<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Listen for calender on port 5005]]></title><description><![CDATA[<p dir="auto">Hi everybody,<br />
I am running a MM on my Raspi3 and an old Notebook LCD. Everything is working fine except a small problem with the calendar module: I would like to implement my own calendar from an .ics  hosted by my synology server. Since now it does not work, I think because of port 5005 used by my server. Is there a way to use my own .ics file this way?<br />
Thank you in advance!</p>
]]></description><link>https://forum.magicmirror.builders/topic/186/listen-for-calender-on-port-5005</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 17:43:35 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/186.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Jun 2016 07:45:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Listen for calender on port 5005 on Mon, 06 Jun 2016 09:11:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paviro" aria-label="Profile: paviro">@<bdi>paviro</bdi></a> Thanks a lot! I actually tried your solution before but it did not work. After your post I was sure it had to work somehow and I was able to solve my problem. My mistake was to leave out / to wrongly implement username and password.</p>
<p dir="auto">With <a href="http://username:password@server.local:5005/calendar.ics" target="_blank" rel="noopener noreferrer nofollow ugc">http://username:password@server.local:5005/calendar.ics</a> everything is working perfectly fine.</p>
]]></description><link>https://forum.magicmirror.builders/post/1367</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1367</guid><dc:creator><![CDATA[Axelito]]></dc:creator><pubDate>Mon, 06 Jun 2016 09:11:50 GMT</pubDate></item><item><title><![CDATA[Reply to Listen for calender on port 5005 on Mon, 06 Jun 2016 08:41:51 GMT]]></title><description><![CDATA[<p dir="auto"><code>http://server.local:5005/calendar.ics</code>?</p>
]]></description><link>https://forum.magicmirror.builders/post/1366</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1366</guid><dc:creator><![CDATA[paviro]]></dc:creator><pubDate>Mon, 06 Jun 2016 08:41:51 GMT</pubDate></item></channel></rss>
