<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Displaying two calendars in the standard calendar in one list]]></title><description><![CDATA[<p dir="auto">I would like to display two Google calendars in the default calendar. However, both calendar should be displayed in one list on the mirror.</p>
<p dir="auto">I try to realize it with the following config</p>
<pre><code>                       module: "calendar",
                        header: "Termine",
                                timeFormat: 'absolute',
                                maximumEntries: 10,
                                dateFormat: 'ddd DD MMM HH:mm',
                                fullDayEventDateFormat: 'ddd DD MMM',
                                showEnd: false,
                                urgency: 0,
                                getRelative: 0,
                                                symbol: "calendar-check",
                                                url: "https://calendar.google.com/calendar/ical/******/basic.ics"
<p dir="auto">But when the MMM starts the module first shows the first configured URL and a few seconds later the module only shows the appointments from the second URL.</p>
<p dir="auto">But as I wrote I need the entries from both calendars in one list.</p>
<p dir="auto">Please can you help me.</p>
<p dir="auto">Thank you in advance.<br />
Lars</p>
]]></description><link>https://forum.magicmirror.builders/topic/18408/displaying-two-calendars-in-the-standard-calendar-in-one-list</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 03:27:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18408.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 17 Jan 2024 09:32:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Displaying two calendars in the standard calendar in one list on Wed, 17 Jan 2024 22:08:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lif" aria-label="Profile: lif">@<bdi>lif</bdi></a></p>
<p dir="auto">Thanks, that worked.</p>
]]></description><link>https://forum.magicmirror.builders/post/114689</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114689</guid><dc:creator><![CDATA[lif]]></dc:creator><pubDate>Wed, 17 Jan 2024 22:08:43 GMT</pubDate></item><item><title><![CDATA[Reply to Displaying two calendars in the standard calendar in one list on Wed, 17 Jan 2024 21:37:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lif" aria-label="Profile: lif">@<bdi>lif</bdi></a> can you do this<br />
<a href="https://forum.magicmirror.builders/post/114622">https://forum.magicmirror.builders/post/114622</a></p>
]]></description><link>https://forum.magicmirror.builders/post/114688</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114688</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 17 Jan 2024 21:37:56 GMT</pubDate></item><item><title><![CDATA[Reply to Displaying two calendars in the standard calendar in one list on Wed, 17 Jan 2024 20:32:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klinge" aria-label="Profile: Klinge">@<bdi>Klinge</bdi></a></p>
<p dir="auto">I typed too soon, just after I posted that I applied a MagicMirror upgrade, now it doesn’t display my personal calendar.</p>
]]></description><link>https://forum.magicmirror.builders/post/114687</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114687</guid><dc:creator><![CDATA[lif]]></dc:creator><pubDate>Wed, 17 Jan 2024 20:32:01 GMT</pubDate></item><item><title><![CDATA[Reply to Displaying two calendars in the standard calendar in one list on Wed, 17 Jan 2024 13:27:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> That´s it. Now it works. Thank you for your help again.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bdream" aria-label="Profile: bdream">@<bdi>bdream</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/lif" aria-label="Profile: lif">@<bdi>lif</bdi></a> Thank you for your support as well.</p>
]]></description><link>https://forum.magicmirror.builders/post/114630</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114630</guid><dc:creator><![CDATA[Klinge]]></dc:creator><pubDate>Wed, 17 Jan 2024 13:27:19 GMT</pubDate></item><item><title><![CDATA[Reply to Displaying two calendars in the standard calendar in one list on Wed, 17 Jan 2024 12:44:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klinge" aria-label="Profile: Klinge">@<bdi>Klinge</bdi></a> fall back to the prior calendar parser</p>
<pre><code>cd ~/MagicMirror
npm install node-ical@0.16.1
<p dir="auto">restart mm</p>
<p dir="auto">your config looks ok</p>
]]></description><link>https://forum.magicmirror.builders/post/114622</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114622</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 17 Jan 2024 12:44:56 GMT</pubDate></item><item><title><![CDATA[Reply to Displaying two calendars in the standard calendar in one list on Wed, 17 Jan 2024 10:32:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bdream" aria-label="Profile: bdream">@<bdi>bdream</bdi></a> Thank you for you answer. Now I delete the second fetch line. So my config is</p>
<pre><code>module: "calendar",
                        header: "Termine",
                                maximumEntries: 10,
                                showEnd: false,
                                urgency: 0,
                                getRelative: 0,
<p dir="auto">But now it’s getting really crazy. The mirror shows me an appointment at 12.20pm today as the first entry. That’s also correct. But after that it only shows me from both calendars all-day appointments. It no longer shows appointments that start at a certain time, for example at 1 pm.</p>
<p dir="auto">Why are only all-day appointments displayed?</p>
]]></description><link>https://forum.magicmirror.builders/post/114621</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114621</guid><dc:creator><![CDATA[Klinge]]></dc:creator><pubDate>Wed, 17 Jan 2024 10:32:19 GMT</pubDate></item><item><title><![CDATA[Reply to Displaying two calendars in the standard calendar in one list on Wed, 17 Jan 2024 10:25:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klinge" aria-label="Profile: Klinge">@<bdi>Klinge</bdi></a></p>
<p dir="auto">I use this to display 3 calendars in the same column</p>
<p dir="auto">{<br />
module: “calendar”,<br />
header: “Our Calendar”,<br />
position: “top_left”,<br />
config: {<br />
calendars: [<br />
{<br />
fetchInterval: 7 * 24 * 60 * 60 * 1000,<br />
symbol: “calendar-check”,<br />
url: ‘<a href="https://calendar.google.com/calendar/ical/en.uk%23holiday%40group.v.calendar.google.com/public/basic.ics" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/ical/en.uk%23holiday%40group.v.calendar.google.com/public/basic.ics</a>’,<br />
},</p>
color: ‘#FFFF00’,<br />
symbol: “calendar”,<br />
url: ‘<a href="https://calendar.google.com/calendar/ical/fr.french%23holiday%40group.v.calendar.google.com/public/basic.ics" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/ical/fr.french%23holiday%40group.v.calendar.google.com/public/basic.ics</a>’,<br />
},<br />
{<br />
color: ‘#00FF00’,<br />
url: ‘<a href="https://calendar.google.com/calendar/ical/xxxx%40gmail.com/private-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/basic.ics" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/ical/xxxx%40gmail.com/private-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/basic.ics</a>’,</p>
<pre><code>                                    },
]]></description><link>https://forum.magicmirror.builders/post/114627</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114627</guid><dc:creator><![CDATA[lif]]></dc:creator><pubDate>Wed, 17 Jan 2024 10:25:50 GMT</pubDate></item><item><title><![CDATA[Reply to Displaying two calendars in the standard calendar in one list on Wed, 17 Jan 2024 09:53:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klinge" aria-label="Profile: Klinge">@<bdi>Klinge</bdi></a> I have a configuration as you but the  <code>fetchInterval:</code><br />
May it help butting this up to the config-part as:</p>
<pre><code>config: {
]]></description><link>https://forum.magicmirror.builders/post/114619</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114619</guid><dc:creator><![CDATA[bdream]]></dc:creator><pubDate>Wed, 17 Jan 2024 09:53:20 GMT</pubDate></item></channel></rss>
