<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[August-Lock Module Stuck on Loading]]></title><description><![CDATA[<p dir="auto">I am trying to get the MMM-August-Lock Module to connect and display the status of the multiple August Locks we have around the house. However, after getting everything installed correctly and authorizing via my email/password and the code that is sent the module is stuck on “Loading” when displayed on my mirror. Any ideas on what might cause this? I see that the module is 3 years old so I am guessing it’s possible August has changed some things that haven’t been updated in the module? Anyone have any experience with this one?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/18607/august-lock-module-stuck-on-loading</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Jul 2026 07:55:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18607.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 28 Mar 2024 20:50:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to August-Lock Module Stuck on Loading on Sat, 06 Apr 2024 19:39:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>, I did and everything authorized successfully. I will open an issue with the developer as suggested above. I appreciate the responses and help!</p>
]]></description><link>https://forum.magicmirror.builders/post/116823</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116823</guid><dc:creator><![CDATA[jcgrim13]]></dc:creator><pubDate>Sat, 06 Apr 2024 19:39:33 GMT</pubDate></item><item><title><![CDATA[Reply to August-Lock Module Stuck on Loading on Fri, 05 Apr 2024 23:48:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jcgrim13" aria-label="Profile: jcgrim13">@<bdi>jcgrim13</bdi></a> sid you rerun the auth script?</p>
<p dir="auto"><img src="/assets/uploads/files/1712360905974-screenshot_20240405_184730_chrome.jpg" alt="Screenshot_20240405_184730_Chrome.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/116815</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116815</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 05 Apr 2024 23:48:29 GMT</pubDate></item><item><title><![CDATA[Reply to August-Lock Module Stuck on Loading on Fri, 05 Apr 2024 23:14:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jcgrim13" aria-label="Profile: jcgrim13">@<bdi>jcgrim13</bdi></a> I recommend to open <a href="https://github.com/relm923/MMM-August-Lock/issues" target="_blank" rel="noopener noreferrer nofollow ugc">an issue in the module’s repository</a>. Maybe the author will notice that.</p>
]]></description><link>https://forum.magicmirror.builders/post/116814</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116814</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Fri, 05 Apr 2024 23:14:22 GMT</pubDate></item><item><title><![CDATA[Reply to August-Lock Module Stuck on Loading on Fri, 05 Apr 2024 05:51:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a>, I had that same thought so I triple checked those, even used the same ones to log in to get the authorization code thats required when you first install the module. I am wondering if August changed something with their API…</p>
]]></description><link>https://forum.magicmirror.builders/post/116799</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116799</guid><dc:creator><![CDATA[jcgrim13]]></dc:creator><pubDate>Fri, 05 Apr 2024 05:51:13 GMT</pubDate></item><item><title><![CDATA[Reply to August-Lock Module Stuck on Loading on Wed, 03 Apr 2024 20:55:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jcgrim13" aria-label="Profile: jcgrim13">@<bdi>jcgrim13</bdi></a> Check that your password and augustID are correct.</p>
]]></description><link>https://forum.magicmirror.builders/post/116764</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116764</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Wed, 03 Apr 2024 20:55:44 GMT</pubDate></item><item><title><![CDATA[Reply to August-Lock Module Stuck on Loading on Wed, 03 Apr 2024 20:47:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jcgrim13" aria-label="Profile: jcgrim13">@<bdi>jcgrim13</bdi></a> GET failed with: 401</p>
<p dir="auto">unauthorized</p>
]]></description><link>https://forum.magicmirror.builders/post/116763</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116763</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 03 Apr 2024 20:47:41 GMT</pubDate></item><item><title><![CDATA[Reply to August-Lock Module Stuck on Loading on Wed, 03 Apr 2024 20:46:52 GMT]]></title><description><![CDATA[<p dir="auto">I am still new at this so didn’t think about the logs. Looks like there is for sure an error, but not sure how to determine what is causing it. Here is the error in the logs…any thoughts</p>
<pre><code class="language-text![alt">0|mm  | [2024-04-03 16:42:14.130] [ERROR] Error occurred while fetching stats Error: GET failed with: 401
0|mm  |     at IncomingMessage.&lt;anonymous&gt; (/home/admin/MagicMirror/modules/MMM-August-Lock/node_modules/tiny-json-http/bundle.js:1:2186)
0|mm  |     at IncomingMessage.emit (node:events:526:35)
0|mm  |     at endReadableNT (node:internal/streams/readable:1408:12)
0|mm  |     at process.processTicksAndRejections (node:internal/process/task_queues:82:21) {
0|mm  |   raw: &lt;ref *1&gt; IncomingMessage {
0|mm  |     _readableState: ReadableState {
0|mm  |       state: 456758,
0|mm  |       highWaterMark: 16384,
0|mm  |       buffer: BufferList { head: null, tail: null, length: 0 },
0|mm  |       length: 0,
0|mm  |       pipes: [],
0|mm  |       flowing: true,
0|mm  |       errored: null,
0|mm  |       defaultEncoding: 'utf8',
0|mm  |       awaitDrainWriters: null,
0|mm  |       decoder: null,
0|mm  |       encoding: null,
0|mm  |       [Symbol(kPaused)]: false
0|mm  |     },
0|mm  |     _events: [Object: null prototype] {
0|mm  |       end: [Array],
0|mm  |       data: [Function (anonymous)]
0|mm  |     },
0|mm  |     _eventsCount: 2,
0|mm  |     _maxListeners: undefined,
0|mm  |     socket: null,
0|mm  |     httpVersionMajor: 1,
0|mm  |     httpVersionMinor: 1,
0|mm  |     httpVersion: '1.1',
0|mm  |     complete: true,
0|mm  |     rawHeaders: [
0|mm  |       'Date',
0|mm  |       'Wed, 03 Apr 2024 20:42:14 GMT',
0|mm  |       'Content-Type',
0|mm  |       'application/json',
0|mm  |       'Content-Length',
0|mm  |       '65',
0|mm  |       'Connection',
0|mm  |       'keep-alive',
0|mm  |       'vary',
0|mm  |       'origin,access-control-request-method,access-control-request-headers',
0|mm  |       'content-security-policy',
0|mm  |       "default-src 'self';base-uri 'self';block-all-mixed-content;font-src 'self' https: data:;frame-ancestors 'self';img-src 'self' data:;object-src 'none';script-src 'self';script-src-attr 'none';style-src 'self' https: 'unsafe-inline';upgrade-insecure-requests",
0|mm  |       'x-dns-prefetch-control',
0|mm  |       'off',
0|mm  |       'expect-ct',
0|mm  |       'max-age=0',
0|mm  |       'x-frame-options',
0|mm  |       'SAMEORIGIN',
0|mm  |       'strict-transport-security',
0|mm  |       'max-age=15552000; includeSubDomains',
0|mm  |       'x-download-options',
0|mm  |       'noopen',
0|mm  |       'x-content-type-options',
0|mm  |       'nosniff',
0|mm  |       'x-permitted-cross-domain-policies',
0|mm  |       'none',
0|mm  |       'referrer-policy',
0|mm  |       'no-referrer',
0|mm  |       'x-xss-protection',
0|mm  |       '0',
0|mm  |       'api-version',
0|mm  |       '0.0.1',
0|mm  |       'x-response-time',
0|mm  |       '2',
0|mm  |       'CF-Cache-Status',
0|mm  |       'DYNAMIC',
0|mm  |       'Set-Cookie',
0|mm  |       '__cf_bm=OoUIdyZ8fziOlR0ZXufTExomKxLJrvgfgDil42qlrOk-1712176934-1.0.1.1-6atgYmMjhGdKpAbUxyDKj36_Cswj3DQLV0Me_FTeh0Rywy2UqoMUs35FUtYJoVv06MUOyGfjuch82PQpSg_DGw; path=/; expires=Wed, 03-Apr-24 21:12:14 GMT; domain=.august.com; HttpOnly; Secure; SameSite=None',
0|mm  |       'Server',
0|mm  |       'cloudflare',
0|mm  |       'CF-RAY',
0|mm  |       '86ebe24d3c4eb3c7-MIA'
0|mm  |     ],
0|mm  |     rawTrailers: [],
0|mm  |     joinDuplicateHeaders: undefined,
0|mm  |     aborted: false,
0|mm  |     upgrade: false,
0|mm  |     url: '',
0|mm  |     method: null,
0|mm  |     statusCode: 401,
0|mm  |     statusMessage: 'Unauthorized',
0|mm  |     client: TLSSocket {
0|mm  |       _tlsOptions: [Object],
0|mm  |       _secureEstablished: true,
0|mm  |       _securePending: false,
0|mm  |       _newSessionPending: false,
0|mm  |       _controlReleased: true,
0|mm  |       secureConnecting: false,
0|mm  |       _SNICallback: null,
0|mm  |       servername: 'api-production.august.com',
0|mm  |       alpnProtocol: false,
0|mm  |       authorized: true,
0|mm  |       authorizationError: null,
0|mm  |       encrypted: true,
0|mm  |       _events: [Object: null prototype],
0|mm  |       _eventsCount: 9,
0|mm  |       connecting: false,
0|mm  |       _hadError: false,
0|mm  |       _parent: null,
0|mm  |       _host: 'api-production.august.com',
0|mm  |       _closeAfterHandlingError: false,
0|mm  |       _readableState: [ReadableState],
0|mm  |       _writableState: [WritableState],
0|mm  |       allowHalfOpen: false,
0|mm  |       _sockname: null,
0|mm  |       _pendingData: null,
0|mm  |       _pendingEncoding: '',
0|mm  |       server: undefined,
0|mm  |       _server: null,
0|mm  |       ssl: [TLSWrap],
0|mm  |       _requestCert: true,
0|mm  |       _rejectUnauthorized: true,
0|mm  |       timeout: 5000,
0|mm  |       parser: null,
0|mm  |       _httpMessage: null,
0|mm  |       autoSelectFamilyAttemptedAddresses: [Array],
0|mm  |       [Symbol(alpncallback)]: null,
0|mm  |       [Symbol(res)]: [TLSWrap],
0|mm  |       [Symbol(verified)]: true,
0|mm  |       [Symbol(pendingSession)]: null,
0|mm  |       [Symbol(async_id_symbol)]: -1,
0|mm  |       [Symbol(kHandle)]: [TLSWrap],
0|mm  |       [Symbol(lastWriteQueueSize)]: 0,
0|mm  |       [Symbol(timeout)]: Timeout {
0|mm  |         _idleTimeout: 5000,
0|mm  |         _idlePrev: [TimersList],
0|mm  |         _idleNext: [Timeout],
0|mm  |         _idleStart: 498879,
0|mm  |         _onTimeout: [Function: bound ],
0|mm  |         _timerArgs: undefined,
0|mm  |         _repeat: null,
0|mm  |         _destroyed: false,
0|mm  |         [Symbol(refed)]: false,
0|mm  |         [Symbol(kHasPrimitive)]: false,
0|mm  |         [Symbol(asyncId)]: 17455,
0|mm  |         [Symbol(triggerId)]: 17453
0|mm  |       },
0|mm  |       [Symbol(kBuffer)]: null,
0|mm  |       [Symbol(kBufferCb)]: null,
0|mm  |       [Symbol(kBufferGen)]: null,
0|mm  |       [Symbol(kCapture)]: false,
0|mm  |       [Symbol(kSetNoDelay)]: false,
0|mm  |       [Symbol(kSetKeepAlive)]: true,
0|mm  |       [Symbol(kSetKeepAliveInitialDelay)]: 1,
0|mm  |       [Symbol(kBytesRead)]: 0,
0|mm  |       [Symbol(kBytesWritten)]: 0,
0|mm  |       [Symbol(connect-options)]: [Object]
0|mm  |     },
]]></description><link>https://forum.magicmirror.builders/post/116762</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116762</guid><dc:creator><![CDATA[jcgrim13]]></dc:creator><pubDate>Wed, 03 Apr 2024 20:46:52 GMT</pubDate></item><item><title><![CDATA[Reply to August-Lock Module Stuck on Loading on Fri, 29 Mar 2024 01:11:49 GMT]]></title><description><![CDATA[<p dir="auto">Do you see anything unusual in the logs of node or the browser?</p>
<p dir="auto">I link the developer here, maybe he’ll get a notification: <a class="plugin-mentions-user plugin-mentions-a" href="/user/relm923" aria-label="Profile: relm923">@<bdi>relm923</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/116633</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116633</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Fri, 29 Mar 2024 01:11:49 GMT</pubDate></item></channel></rss>
