<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-CalendarExt3Agenda no longer working after MM update]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I installed the new version of MM and now this module isn’t working properly.  I get some data but not much.  I do see a notification that there’s an update, but when I run <strong>git pull</strong> and <strong>npm install</strong>, it gives me a warning about committing changes for a json file and then says aborted.  (not sure if that’s important or not).</p>
<pre><code></code></pre>
<p dir="auto">Updating d1d25b3…e0adcbf<br />
error: Your local changes to the following files would be overwritten by merge:<br />
package-lock.json<br />
Please commit your changes or stash them before you merge.<br />
Aborting</p>
<p dir="auto">up to date, audited 1 package in 2s</p>
<p dir="auto">When I run MM, the calendar info shows but only a few items and doesn’t grab all the calendars in the list.</p>
<p dir="auto">Anyone know why this might not be working and how I update it properly if that’s the issue?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/18397/mmm-calendarext3agenda-no-longer-working-after-mm-update</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 03:22:46 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18397.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 14 Jan 2024 21:09:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda no longer working after MM update on Tue, 16 Jan 2024 07:35:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kelemvor" aria-label="Profile: Kelemvor">@<bdi>Kelemvor</bdi></a><br />
1.4.2 is the latest version.</p>
]]></description><link>https://forum.magicmirror.builders/post/114551</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114551</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Tue, 16 Jan 2024 07:35:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda no longer working after MM update on Mon, 15 Jan 2024 23:13:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a> Hi.  The version in Packages.json is 1.4.1.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/post/114546</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114546</guid><dc:creator><![CDATA[Kelemvor]]></dc:creator><pubDate>Mon, 15 Jan 2024 23:13:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda no longer working after MM update on Mon, 15 Jan 2024 01:01:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kelemvor" aria-label="Profile: Kelemvor">@<bdi>Kelemvor</bdi></a><br />
Go to directory of CX3A then open the package.json. Could u check the version number?</p>
]]></description><link>https://forum.magicmirror.builders/post/114496</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114496</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Mon, 15 Jan 2024 01:01:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda no longer working after MM update on Mon, 15 Jan 2024 00:36:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kelemvor" aria-label="Profile: Kelemvor">@<bdi>Kelemvor</bdi></a> I don’t know on his modules</p>
]]></description><link>https://forum.magicmirror.builders/post/114495</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114495</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 15 Jan 2024 00:36:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda no longer working after MM update on Sun, 14 Jan 2024 23:58:28 GMT]]></title><description><![CDATA[<p dir="auto">THe vk thing doesn’t seem to be affecting anything so I’ll make a new thread about that if somethign comes up.</p>
<p dir="auto">MM is still telling me that there’s an update available for CalendarExt3Agenda.</p>
<p dir="auto">I previously ran:</p>
<pre><code>cd ~/MagicMirror/modules/MMM-CalendarExt3Agenda
git pull
npm update
<p dir="auto">But it still tells me there’s an update.  Is there some other command I need to run?  I ran it before running the commands you pasted in above so maybe I just need to run these commands again?</p>
]]></description><link>https://forum.magicmirror.builders/post/114493</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114493</guid><dc:creator><![CDATA[Kelemvor]]></dc:creator><pubDate>Sun, 14 Jan 2024 23:58:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda no longer working after MM update on Sun, 14 Jan 2024 23:12:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kelemvor" aria-label="Profile: Kelemvor">@<bdi>Kelemvor</bdi></a> generally there is an error further up for the vkCreateInstance problem…</p>
<p dir="auto">you can also try a newer version of electron</p>
npm install electron@28.1.1
]]></description><link>https://forum.magicmirror.builders/post/114482</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114482</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 14 Jan 2024 23:12:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda no longer working after MM update on Sun, 14 Jan 2024 22:35:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks!</p>
<p dir="auto">I ran that and it seemed to fix the problem.  It still tells me there’s an update for Ext3Agenta.  Do I now need to run the Upgrade commands from Git again?</p>
git pull
npm update
<p dir="auto">Also, at the end of everything loading I see this.  Not sure what it means or if it’s important or not.<br />
<img src="/assets/uploads/files/1705271679893-b63ab704-e615-4b9d-ae09-6c95ccc0bb16-image.png" alt="b63ab704-e615-4b9d-ae09-6c95ccc0bb16-image.png" class="img-markdown  img-fluid" /></p>
<p dir="auto">Thoughts?</p>
]]></description><link>https://forum.magicmirror.builders/post/114480</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114480</guid><dc:creator><![CDATA[Kelemvor]]></dc:creator><pubDate>Sun, 14 Jan 2024 22:35:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda no longer working after MM update on Sun, 14 Jan 2024 21:54:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kelemvor" aria-label="Profile: Kelemvor">@<bdi>Kelemvor</bdi></a> do</p>
git checkout package-lock.json
git pull
npm run install-mm
npm install node-ical@0.16.1
]]></description><link>https://forum.magicmirror.builders/post/114477</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114477</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 14 Jan 2024 21:54:24 GMT</pubDate></item></channel></rss>
