<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-FlightRadarTracker Syntax Error]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am not a programmer and cannot figure out what file/source is the cause of this error.  Does anyone have any hints?</p>
<pre><code>[09.02.2024 11:52.30.462] [ERROR] evalmachine.&lt;anonymous&gt;:1
{"aircraft":[],"full_count":0,"version":5}
SyntaxError: Unexpected token ':'
    at new Script (node:vm:94:7)
    at createScript (node:vm:251:10)
    at runInNewContext (node:vm:292:10)
    at parseJSONPNode (C:\Users\Space\MagicMirror\modules\MMM-FlightRadarTracker\node_modules\parse-jsonp\dist\node.js:14:2)
    at C:\Users\Space\MagicMirror\modules\MMM-FlightRadarTracker\node_modules\flightradar24-client\lib\radar.js:75:16
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
]]></description><link>https://forum.magicmirror.builders/topic/18494/mmm-flightradartracker-syntax-error</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 01:40:37 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18494.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 09 Feb 2024 16:59:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-FlightRadarTracker Syntax Error on Fri, 09 Feb 2024 20:33:28 GMT]]></title><description><![CDATA[<p dir="auto">This module is abandoned. In <a href="https://github.com/jesmak/MMM-FlightRadarTracker/issues/14" target="_blank" rel="noopener noreferrer nofollow ugc">issue 14</a> you can read that the API stopped working. Try MMM-Flights instead.</p>
]]></description><link>https://forum.magicmirror.builders/post/115412</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/115412</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Fri, 09 Feb 2024 20:33:28 GMT</pubDate></item></channel></rss>
