<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem after MM-upgrade]]></title><description><![CDATA[<p dir="auto">I just did an upgrade and got the following message:</p>
<p dir="auto">pi@raspberrypi:~/MagicMirror $ npm start</p>
<p dir="auto">magicmirror@2.26.0 start<br />
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js</p>
<p dir="auto">[16.01.2024 19:51.34.090] [LOG]   Starting MagicMirror: v2.26.0<br />
[16.01.2024 19:51.34.111] [LOG]   Loading config …<br />
[16.01.2024 19:51.34.120] [DEBUG] config template file not exists, no envsubst<br />
[16.01.2024 19:51.34.133] [LOG]   Loading module helpers …<br />
[16.01.2024 19:51.34.145] [LOG]   No helper found for module: alert.<br />
[16.01.2024 19:51.34.204] [ERROR] (node:29116) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘command-exists’<br />
Require stack:</p>
<ul>
<li>/home/pi/MagicMirror/modules/default/updatenotification/update_helper.js</li>
<li>/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js</li>
<li>/home/pi/MagicMirror/js/app.js</li>
<li>/home/pi/MagicMirror/js/electron.js</li>
<li>/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js</li>
<li>at Module._resolveFilename (node:internal/modules/cjs/loader:1082:15)<br />
at n._resolveFilename (node:electron/js2c/browser_init:2:117457)<br />
at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)<br />
at Module._load (node:internal/modules/cjs/loader:927:27)<br />
at f._load (node:electron/js2c/asar_bundle:2:13330)<br />
at Module.require (node:internal/modules/cjs/loader:1148:19)<br />
at require (node:internal/modules/cjs/helpers:110:18)<br />
at Object. (/home/pi/MagicMirror/modules/default/updatenotification/update_helper.js:3:23)<br />
at Module._compile (node:internal/modules/cjs/loader:1269:14)<br />
at Module._extensions…js (node:internal/modules/cjs/loader:1324:10)<br />
at Module.load (node:internal/modules/cjs/loader:1124:32)<br />
at Module._load (node:internal/modules/cjs/loader:965:12)<br />
at Object. (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:4:22)<br />
(Use <code>electron --trace-warnings ...</code> to show where the warning was created)<br />
[16.01.2024 19:51.34.206] [ERROR] (node:29116) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag <code>--unhandled-rejections=strict</code> (see <a href="https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode" target="_blank" rel="noopener noreferrer nofollow ugc">https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode</a>). (rejection id: 1)<br />
^C/home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT</li>
</ul>
<p dir="auto">I appreciate all help. THANKS !!!</p>
]]></description><link>https://forum.magicmirror.builders/topic/18405/problem-after-mm-upgrade</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Jul 2026 20:03:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18405.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 16 Jan 2024 19:05:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem after MM-upgrade on Tue, 16 Jan 2024 19:45:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clla1972" aria-label="Profile: CLLA1972">@<bdi>CLLA1972</bdi></a> said in <a href="/post/114599">Problem after MM-upgrade</a>:</p>
<p dir="auto">(I am not an expert on this)</p>
<p dir="auto">no problem… do this</p>
<p dir="auto">stop mm</p>
<pre><code>cd ~/MagicMirror
npm run install-mm
<p dir="auto">then restart MM</p>
]]></description><link>https://forum.magicmirror.builders/post/114600</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114600</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 16 Jan 2024 19:45:44 GMT</pubDate></item><item><title><![CDATA[Reply to Problem after MM-upgrade on Tue, 16 Jan 2024 19:19:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clla1972" aria-label="Profile: CLLA1972">@<bdi>CLLA1972</bdi></a> (I am not an expert on this)</p>
]]></description><link>https://forum.magicmirror.builders/post/114599</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114599</guid><dc:creator><![CDATA[CLLA1972]]></dc:creator><pubDate>Tue, 16 Jan 2024 19:19:17 GMT</pubDate></item><item><title><![CDATA[Reply to Problem after MM-upgrade on Tue, 16 Jan 2024 19:19:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> This?</p>
<p dir="auto">pi@raspberrypi:~/MagicMirror $ git status<br />
På grenen master<br />
Din gren är à jour med “origin/master”.</p>
<p dir="auto">Ospårade filer:<br />
(använd “git add …” för att ta med i det som ska checkas in)<br />
custom.css<br />
nohup.out</p>
<p dir="auto">inget köat för incheckning, men ospårade filer finns (spåra med “git add”)</p>
]]></description><link>https://forum.magicmirror.builders/post/114598</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114598</guid><dc:creator><![CDATA[CLLA1972]]></dc:creator><pubDate>Tue, 16 Jan 2024 19:19:04 GMT</pubDate></item><item><title><![CDATA[Reply to Problem after MM-upgrade on Tue, 16 Jan 2024 19:15:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clla1972" aria-label="Profile: CLLA1972">@<bdi>CLLA1972</bdi></a> said in <a href="/post/114595">Problem after MM-upgrade</a>:</p>
<p dir="auto">Cannot find module ‘command-exists’</p>
<p dir="auto">the<br />
npm run install_mm<br />
did not run</p>
<p dir="auto">I hate the pull &amp;&amp; npm …  if one fails the other doesn’t run, and you have no idea what is supposed to happen anyhow…</p>
<p dir="auto">please show the output of git status</p>
<p dir="auto">thats why I made the upgrade script<br />
see<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/114597</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114597</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 16 Jan 2024 19:15:15 GMT</pubDate></item></channel></rss>
