<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[change position body size]]></title><description><![CDATA[<p dir="auto">Hello everyone,<br />
I’m sure that my query has been asked several times before, but I can’t find a forum entry that helps me at the moment.</p>
<p dir="auto">Can you briefly explain to me how I can change the size of the position bodies? In other words, how do I enter it in Custom.css?</p>
<p dir="auto">I would like to adjust the widths of the top_left, top_center and top_middle.<br />
As far as I understand it, I will probably control it somehow via padding, but how exactly does that work?</p>
<p dir="auto">I would appreciate a short answer with an explanation or a link to a tutorial or instructions.</p>
]]></description><link>https://forum.magicmirror.builders/topic/18510/change-position-body-size</link><generator>RSS for Node</generator><lastBuildDate>Mon, 14 Sep 2026 20:34:33 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18510.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Feb 2024 14:20:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to change position body size on Wed, 14 Feb 2024 15:31:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/svenpisa" aria-label="Profile: svenpisa">@<bdi>svenpisa</bdi></a> takes all kinds of skills to make a complete thing.  looking good is an important characteristic, glad there are folks like you that  translate the vision into something concrete.</p>
]]></description><link>https://forum.magicmirror.builders/post/115604</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/115604</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 14 Feb 2024 15:31:02 GMT</pubDate></item><item><title><![CDATA[Reply to change position body size on Wed, 14 Feb 2024 15:18:48 GMT]]></title><description><![CDATA[<p dir="auto">NICE!!!</p>
<p dir="auto">And thanks for the links… The last one was great… :-)</p>
<p dir="auto">And sorry for “easy” ;-)</p>
<p dir="auto">I’m more the opposite of you… :D</p>
]]></description><link>https://forum.magicmirror.builders/post/115603</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/115603</guid><dc:creator><![CDATA[svenpisa]]></dc:creator><pubDate>Wed, 14 Feb 2024 15:18:48 GMT</pubDate></item><item><title><![CDATA[Reply to change position body size on Wed, 14 Feb 2024 14:52:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/svenpisa" aria-label="Profile: svenpisa">@<bdi>svenpisa</bdi></a> those things are called regions in MagicMirror</p>
<p dir="auto">you can see their definitions in css/main.css (small sample)</p>
<pre><code class="language-css">.region {
  position: absolute;
.region.fullscreen {
  position: absolute;
  inset: calc(-1 * var(--gap-body-top)) calc(-1 * var(--gap-body-right)) calc(-1 * var(--gap-body-bottom)) calc(-1 * var(--gap-body-left));
  pointer-events: none;
.region.right {
  right: 0;
  text-align: right;
<p dir="auto">you can change them, by defining the same thing (the selector clause, everything before the {) in custom.css</p>
<p dir="auto">in MM there is a stack of css definitions</p>
<pre><code class="language-text">custom.css on top
module css  (multiple)
main.css
<p dir="auto">the versions of definitions above another overrides the prior</p>
<pre><code class="language-text">custom.css overrides all
module overrides main
main is the base..
<p dir="auto">in the developers window you can see where a definition  comes from when u select and element, in the element tab<br />
see this for a starter on developers window elements tab<br />
<a href="https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1707761145294">https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1707761145294</a></p>
<p dir="auto">the doc, <a href="https://docs.magicmirror.builders/modules/configuration.html#position" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/modules/configuration.html#position</a><br />
shows the view of the default definitions…</p>
<p dir="auto">note that adding to one means taking away from another…</p>
<p dir="auto">there are lots of settings that affect each other… padding, margin, width , height,<br />
what to do about content that exceeds the boundary, wrap, clip,<br />
alignment</p>
<p dir="auto">easy is a term I would not use for html/css<br />
(I am not a visual designer, and this hurts my head…)<br />
<a href="https://www.geeksforgeeks.org/design-a-web-page-using-html-and-css/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.geeksforgeeks.org/design-a-web-page-using-html-and-css/</a><br />
<a href="https://www.udacity.com/blog/2021/02/an-introduction-to-margins-and-padding-in-css.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.udacity.com/blog/2021/02/an-introduction-to-margins-and-padding-in-css.html</a></p>
]]></description><link>https://forum.magicmirror.builders/post/115600</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/115600</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 14 Feb 2024 14:52:32 GMT</pubDate></item></channel></rss>
