<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-PIR]]></title><description><![CDATA[<p dir="auto">Having had issues with Pi5 I went back to Pi4b. MMM-PIR works great with pi 4, blanking the screen after timer expires and resetting once presence is detected.<br />
The only issue I have is when the screen is blanked, the monitor backlight remains on, visible at nightnas a glow, the monitor remains powered up, I would have expected it to go into standby?</p>
]]></description><link>https://forum.magicmirror.builders/topic/18501/mmm-pir</link><generator>RSS for Node</generator><lastBuildDate>Tue, 11 Aug 2026 17:11:54 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18501.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 12 Feb 2024 09:32:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-PIR on Fri, 16 Feb 2024 19:40:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eyesallin" aria-label="Profile: eyesallin">@<bdi>eyesallin</bdi></a> in the node_helper.js</p>
<p dir="auto">browsers cannot access the system directly.<br />
the node_helper is the mm solution for that</p>
]]></description><link>https://forum.magicmirror.builders/post/115650</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/115650</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 16 Feb 2024 19:40:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR on Fri, 16 Feb 2024 19:37:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
So to ask but where are the commands located?</p>
]]></description><link>https://forum.magicmirror.builders/post/115649</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/115649</guid><dc:creator><![CDATA[eyesallin]]></dc:creator><pubDate>Fri, 16 Feb 2024 19:37:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR on Thu, 15 Feb 2024 14:46:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eyesallin" aria-label="Profile: eyesallin">@<bdi>eyesallin</bdi></a> can u execute the cec-client commands from the commandline to verify they work as you expect?</p>
<p dir="auto">see <a href="https://pimylifeup.com/raspberrypi-hdmi-cec/" target="_blank" rel="noopener noreferrer nofollow ugc">https://pimylifeup.com/raspberrypi-hdmi-cec/</a></p>
<p dir="auto">then u may be able to adjust the commands the  module is using…</p>
<p dir="auto">none of my displays support standby</p>
]]></description><link>https://forum.magicmirror.builders/post/115629</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/115629</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 15 Feb 2024 14:46:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR on Thu, 15 Feb 2024 14:08:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Thank you, I’ve checked and it is mode 4 for HDMI CEC, I have checked my monitor and HDMI CEC function is turned on, so it should work. After time out the monitor blanks but it is still powered on so I’m guessing so is the backlight, but Ill wait till dark to find out.<br />
Can I just say thanks again for your support with this.</p>
]]></description><link>https://forum.magicmirror.builders/post/115628</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/115628</guid><dc:creator><![CDATA[eyesallin]]></dc:creator><pubDate>Thu, 15 Feb 2024 14:08:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR on Wed, 14 Feb 2024 12:39:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eyesallin" aria-label="Profile: eyesallin">@<bdi>eyesallin</bdi></a> One the the modes will turn off the HDMI port. one of the modes uses CEC commands</p>
<p dir="auto">see this MMM-Pir<br />
<a href="https://github.com/bugsounet/MMM-Pir" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/bugsounet/MMM-Pir</a></p>
]]></description><link>https://forum.magicmirror.builders/post/115593</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/115593</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 14 Feb 2024 12:39:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR on Wed, 14 Feb 2024 11:02:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Many thanks, when I shut down the Pi, I get a No Hdmi message on screen and then the monitor goes into standby.<br />
Is there a way that MMM-PIR can turn off the Hdmi feed?<br />
Apologies but I’m not a programmer, just a hobbyist, you mention CEC commands, how would I implement this?</p>
]]></description><link>https://forum.magicmirror.builders/post/115592</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/115592</guid><dc:creator><![CDATA[eyesallin]]></dc:creator><pubDate>Wed, 14 Feb 2024 11:02:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR on Tue, 13 Feb 2024 15:05:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eyesallin" aria-label="Profile: eyesallin">@<bdi>eyesallin</bdi></a> blanking means hide modules. HDMI and screen still active</p>
<p dir="auto">need CEC commands to potentially get standby mode, if you monitor supports that. I have one TV that supports CEC commands, but does not support standby,  only off or on</p>
<p dir="auto">I use blanking extensively  cause none of my monitors will turn off/on</p>
]]></description><link>https://forum.magicmirror.builders/post/115575</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/115575</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 13 Feb 2024 15:05:21 GMT</pubDate></item></channel></rss>
