<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Toulouse-Transports - Can&#x27;t display 2 buses with same bus stop]]></title><description><![CDATA[<p dir="auto">Hello there !</p>
<p dir="auto">This module works correctly but when i’m trying to display 2 “lineNumber” with the same “stopCode” the module won’t loading anymore.</p>
<p dir="auto">Do you have any ideas ?</p>
<p dir="auto">Thanks<br />
Jay777</p>
]]></description><link>https://forum.magicmirror.builders/topic/18518/mmm-toulouse-transports-can-t-display-2-buses-with-same-bus-stop</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 01:37:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18518.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 18 Feb 2024 15:16:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Toulouse-Transports - Can&#x27;t display 2 buses with same bus stop on Wed, 28 May 2025 08:21:17 GMT]]></title><description><![CDATA[<p dir="auto">Salut,</p>
<p dir="auto">The only solution I found,</p>
<p dir="auto">since I’m not a JS dev,</p>
<p dir="auto">is to load the module twice following this tutorial:</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/14724/run-two-instances-of-the-same-module-sometimes-tutorial">https://forum.magicmirror.builders/topic/14724/run-two-instances-of-the-same-module-sometimes-tutorial</a></p>
<p dir="auto">(not ideal though, because you call the API twice)</p>
]]></description><link>https://forum.magicmirror.builders/post/126758</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/126758</guid><dc:creator><![CDATA[bibelo]]></dc:creator><pubDate>Wed, 28 May 2025 08:21:17 GMT</pubDate></item></channel></rss>
