<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-PIR Install Issue]]></title><description><![CDATA[<p dir="auto">Hello all,  I have a problem installing MMM-Pir Module. Maybe someone has an idea what I can check/do. Thanks in advance!</p>
<p dir="auto"><img src="/assets/uploads/files/1710190052560-image.png" alt="image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Log:</p>
<p dir="auto">123 timing commandinstall Completed in 3987ms<br />
124 verbose stack Error command failed<br />
124 verbose stack     at ChildProcess.anonymous (usrlibnode_modulesnpmnode_modules@npmclipromise-spawnlibindex.js5327)<br />
124 verbose stack     at ChildProcess.emit (nodeevents51428)<br />
124 verbose stack     at maybeClose (nodeinternalchild_process109116)<br />
124 verbose stack     at ChildProcess._handle.onexit (nodeinternalchild_process3025)<br />
125 verbose pkgid MMM-Pir@1.5.0<br />
126 verbose cwd homexenonMagicMirrorv2MagicMirrormodulesMMM-Pir<br />
127 verbose Linux 6.1.21-v8+<br />
128 verbose node v18.17.1<br />
129 verbose npm  v9.6.7<br />
130 error code 255<br />
131 error path homexenonMagicMirrorv2MagicMirrormodulesMMM-Pir<br />
132 error command failed<br />
133 error command sh -c <a href="http://installerpreinstall.sh" target="_blank" rel="noopener noreferrer nofollow ugc">installerpreinstall.sh</a> -d ‘unclutter cec-utils ddcutil python3 python-is-python3 python3-gpiozero’<br />
134 verbose exit 255<br />
135 timing npm Completed in 4803ms<br />
136 verbose code 255<br />
137 error A complete log of this run can be found in homexenon.npm_logs2024-03-10T19_31_02_029Z-debug-0.log</p>
]]></description><link>https://forum.magicmirror.builders/topic/18569/mmm-pir-install-issue</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 21:35:15 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18569.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 Mar 2024 20:50:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-PIR Install Issue on Tue, 12 Mar 2024 17:18:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> worked !! Thank you  - I m still a linux newbie</p>
]]></description><link>https://forum.magicmirror.builders/post/116237</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116237</guid><dc:creator><![CDATA[Andrei.Leahu]]></dc:creator><pubDate>Tue, 12 Mar 2024 17:18:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR Install Issue on Tue, 12 Mar 2024 11:27:27 GMT]]></title><description><![CDATA[<p dir="auto">@Andrei-Leahu<br />
HI, change MagicMirror folder permission as your own user (xenon) and not root</p>
]]></description><link>https://forum.magicmirror.builders/post/116213</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116213</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Tue, 12 Mar 2024 11:27:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PIR Install Issue on Mon, 11 Mar 2024 23:13:26 GMT]]></title><description><![CDATA[<p dir="auto">@Andrei-Leahu the module author has been updating recently, I would open an issue on the module github page</p>
]]></description><link>https://forum.magicmirror.builders/post/116208</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116208</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 11 Mar 2024 23:13:26 GMT</pubDate></item></channel></rss>
