<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-CalendarExt3Agenda Split]]></title><description><![CDATA[<p dir="auto">Hall together,</p>
<p dir="auto">the entry is not a mistake but rather a query about the module.</p>
<p dir="auto">I use the following two modules and am quite satisfied so far.</p>
<p dir="auto"><a href="https://github.com/MMRIZE/MMM-CalendarExt3Agenda" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MMRIZE/MMM-CalendarExt3Agenda</a><br />
<a href="https://github.com/MMRIZE/MMM-CalendarExt3/tree/main" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MMRIZE/MMM-CalendarExt3/tree/main</a></p>
<p dir="auto">But now I would like to completely hide or remove the upper calendar area in MMM-CalendarExt3Agenda so that I really only have the agenda.<br />
In which file do I have to adjust which lines to display only the lower section?</p>
<p dir="auto">And while we’re at it…<br />
Do you have a link or a forum entry for me in which it is described for dummies how I can enter my calendar entries in such a nice color that the “Gelber Sack” with symbol is displayed in yellow?</p>
<p dir="auto">Many thanks in advance and best regards<br />
Sven</p>
]]></description><link>https://forum.magicmirror.builders/topic/18411/mmm-calendarext3agenda-split</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 16:41:24 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18411.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 17 Jan 2024 13:27:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda Split on Thu, 18 Jan 2024 20:23:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/svenpisa" aria-label="Profile: svenpisa">@<bdi>svenpisa</bdi></a><br />
<a href="https://github.com/MMRIZE/MMM-CalendarExt3/wiki/Examples-%26-Tips" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MMRIZE/MMM-CalendarExt3/wiki/Examples-%26-Tips</a></p>
]]></description><link>https://forum.magicmirror.builders/post/114717</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114717</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Thu, 18 Jan 2024 20:23:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda Split on Thu, 18 Jan 2024 20:22:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> And now i found it.</p>
<pre><code>hiddenOnStartup: "True",
<p dir="auto">and everything is fine… ;-)</p>
]]></description><link>https://forum.magicmirror.builders/post/114718</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114718</guid><dc:creator><![CDATA[svenpisa]]></dc:creator><pubDate>Thu, 18 Jan 2024 20:22:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda Split on Thu, 18 Jan 2024 20:14:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/svenpisa" aria-label="Profile: svenpisa">@<bdi>svenpisa</bdi></a> no. the calendar module reads the events and broadcasts them as notifications, and the Ext3 modules receive the notifications.</p>
<p dir="auto">with position commented out on the default calendar module, only it’s output does not display</p>
]]></description><link>https://forum.magicmirror.builders/post/114716</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114716</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 18 Jan 2024 20:14:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda Split on Thu, 18 Jan 2024 20:11:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> sorry, one more question. If I comment out the position, I no longer have access to the URL from the calendar module and therefore no more entries in EXT3 and EXT3Agenda…</p>
]]></description><link>https://forum.magicmirror.builders/post/114715</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114715</guid><dc:creator><![CDATA[svenpisa]]></dc:creator><pubDate>Thu, 18 Jan 2024 20:11:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda Split on Thu, 18 Jan 2024 20:01:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> great. Thanks a lot!!! That’s it. You can close the post. Because of the color i have to read some more posts i think. If i would find no solution i will make a new post. Thank you guys!!!</p>
]]></description><link>https://forum.magicmirror.builders/post/114714</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114714</guid><dc:creator><![CDATA[svenpisa]]></dc:creator><pubDate>Thu, 18 Jan 2024 20:01:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda Split on Thu, 18 Jan 2024 19:21:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/svenpisa" aria-label="Profile: svenpisa">@<bdi>svenpisa</bdi></a> all the Ext3 modules depend on the default calendar. but you can  not show the default calendar output, by commenting out it’s position choice, by adding // to that line</p>
<p dir="auto">//position:</p>
]]></description><link>https://forum.magicmirror.builders/post/114712</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114712</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 18 Jan 2024 19:21:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda Split on Thu, 18 Jan 2024 19:02:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a> thanks a lot for your fast answer.</p>
<p dir="auto">Hiding worked really well. I could have figured it out myself.  :-(</p>
<p dir="auto">I’ll have to read up on the color again. But I noticed that CalendarExt3 and Ext3Agenda as well as other modules have a dependency on “calendar”. Can you tell me how I can keep the module in Config.js but not display it so that the dependencies remain?<br />
Oh and sorry, with the color to Calendar I actually meant the colors of the calendar entries in your MMM modules Ext3.</p>
<p dir="auto">Have a nice evening<br />
Sven</p>
]]></description><link>https://forum.magicmirror.builders/post/114711</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114711</guid><dc:creator><![CDATA[svenpisa]]></dc:creator><pubDate>Thu, 18 Jan 2024 19:02:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda Split on Thu, 18 Jan 2024 07:47:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/svenpisa" aria-label="Profile: svenpisa">@<bdi>svenpisa</bdi></a><br />
1.<br />
<img src="/assets/uploads/files/1705563880384-5a095d34-36b2-40dd-afa6-b8550832431a-image.png" alt="5a095d34-36b2-40dd-afa6-b8550832431a-image.png" class=" img-fluid img-markdown" /></p>
<ol start="2">
<li>Assign <code>color</code> into your <code>calendar</code> module config.</li>
</ol>
<pre><code class="language-js">{
			header: "US Holidays",
						color: "yellow",
						symbol: "calendar-check",
						url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
]]></description><link>https://forum.magicmirror.builders/post/114699</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114699</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Thu, 18 Jan 2024 07:47:02 GMT</pubDate></item></channel></rss>
