<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Default Calendar Module not showing some recurring events.]]></title><description><![CDATA[<p dir="auto">Hello,<br />
Building my first Magic Mirror as calendar for my family and just about done but have been banging my head for a couple days on a particular issue with the default calendar module not showing all my recurring events. What is strange is that it shows  them in past events and in events past the first of the next month but none between now and the end of the month of January (even some in series with ones showing in the past or more distant future). Searched the forums and haven’t found any with this issue yet so looking for some help. Thanks in advance!</p>
<p dir="auto">Below is my calendar config, i have a copy of my ical pulled from icloud locally in a folder under my modules folder.</p>
<pre><code> {
                //      header: "US Holidays",
                                maximumNumberOfDays: 120,
                                maximumEntries: 100,
                                wrapEvents: true,
                                                symbol: "calendar-check",
                                                url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics",
                                                color: "red"
                                                symbol: "calendar",
                                                url: "http://0.0.0.0:8080/modules/calendars/familycal.ics",
                                                color: "blue"
                                broadcastPastEvents: true,
<p dir="auto">Below is a sample of one of the events in question from the ics file, but all recurring that fall in the period are exhibiting this. From this recurring event it just shows the entries for the following dates Jan 9, Jan 11, Feb 1,Feb 6… and is missing the ones that should be on Jan 16, Jan 18, Jan 23, Jan 25 and Jan 30:</p>
<pre><code>BEGIN:VEVENT
CREATED:20240113T055021Z
DTEND;TZID=America/New_York:20240109T090000
DTSTAMP:20240113T055022Z
DTSTART;TZID=America/New_York:20240109T080000
LAST-MODIFIED:20240113T055021Z
RRULE:FREQ=WEEKLY;UNTIL=20240627T120000Z;BYDAY=TU,TH
SEQUENCE:0
SUMMARY:Band Practice
UID:868DEEF9-5FA2-4AFB-A9AC-AA1A28120F1E
URL;VALUE=URI:
X-APPLE-CREATOR-IDENTITY:com.apple.mobilecal
X-APPLE-CREATOR-TEAM-IDENTITY:0000000000
TRANSP:OPAQUE
END:VEVENT
<p dir="auto">Thanks again.</p>
]]></description><link>https://forum.magicmirror.builders/topic/18388/default-calendar-module-not-showing-some-recurring-events</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 09:56:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18388.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 13 Jan 2024 16:26:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Default Calendar Module not showing some recurring events. on Wed, 13 Mar 2024 15:51:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/114437">Default Calendar Module not showing some recurring events.</a>:</p>
<p dir="auto">npm install node-ical@0.16.1</p>
<p dir="auto">That did the trick, been scratching my head for a while.<br />
Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/116258</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116258</guid><dc:creator><![CDATA[johanPO]]></dc:creator><pubDate>Wed, 13 Mar 2024 15:51:31 GMT</pubDate></item><item><title><![CDATA[Reply to Default Calendar Module not showing some recurring events. on Wed, 17 Jan 2024 02:56:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Thank you so much for that!! I haven’t deployed my mirror yet, I just have it running headless with a remote screen that I check every few days to make sure things are still looking good. I noticed the other day that some of the recurring events weren’t full day events disappeared. I was convinced that I had screwed something up on the config side. It took spinning up a duplicate system as a test using default config with just my calendars to realize that the issue wasn’t on my side.</p>
<p dir="auto">I also ran the rollback, and everything is  solid once again.</p>
]]></description><link>https://forum.magicmirror.builders/post/114613</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114613</guid><dc:creator><![CDATA[ZiggidyZ]]></dc:creator><pubDate>Wed, 17 Jan 2024 02:56:51 GMT</pubDate></item><item><title><![CDATA[Reply to Default Calendar Module not showing some recurring events. on Sat, 13 Jan 2024 19:17:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  Thanks so much for this and the quick response, it did the trick to get the events showing which is more important to me at this point than the times being 100% correct, and I have not yet found one of mine that seems to be off on that issue yet.  Hopefully soon all issues can be resolved on this but I know how difficult working with dates and times can be.<br />
Relavant xkcd: <a href="https://xkcd.com/2867/" target="_blank" rel="noopener noreferrer nofollow ugc">DateTime</a></p>
]]></description><link>https://forum.magicmirror.builders/post/114440</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114440</guid><dc:creator><![CDATA[schubs]]></dc:creator><pubDate>Sat, 13 Jan 2024 19:17:51 GMT</pubDate></item><item><title><![CDATA[Reply to Default Calendar Module not showing some recurring events. on Sat, 13 Jan 2024 18:15:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schubs" aria-label="Profile: schubs">@<bdi>schubs</bdi></a> yes, we are having trouble with the new rrule library used by the calendar ICS parser</p>
<p dir="auto">let’s try to go back to the prior version (which also has trouble getting the time correctly)</p>
<pre><code class="language-bash">cd ~/MagicMirror
<p dir="auto">then restart MagicMirror</p>
]]></description><link>https://forum.magicmirror.builders/post/114437</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114437</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 13 Jan 2024 18:15:08 GMT</pubDate></item></channel></rss>
