsg1-4) ...
Selecting previously unselected package libcec6:arm64.
Preparing to unpack .../1-libcec6_6.0.2-5+rpt2_arm64.deb ...
Unpacking libcec6:arm64 (6.0.2-5+rpt2) ...
Selecting previously unselected package cec-utils.
Preparing to unpack .../2-cec-utils_6.0.2-5+rpt2_arm64.deb ...
Unpacking cec-utils (6.0.2-5+rpt2) ...
Selecting previously unselected package ddcutil.
Preparing to unpack .../3-ddcutil_1.4.1-1_arm64.deb ...
Unpacking ddcutil (1.4.1-1) ...
Selecting previously unselected package unclutter.
Preparing to unpack .../4-unclutter_8-25_arm64.deb ...
Unpacking unclutter (8-25) ...
Selecting previously unselected package unclutter-startup.
Preparing to unpack .../5-unclutter-startup_8-25_all.deb ...
Unpacking unclutter-startup (8-25) ...
Setting up libp8-platform2:arm64 (2.1.0.1+dfsg1-4) ...
Setting up unclutter (8-25) ...
update-alternatives: using /usr/bin/unclutter-classic to provide /usr/bin/unclutter (unclutter) in auto mode
Setting up libcec6:arm64 (6.0.2-5+rpt2) ...
Setting up unclutter-startup (8-25) ...
Setting up ddcutil (1.4.1-1) ...
Setting up cec-utils (6.0.2-5+rpt2) ...
Processing triggers for man-db (2.11.2-2) ...
Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ...
All Dependencies needed are installed !
Installing @sdetweil sandbox fix...
fixing sandbox permissions
&gt; MMM-Pir@1.1.2 postinstall
&gt; installer/postinstall.sh -r -m
Minify Main code...
Found: 8 files to minify
Process File: ../MMM-Pir.js
Process File: ../node_helper.js
Process File: ../components/screenLib.js
Process File: ../components/screenDisplayer.js
Process File: ../components/progressbar.js
Process File: ../components/pirLib.js
Process File: ../components/parseData.js
Process File: ../components/loadLibraries.js
Done
Try to Disable screen saver...
Found: screen saver in gsettings
gsettings screen saver already disabled
Found: screen saver in lightdm
screensaver via lightdm already disabled but need to be updated
Found: screen saver in lxsession
lxsession screen saver already disabled but need to updated
Found: screen saver in wayland
disable screensaver via wayfire.ini
[WARN] There is some change for disable screen saver
[WARN] Please, don't forget to reboot your OS for apply the new configuration!
Done
Rebuild MagicMirror...
make: Entering directory '/home/pi/MagicMirror/modules/MMM-Pir/node_modules/epoll/build'
  CXX(target) Release/obj.target/epoll/src/epoll.o
  SOLINK_MODULE(target) Release/obj.target/epoll.node
  COPY Release/epoll.node
make: Leaving directory '/home/pi/MagicMirror/modules/MMM-Pir/node_modules/epoll/build'
Done
MMM-Pir is now installed !
added 218 packages in 53s
43 packages are looking for funding
  run `npm fund` for details
]]></description><link>https://forum.magicmirror.builders/post/114594</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114594</guid><dc:creator><![CDATA[ingo916]]></dc:creator><pubDate>Tue, 16 Jan 2024 18:02:09 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with MMM-PIR on Tue, 16 Jan 2024 17:57:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> said in <a href="/post/114562">Issues with MMM-PIR</a>:</p>
<p dir="auto">groups</p>
<p dir="auto">I am also getting the error<br />
MMM-Pir<br />
Error detected: EINVAL:invalid argument, write</p>
<p dir="auto">pi@raspberrypi:~ $ groups<br />
pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi<br />
pi@raspberrypi:~ $<br />
<img src="error" alt="IMG_013.jpg" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1705427868639-img_0130-resized.jpg" alt="IMG_0130.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/114591</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114591</guid><dc:creator><![CDATA[ingo916]]></dc:creator><pubDate>Tue, 16 Jan 2024 17:57:57 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with MMM-PIR on Tue, 16 Jan 2024 12:14:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eyesallin" aria-label="Profile: eyesallin">@<bdi>eyesallin</bdi></a></p>
<p dir="auto">like that:</p>
<pre><code>pi@raspberrypi:~ $ groups
pi@raspberrypi:~ $
<p dir="auto">I have to see if you are in gpio group :)</p>
]]></description><link>https://forum.magicmirror.builders/post/114562</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114562</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Tue, 16 Jan 2024 12:14:16 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with MMM-PIR on Tue, 16 Jan 2024 10:46:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a>  Apologies but I don’t understand what you are asking for?</p>
]]></description><link>https://forum.magicmirror.builders/post/114560</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114560</guid><dc:creator><![CDATA[eyesallin]]></dc:creator><pubDate>Tue, 16 Jan 2024 10:46:02 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with MMM-PIR on Mon, 15 Jan 2024 21:21:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eyesallin" aria-label="Profile: eyesallin">@<bdi>eyesallin</bdi></a> hi, eventually can I have the result of this commands in a terminal:</p>
<pre><code>groups
<p dir="auto">thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/114541</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114541</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Mon, 15 Jan 2024 21:21:08 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with MMM-PIR on Thu, 11 Jan 2024 08:36:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eyesallin" aria-label="Profile: eyesallin">@<bdi>eyesallin</bdi></a></p>
<p dir="auto">50% unfortunately the top error is still there, any other help would be appreciated.<br />
EINVAL: Invalid argument, write.</p>
]]></description><link>https://forum.magicmirror.builders/post/114337</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114337</guid><dc:creator><![CDATA[eyesallin]]></dc:creator><pubDate>Thu, 11 Jan 2024 08:36:54 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with MMM-PIR on Wed, 10 Jan 2024 23:25:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Many thanks I’ll give it a try. Will report back.</p>
]]></description><link>https://forum.magicmirror.builders/post/114324</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114324</guid><dc:creator><![CDATA[eyesallin]]></dc:creator><pubDate>Wed, 10 Jan 2024 23:25:20 GMT</pubDate></item><item><title><![CDATA[Reply to Issues with MMM-PIR on Wed, 10 Jan 2024 19:17:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eyesallin" aria-label="Profile: eyesallin">@<bdi>eyesallin</bdi></a> on pi5 by default you have to use mode 10, as Wayland is the display manager</p>
]]></description><link>https://forum.magicmirror.builders/post/114314</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114314</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 10 Jan 2024 19:17:04 GMT</pubDate></item></channel></rss>
