<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Wyze Cams]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/15175/wyze-cam-v3">Wyze Cam V3</a><br />
Anyone figure out how to make the Wyze Cams show up on MM without using a RTSP module?</p>
]]></description><link>https://forum.magicmirror.builders/topic/18459/wyze-cams</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 03:56:46 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18459.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 28 Jan 2024 21:50:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Wyze Cams on Sun, 19 May 2024 20:09:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robertjunior24" aria-label="Profile: robertjunior24">@<bdi>robertjunior24</bdi></a> the problem is that RTSP isn’t supported by Web protocals.</p>
<p dir="auto">Here’s what I’m currently doing for my Reolink cameras:</p>
<p dir="auto">I use an PI 4 with Motion Eye OS (Discontinued, but still kinda works, there is betas of an attempt to bring MotionEye back) to convert the RTSP streams to Web streams. Then using MMM-EmbedURL, I’m able to pick up the web streams to use on my mirror.</p>
<p dir="auto">What I’d like to do is use something faster and more reliable - (Scrypted?) to do the conversion. Currently, there’s a lag that will form within the motioneye software, so I tend to reboot the pi once an hour (overdone, but it works) to keep it reasonable.</p>
<p dir="auto">If I use the Framed version of the URLs that MotionEyeOS provides me (like <code>http://192.168.0.7/picture/2/frame/</code>) - I don’t have to have MMM-Embed URL reset the picture, the system will provide a temporary “No Camera” image while it’s down.+</p>
<p dir="auto">Important note: Pi 5 (and newer, eventually) will NOT run what’s required for the old software, so Pi4 is what’s recommended.</p>
]]></description><link>https://forum.magicmirror.builders/post/117863</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117863</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Sun, 19 May 2024 20:09:21 GMT</pubDate></item><item><title><![CDATA[Reply to Wyze Cams on Sun, 19 May 2024 09:12:47 GMT]]></title><description><![CDATA[<p dir="auto">Can anyone answer this question? I’m looking for a answer because I have the same question. If anyone has one, please tag me. Thanks a lot.<a href="https://emp3juice.blog/" target="_blank" rel="noopener noreferrer nofollow ugc" class="plugin-markdown-hidden-link small link-danger"></a><a href="https://tubidy.diy/" target="_blank" rel="noopener noreferrer nofollow ugc" class="plugin-markdown-hidden-link small link-danger"></a><a href="https://y2mate.diy/" target="_blank" rel="noopener noreferrer nofollow ugc" class="plugin-markdown-hidden-link small link-danger"></a></p>
]]></description><link>https://forum.magicmirror.builders/post/117856</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117856</guid><dc:creator><![CDATA[robertjunior24]]></dc:creator><pubDate>Sun, 19 May 2024 09:12:47 GMT</pubDate></item></channel></rss>
