<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM-GoogleAssistant Error:  Unexpected end of JSON input]]></title><description><![CDATA[<p dir="auto">I have followed the guide and get al lthe way to the end without any issues until I go to generate a token</p>
<p dir="auto">I have rebuilt the credentials in google cloud and redownloaded several times and still get this error</p>
<p dir="auto">Can anyone point me in th right direction please ?</p>
<p dir="auto">Thank you</p>
<pre><code></code></pre>
<p dir="auto">Welcome to MMM-GoogleAssistant Token generator!</p>
<p dir="auto">Note: The choice expects [Y or N] and does not need [Enter] to confirm<br />
Do you want to install/reinstall MMM-GoogleAssistant token? [Y/n]<br />
Your choice: Y<br />
[GA] SyntaxError: /home/magicmirror/MagicMirror/modules/MMM-GoogleAssistant/credentials.json: Unexpected end of JSON input</p>
<p dir="auto">code_text</p>
]]></description><link>https://forum.magicmirror.builders/topic/18473/mm-googleassistant-error-unexpected-end-of-json-input</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 19:29:59 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18473.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 02 Feb 2024 09:10:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM-GoogleAssistant Error:  Unexpected end of JSON input on Sat, 03 Feb 2024 16:55:58 GMT]]></title><description><![CDATA[<p dir="auto">Please mark this topic as solved.</p>
<p dir="auto">The only thing I can figure is that it too some time to propagate  maybe ?</p>
<p dir="auto">I haven’t changed anything yet this morning it was able to generate the token without any issues</p>
<p dir="auto">Thank you for the help  :)</p>
]]></description><link>https://forum.magicmirror.builders/post/115240</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/115240</guid><dc:creator><![CDATA[dood]]></dc:creator><pubDate>Sat, 03 Feb 2024 16:55:58 GMT</pubDate></item><item><title><![CDATA[Reply to MM-GoogleAssistant Error:  Unexpected end of JSON input on Fri, 02 Feb 2024 21:05:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> It does.</p>
<p dir="auto">If it helps here is the full contents of the credentials.json file</p>
<p dir="auto">I have completely started from scratch 3 times now, those three times ere al lthe way from installing OS to this step.  I have went back and reconfigured and redownloaded the json file at least 5 times and still exact same error, in exactly the same place</p>
<p dir="auto">my os is</p>
<pre><code>magicmirror@magicmirror:~$ uname -a
Linux magicmirror 6.1.0-17-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.69-1 (2023-12-30) x86_64 GNU/Linux
magicmirror@magicmirror:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description:    Debian GNU/Linux 12 (bookworm)
Release:        12
Codename:       bookworm
<pre><code>{"web":{"client_id":"457148194700-qvcm.apps.googleusercontent.com","project_id":"ace-beanbag-413106","auth_uri":"https://accounts.google.com/o/oauth2/auth","token_uri":"https://oauth2.googleapis.com/token","auth_provider_x509_cert_url":"https://www.googleapis.com/oauth2/v1/certs","client_secret":"**REMOVED","redirect_uris":["https://googleassistant.bugsounet.fr"]}}
]]></description><link>https://forum.magicmirror.builders/post/115224</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/115224</guid><dc:creator><![CDATA[dood]]></dc:creator><pubDate>Fri, 02 Feb 2024 21:05:08 GMT</pubDate></item><item><title><![CDATA[Reply to MM-GoogleAssistant Error:  Unexpected end of JSON input on Fri, 02 Feb 2024 19:50:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dood" aria-label="Profile: dood">@<bdi>dood</bdi></a> if you edit the credentials.json file, I think it should say web:{</p>
<p dir="auto">to start…</p>
]]></description><link>https://forum.magicmirror.builders/post/115223</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/115223</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 02 Feb 2024 19:50:37 GMT</pubDate></item><item><title><![CDATA[Reply to MM-GoogleAssistant Error:  Unexpected end of JSON input on Fri, 02 Feb 2024 19:32:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Yes, its set as Web Application in CLoud config.</p>
<p dir="auto">I followed the guids located here</p>
<p dir="auto"><a href="https://wiki.bugsounet.fr/en/MMM-GoogleAssistant" target="_blank" rel="noopener noreferrer nofollow ugc">https://wiki.bugsounet.fr/en/MMM-GoogleAssistant</a></p>
]]></description><link>https://forum.magicmirror.builders/post/115222</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/115222</guid><dc:creator><![CDATA[dood]]></dc:creator><pubDate>Fri, 02 Feb 2024 19:32:53 GMT</pubDate></item><item><title><![CDATA[Reply to MM-GoogleAssistant Error:  Unexpected end of JSON input on Fri, 02 Feb 2024 13:11:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dood" aria-label="Profile: dood">@<bdi>dood</bdi></a> did you select the correct type on the cloud config?   the credentials file has different formats depending on the type you select</p>
]]></description><link>https://forum.magicmirror.builders/post/115219</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/115219</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 02 Feb 2024 13:11:49 GMT</pubDate></item></channel></rss>
