<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[module.js mismatch error and good by os]]></title><description><![CDATA[<p dir="auto">Hello guys, I get since some days more and more same errors:</p>
<pre><code>[module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 20:41.24.631] [ERROR] Whoops! There was an uncaught exception...
[07.03.2024 20:41.24.636] [ERROR] TypeError: terminated
    at Fetch.onAborted (node:internal/deps/undici/undici:11442:53)
    at Fetch.emit (node:events:514:28)
    at Fetch.terminate (node:internal/deps/undici/undici:10695:14)
    at Object.onError (node:internal/deps/undici/undici:11537:36)
    at Request.onError (node:internal/deps/undici/undici:8310:31)
    at errorRequest (node:internal/deps/undici/undici:10378:17)
    at TLSSocket.onSocketClose (node:internal/deps/undici/undici:9811:9)
    at TLSSocket.emit (node:events:526:35)
    at node:net:323:12
    at TCP.done (node:_tls_wrap:588:7) {
  [cause]: Error: read ECONNRESET
      at TLSWrap.onStreamRead (node:internal/stream_base_commons:217:20) {
    errno: -104,
    code: 'ECONNRESET',
    syscall: 'read'
<p dir="auto">i don’t know what to do because after some hours my whole pi stock and I have to disconnect the electrical to reboot it again. somebody can help me?</p>
<p dir="auto">thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/18555/module-js-mismatch-error-and-good-by-os</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 03:59:08 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18555.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 07 Mar 2024 20:26:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to module.js mismatch error and good by os on Fri, 08 Mar 2024 20:35:28 GMT]]></title><description><![CDATA[<p dir="auto">okay i will See what happened with the os now. I changed the MMM-MyCommute and don’t get much error anymore just this.</p>
<p dir="auto">thanks all for ur support!</p>
]]></description><link>https://forum.magicmirror.builders/post/116147</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116147</guid><dc:creator><![CDATA[fischi87]]></dc:creator><pubDate>Fri, 08 Mar 2024 20:35:28 GMT</pubDate></item><item><title><![CDATA[Reply to module.js mismatch error and good by os on Fri, 08 Mar 2024 19:33:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a> this error message will still occur, but can be ignored, as the code continues on without trouble</p>
]]></description><link>https://forum.magicmirror.builders/post/116146</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116146</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 08 Mar 2024 19:33:26 GMT</pubDate></item><item><title><![CDATA[Reply to module.js mismatch error and good by os on Fri, 08 Mar 2024 19:10:59 GMT]]></title><description><![CDATA[<p dir="auto">I think the fetch errors are related to <a href="https://github.com/MagicMirrorOrg/MagicMirror/issues/3329" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MagicMirrorOrg/MagicMirror/issues/3329</a></p>
<p dir="auto">you can try the newest electron version or disable ipv6</p>
]]></description><link>https://forum.magicmirror.builders/post/116145</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116145</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Fri, 08 Mar 2024 19:10:59 GMT</pubDate></item><item><title><![CDATA[Reply to module.js mismatch error and good by os on Fri, 08 Mar 2024 19:08:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fischi87" aria-label="Profile: fischi87">@<bdi>fischi87</bdi></a> said in <a href="/post/116134">module.js mismatch error and good by os</a>:</p>
<p dir="auto">do u mean the whole errors come from the MMM-MyCommute module?</p>
<p dir="auto">I don’t know. Deactivate all modules except this one and then see if the errors still occur.</p>
]]></description><link>https://forum.magicmirror.builders/post/116144</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116144</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Fri, 08 Mar 2024 19:08:04 GMT</pubDate></item><item><title><![CDATA[Reply to module.js mismatch error and good by os on Fri, 08 Mar 2024 14:06:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fischi87" aria-label="Profile: fischi87">@<bdi>fischi87</bdi></a> that message should really be a warning, as it causes no trouble, and the code handles the issue</p>
]]></description><link>https://forum.magicmirror.builders/post/116137</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116137</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 08 Mar 2024 14:06:55 GMT</pubDate></item><item><title><![CDATA[Reply to module.js mismatch error and good by os on Fri, 08 Mar 2024 12:20:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a></p>
<p dir="auto">after some trieng, i get still the same error:?</p>
<pre><code>[08.03.2024 13:18.44.611] [ERROR] [MMM-MyCommute.js:481:18] Parameter mismatch in module.show: callback is not an optional parameter!
]]></description><link>https://forum.magicmirror.builders/post/116135</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116135</guid><dc:creator><![CDATA[fischi87]]></dc:creator><pubDate>Fri, 08 Mar 2024 12:20:27 GMT</pubDate></item><item><title><![CDATA[Reply to module.js mismatch error and good by os on Fri, 08 Mar 2024 12:14:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a></p>
<p dir="auto">okay i will it a try. thank u.</p>
]]></description><link>https://forum.magicmirror.builders/post/116134</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116134</guid><dc:creator><![CDATA[fischi87]]></dc:creator><pubDate>Fri, 08 Mar 2024 12:14:02 GMT</pubDate></item><item><title><![CDATA[Reply to module.js mismatch error and good by os on Fri, 08 Mar 2024 10:48:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fischi87" aria-label="Profile: fischi87">@<bdi>fischi87</bdi></a> That project hasn’t been updated since 7 years. On the official module list is a newer fork which got updated 2 years ago. So I recommend try this newer fork: <a href="https://github.com/qistoph/MMM-MyCommute" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/qistoph/MMM-MyCommute</a>.</p>
]]></description><link>https://forum.magicmirror.builders/post/116133</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116133</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Fri, 08 Mar 2024 10:48:38 GMT</pubDate></item><item><title><![CDATA[Reply to module.js mismatch error and good by os on Fri, 08 Mar 2024 05:47:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a></p>
<p dir="auto">Good Morning,</p>
<pre><code>pi@raspberrypi:~/MagicMirror/modules/MMM-MyCommute $ git remote -v
origin  https://github.com/jclarke0000/MMM-MyCommute.git (fetch)
origin  https://github.com/jclarke0000/MMM-MyCommute.git (push)
]]></description><link>https://forum.magicmirror.builders/post/116130</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116130</guid><dc:creator><![CDATA[fischi87]]></dc:creator><pubDate>Fri, 08 Mar 2024 05:47:09 GMT</pubDate></item><item><title><![CDATA[Reply to module.js mismatch error and good by os on Thu, 07 Mar 2024 23:19:48 GMT]]></title><description><![CDATA[<p dir="auto">Which fork of MMM-MyCommute are you using? Go to the module’s directory and run <code>git remote -v</code>.</p>
]]></description><link>https://forum.magicmirror.builders/post/116126</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116126</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Thu, 07 Mar 2024 23:19:48 GMT</pubDate></item><item><title><![CDATA[Reply to module.js mismatch error and good by os on Thu, 07 Mar 2024 21:17:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">so?</p>
<pre><code>[07.03.2024 16:54.00.433] [ERROR] Whoops! There was an uncaught exception...
[07.03.2024 16:54.00.436] [ERROR] TypeError: Cannot read properties of undefined (reading 'statusCode')
    at Request._callback (/home/pi/MagicMirror/modules/MMM-MyCommute/node_helper.js:90:72)
    at self.callback (/home/pi/MagicMirror/modules/MMM-MyCommute/node_modules/request/request.js:185:22)
    at Request.emit (node:events:514:28)
    at Request.onRequestError (/home/pi/MagicMirror/modules/MMM-MyCommute/node_modules/request/request.js:877:8)
    at ClientRequest.emit (node:events:514:28)
    at TLSSocket.socketErrorListener (node:_http_client:501:9)
    at TLSSocket.emit (node:events:514:28)
    at emitErrorNT (node:internal/streams/destroy:151:8)
    at emitErrorCloseNT (node:internal/streams/destroy:116:3)
    at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
[07.03.2024 16:54.00.436] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[07.03.2024 16:54.00.437] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
[07.03.2024 16:54.00.440] [ERROR] Whoops! There was an uncaught exception...
[07.03.2024 16:54.00.441] [ERROR] TypeError: Cannot read properties of undefined (reading 'statusCode')
[07.03.2024 16:54.00.442] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[07.03.2024 16:54.00.442] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
[07.03.2024 16:57.14.836] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:00.29.852] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:00.29.860] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:03.40.785] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:03.40.791] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:03.40.794] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:05.08.963] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:05.11.515] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 17:07.36.595] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:07.36.604] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:07.36.608] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:07.36.625] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:07.36.630] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:12.14.810] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:14.01.586] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 17:15.30.200] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:15.34.878] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:18.40.577] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:18.40.611] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:18.40.629] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:20.09.069] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:22.36.668] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:22.36.678] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:22.36.679] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:22.36.716] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:22.36.717] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:27.14.780] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:30.29.901] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:30.29.914] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:33.40.530] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:33.40.536] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:33.40.537] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:35.08.848] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:37.36.654] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:37.36.656] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:37.36.658] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:37.36.660] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:37.36.662] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:42.14.801] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:45.29.904] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:45.30.045] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 17:17.22.258] [WARN]  You're using a full whitelist configuration to allow for all IPs
[07.03.2024 17:17.29.864] [ERROR] Got error: connect ECONNREFUSED ::1:8085
[07.03.2024 17:17.29.866] [ERROR] Got error: connect ECONNREFUSED ::1:8085
[07.03.2024 17:17.29.872] [ERROR] Got error: connect ECONNREFUSED ::1:8085
[07.03.2024 17:17.31.105] [WARN]  MMM-Fuel: Filtered stationIds list is empty
Warning: vkCreateInstance: Found no drivers!
Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
    at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
    at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
    at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
    at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
    at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
[07.03.2024 18:32.42.019] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 18:37.42.727] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 18:47.42.027] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 18:47.42.297] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 18:57.42.068] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 19:02.42.065] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 19:02.52.629] [ERROR] Newsfeed Error. Could not fetch newsfeed:  http://www.n-tv.de/23.rss',1649704970 TypeError: fetch failed
    at Object.fetch (node:internal/deps/undici/undici:11576:11) {
  cause: Error: read ECONNRESET
      at TCP.onStreamRead (node:internal/stream_base_commons:217:20) {
    errno: -104,
    code: 'ECONNRESET',
    syscall: 'read'
[07.03.2024 19:07.41.602] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 19:16.23.509] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 19:16.23.746] [ERROR] [ERROR] [MMM-LogExt.js:104:32] TypeError: undefined is not an object (evaluating 'stack[0].trim')
[07.03.2024 19:19.33.715] [ERROR] Calendar Error. Could not fetch calendar:  http://p38-caldav.icloud.com/published/2/MTE1NzI0ODI1NTMxMTU3MjAoEsRWam-2ZZTrGZrTpcWein9v_8iLzzNNtqHYSW-F TypeError: fetch failed
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
  cause: ConnectTimeoutError: Connect Timeout Error
      at onConnectTimeout (node:internal/deps/undici/undici:8522:28)
      at node:internal/deps/undici/undici:8480:50
      at Immediate._onImmediate (node:internal/deps/undici/undici:8511:13)
      at process.processImmediate (node:internal/timers:476:21) {
    code: 'UND_ERR_CONNECT_TIMEOUT'
[07.03.2024 19:19.34.078] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 19:19.47.570] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 19:27.41.873] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 19:31.23.198] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 19:34.33.784] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 19:37.41.815] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 19:46.23.244] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 19:46.28.220] [ERROR] Newsfeed Error. Could not fetch newsfeed:  http://www.n-tv.de/23.rss',1649704970 TypeError: fetch failed
    errno: -104,
    code: 'ECONNRESET',
    syscall: 'read'
[07.03.2024 19:47.41.945] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 19:49.33.800] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 19:51.31.330] [ERROR] Newsfeed Error. Could not fetch newsfeed:  http://www.n-tv.de/23.rss',1649704970 TypeError: fetch failed
    errno: -104,
    code: 'ECONNRESET',
    syscall: 'read'
[07.03.2024 19:56.32.545] [ERROR] Newsfeed Error. Could not fetch newsfeed:  http://www.n-tv.de/23.rss',1649704970 TypeError: fetch failed
    errno: -104,
    code: 'ECONNRESET',
    syscall: 'read'
[07.03.2024 19:57.41.989] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 20:01.23.205] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 20:01.33.660] [ERROR] Newsfeed Error. Could not fetch newsfeed:  http://www.n-tv.de/23.rss',1649704970 TypeError: fetch failed
    errno: -104,
    code: 'ECONNRESET',
    syscall: 'read'
[07.03.2024 20:04.33.930] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 20:07.41.827] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 20:16.23.509] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 20:17.42.610] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 20:19.33.817] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 20:24.04.656] [ERROR] Newsfeed Error. Could not fetch newsfeed:  https://www.gala.de/feed/rss-news/ TypeError: fetch failed
[07.03.2024 20:24.04.675] [ERROR] Newsfeed Error. Could not fetch newsfeed:  http://www.n-tv.de/23.rss',1649704970 TypeError: fetch failed
  cause: SocketError: other side closed
      at Socket.onSocketEnd (node:internal/deps/undici/undici:9790:26)
      at Socket.emit (node:events:526:35)
      at endReadableNT (node:internal/streams/readable:1359:12)
      at process.processTicksAndRejections (node:internal/process/task_queues:82:21) {
    code: 'UND_ERR_SOCKET',
    socket: {
      localAddress: '2003:f4:bf06:2900:794a:73d6:93b3:3918',
      localPort: 43688,
      remoteAddress: '2600:9000:2759:600:10:e1a5:2c0:93a1',
      remotePort: 80,
      remoteFamily: 'IPv6',
      timeout: undefined,
      bytesWritten: 307,
      bytesRead: 0
[07.03.2024 20:27.42.983] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 20:31.29.021] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 20:34.33.778] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 20:37.42.426] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
    at node:net:323:12
    errno: -104,
    code: 'ECONNRESET',
    syscall: 'read'
[07.03.2024 20:41.24.637] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[07.03.2024 20:41.24.638] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
[07.03.2024 20:46.23.309] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 20:47.41.665] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 20:49.33.775] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 20:57.41.701] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 21:01.23.282] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 21:04.33.993] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 21:07.41.762] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 21:16.23.288] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 21:17.41.805] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 21:19.33.812] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 21:27.41.899] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 21:31.23.355] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 21:34.33.781] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 21:37.41.741] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 21:46.23.285] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 21:47.41.969] [ERROR] [module.js:395:8] Parameter mismatch in module.show: callback is not an optional parameter!
[07.03.2024 21:49.33.880] [WARN]  MMM-Fuel: Filtered stationIds list is empty
<p dir="auto">and now this:</p>
<pre><code>[07.03.2024 22:11.05.654] [ERROR] [ERROR] [MMM-LogExt.js:104:32] TypeError: undefined is not an object (evaluating 'stack[0].trim')
[07.03.2024 22:11.05.682] [INFO]  [loader.js:43:20] All modules started!
[07.03.2024 22:11.05.908] [WARN]  MMM-Fuel: Filtered stationIds list is empty
[07.03.2024 22:11.06.413] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
[07.03.2024 22:11.06.421] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
[07.03.2024 22:12.32.149] [INFO]  Calendar-Fetcher: Broadcasting 6 events from http://p38-caldav.icloud.com/published/2/MTE1NzI0ODI1NTMxMTU3MjAoEsRWam-2ZZTrGZrTpcWein9v_8iLzzNNtqHYSW-F.
[07.03.2024 22:12.32.346] [INFO]  updatenotification: You are not using pm2
[07.03.2024 22:12.32.372] [ERROR] Whoops! There was an uncaught exception...
[07.03.2024 22:12.32.373] [ERROR] TypeError: Cannot read properties of undefined (reading 'statusCode')
[07.03.2024 22:12.32.374] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[07.03.2024 22:12.32.374] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
[07.03.2024 22:15.45.792] [INFO]  Calendar-Fetcher: Broadcasting 25 events from http://p103-caldav.icloud.com/published/2/MTE2MDcyNjc3OTYxMTYwN6ZYZQ5Zk3eL98raqhQSpn8fhpKW6d_J381unsy_tQSX.
[07.03.2024 22:15.46.373] [ERROR] [ERROR] [MMM-LogExt.js:104:32] TypeError: undefined is not an object (evaluating 'stack[0].trim')
[07.03.2024 22:15.47.295] [LOG]   [MMM-ioBroker.js:70:11] ioBroker new data fetched...
[07.03.2024 22:15.47.698] [LOG]   [weather.js:166:7] New weather information available.
[07.03.2024 22:15.47.723] [LOG]   [weather.js:166:7] New weather information available.
[07.03.2024 22:16.06.790] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
[07.03.2024 22:16.07.020] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
]]></description><link>https://forum.magicmirror.builders/post/116124</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116124</guid><dc:creator><![CDATA[fischi87]]></dc:creator><pubDate>Thu, 07 Mar 2024 21:17:53 GMT</pubDate></item><item><title><![CDATA[Reply to module.js mismatch error and good by os on Thu, 07 Mar 2024 20:49:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fischi87" aria-label="Profile: fischi87">@<bdi>fischi87</bdi></a> can u show a little more of the trace</p>
]]></description><link>https://forum.magicmirror.builders/post/116123</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116123</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 07 Mar 2024 20:49:10 GMT</pubDate></item></channel></rss>
