<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-euro2024]]></title><description><![CDATA[<p dir="auto">A few weeks more to go, but the magic mirror module is already here for you: <a href="https://github.com/0m4r/MMM-euro2024" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/0m4r/MMM-euro2024</a>!</p>
<p dir="auto"><img src="https://github.com/0m4r/MMM-euro2024/raw/main/MMM-euro2024.png" alt="MMM-euro2024" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/18618/mmm-euro2024</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 18:35:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18618.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 Apr 2024 13:48:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-euro2024 on Wed, 19 Jun 2024 15:28:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/0m4r" aria-label="Profile: 0m4r">@<bdi>0m4r</bdi></a>  Hello and thank you for your great module.</p>
<p dir="auto">after installing it, it appears on my mirror, but stays on “loading…”.</p>
<p dir="auto">Do you maybe know this issue?</p>
<p dir="auto">Thanks in advance for your helps.</p>
<p dir="auto">Kind regards</p>
<p dir="auto"><img src="/assets/uploads/files/1718810888208-capture-d-e-cran-2024-06-19-a-17.27.57.jpg" alt="Capture d’écran 2024-06-19 à 17.27.57.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/118382</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118382</guid><dc:creator><![CDATA[com1cedric]]></dc:creator><pubDate>Wed, 19 Jun 2024 15:28:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Sun, 16 Jun 2024 10:31:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/leafarenuk" aria-label="Profile: leafarenuk">@<bdi>leafarenuk</bdi></a> I replied to you on Git Hub a week ago or so.<br />
As I have not heard back from you since then, I assume the problem is resolved.</p>
<p dir="auto">If not, feel free to get in touch again.</p>
]]></description><link>https://forum.magicmirror.builders/post/118321</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118321</guid><dc:creator><![CDATA[0m4r]]></dc:creator><pubDate>Sun, 16 Jun 2024 10:31:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Sat, 08 Jun 2024 19:40:27 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys,<br />
I cannot get this module to run…</p>
<p dir="auto">I also opened an issue in the repo: <a href="https://github.com/0m4r/MMM-euro2024/issues/2" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/0m4r/MMM-euro2024/issues/2</a></p>
<p dir="auto">Can somebody from here help me? <a class="plugin-mentions-user plugin-mentions-a" href="/user/0m4r" aria-label="Profile: 0m4r">@<bdi>0m4r</bdi></a> ?</p>
<p dir="auto">Thanks in advance</p>
]]></description><link>https://forum.magicmirror.builders/post/118175</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118175</guid><dc:creator><![CDATA[leafarenuk]]></dc:creator><pubDate>Sat, 08 Jun 2024 19:40:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Tue, 09 Apr 2024 07:34:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robiv8" aria-label="Profile: robiv8">@<bdi>robiv8</bdi></a> try with this:</p>
<pre><code>{
	disabled: false,
	module: "MMM-euro2024",
	position: "center",
	header: "Euro 2024",
	updateInterval: 60 * 1000,
	token: "b1e67..myToken..67c8c5",
]]></description><link>https://forum.magicmirror.builders/post/116871</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116871</guid><dc:creator><![CDATA[0m4r]]></dc:creator><pubDate>Tue, 09 Apr 2024 07:34:05 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Mon, 08 Apr 2024 17:31:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/0m4r" aria-label="Profile: 0m4r">@<bdi>0m4r</bdi></a><br />
Hallo.<br />
This i my config, as described in GitHub</p>
<pre><code>{
	disabled: false,
	position: "center",
	token: [b1e67..myToken..67c8c5],
<p dir="auto">Ok Danke,<br />
with superscripts it works.<br />
Why isn’t that right in GitHub?</p>
]]></description><link>https://forum.magicmirror.builders/post/116867</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116867</guid><dc:creator><![CDATA[robiv8]]></dc:creator><pubDate>Mon, 08 Apr 2024 17:31:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Mon, 08 Apr 2024 16:17:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/0m4r" aria-label="Profile: 0m4r">@<bdi>0m4r</bdi></a> yes… it works</p>
]]></description><link>https://forum.magicmirror.builders/post/116863</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116863</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 08 Apr 2024 16:17:26 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Mon, 08 Apr 2024 16:17:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> this is good, isn’t it?</p>
]]></description><link>https://forum.magicmirror.builders/post/116862</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116862</guid><dc:creator><![CDATA[0m4r]]></dc:creator><pubDate>Mon, 08 Apr 2024 16:17:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Mon, 08 Apr 2024 16:09:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/0m4r" aria-label="Profile: 0m4r">@<bdi>0m4r</bdi></a> this is what your module config looks like in  MMM-Config<br />
<img src="/assets/uploads/files/1712592521806-screenshot-at-2024-04-08-11-06-32-resized.png" alt="Screenshot at 2024-04-08 11-06-32.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/116861</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116861</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 08 Apr 2024 16:09:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Mon, 08 Apr 2024 08:57:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robiv8" aria-label="Profile: robiv8">@<bdi>robiv8</bdi></a> I think your configuration is wrong.<br />
Is the token wrapped into quotes?</p>
<pre><code>{
  disabled: false,
  module: 'MMM-euro2024',
  position: 'center',
  header: 'Euro 2024',
    token: "M4g1cM1rr0r"
]]></description><link>https://forum.magicmirror.builders/post/116857</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116857</guid><dc:creator><![CDATA[0m4r]]></dc:creator><pubDate>Mon, 08 Apr 2024 08:57:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Sun, 07 Apr 2024 19:51:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/0m4r" aria-label="Profile: 0m4r">@<bdi>0m4r</bdi></a><br />
das log sagt: Please correct syntax errors at or above this line: ReferenceError: b1e6…meinToken…67c8c5 is not defined</p>
]]></description><link>https://forum.magicmirror.builders/post/116851</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116851</guid><dc:creator><![CDATA[robiv8]]></dc:creator><pubDate>Sun, 07 Apr 2024 19:51:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Sun, 07 Apr 2024 14:17:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> this is done in version 1.0.4</p>
]]></description><link>https://forum.magicmirror.builders/post/116843</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116843</guid><dc:creator><![CDATA[0m4r]]></dc:creator><pubDate>Sun, 07 Apr 2024 14:17:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Sun, 07 Apr 2024 13:50:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robiv8" aria-label="Profile: robiv8">@<bdi>robiv8</bdi></a> hey, I am sorry to hear that.<br />
Are you able to provide some logs?</p>
]]></description><link>https://forum.magicmirror.builders/post/116842</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116842</guid><dc:creator><![CDATA[0m4r]]></dc:creator><pubDate>Sun, 07 Apr 2024 13:50:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Sun, 07 Apr 2024 13:11:50 GMT]]></title><description><![CDATA[<p dir="auto">I get a black screen when I activate the module?<br />
Original Config as in description and token available.<br />
Does anyone know what this could be?</p>
<p dir="auto">Ich bekomme einen Schwarzen Schirm wenn ich das Modul Aktiviere?<br />
Original Config wie in Beschreibung und Token vorhanden.<br />
Weiß jemand was das sein könnte?</p>
<p dir="auto">Danke<br />
Robert</p>
]]></description><link>https://forum.magicmirror.builders/post/116839</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116839</guid><dc:creator><![CDATA[robiv8]]></dc:creator><pubDate>Sun, 07 Apr 2024 13:11:50 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Sun, 07 Apr 2024 15:05:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/0m4r" aria-label="Profile: 0m4r">@<bdi>0m4r</bdi></a> i want to nudge you a little more, on the defaults.</p>
<p dir="auto">my <a href="https://github.com/sdetweil/MMM-Config" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-Config</a> module presents a form for config  customization, and it does this by discovering the parameters in the defaults section of the modulename.js.  as it sits, your module would have no parameters for the user to configure</p>
<p dir="auto">just move that one section to the modulename.js from the node helper and all will be good. no other change to your module is required because you did  that change.</p>
]]></description><link>https://forum.magicmirror.builders/post/116838</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116838</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 07 Apr 2024 15:05:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Sun, 07 Apr 2024 11:04:22 GMT]]></title><description><![CDATA[<p dir="auto">The <a href="http://README.md" target="_blank" rel="noopener noreferrer nofollow ugc">README.md</a> is updated.<br />
The configuration instructions should be now correct: <a href="https://github.com/0m4r/MMM-euro2024?tab=readme-ov-file#configuration" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/0m4r/MMM-euro2024?tab=readme-ov-file#configuration</a></p>
]]></description><link>https://forum.magicmirror.builders/post/116834</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116834</guid><dc:creator><![CDATA[0m4r]]></dc:creator><pubDate>Sun, 07 Apr 2024 11:04:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Fri, 05 Apr 2024 06:34:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanks for the detailed feedback.<br />
I will update it as soon as I get a moment :)</p>
]]></description><link>https://forum.magicmirror.builders/post/116796</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116796</guid><dc:creator><![CDATA[0m4r]]></dc:creator><pubDate>Fri, 05 Apr 2024 06:34:26 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Thu, 04 Apr 2024 10:25:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/0m4r" aria-label="Profile: 0m4r">@<bdi>0m4r</bdi></a><br />
also, the defaults go in the modulename.js not in the node_helper.js</p>
<pre><code class="language-js">defaults: {
    competitionId: 2018, // Euro 2024
    updateInterval: 60 * 1000, // 1 minute
<p dir="auto">this provides overridable properties via config.js</p>
<p dir="auto">from the doc<br />
<a href="https://docs.magicmirror.builders/development/core-module-file.html#available-module-instance-properties" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/development/core-module-file.html#available-module-instance-properties</a></p>
<p dir="auto"><img src="/assets/uploads/files/1712226330324-screenshot_20240404_052415_chrome.jpg" alt="Screenshot_20240404_052415_Chrome.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1712226343106-screenshot_20240404_052424_chrome.jpg" alt="Screenshot_20240404_052424_Chrome.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/116787</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116787</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 04 Apr 2024 10:25:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Thu, 04 Apr 2024 10:31:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/0m4r" aria-label="Profile: 0m4r">@<bdi>0m4r</bdi></a> the sample is missing the config:{} section</p>
<pre><code class="language-text">{
  disabled: false,
  position: "bottom_center",
  defaults: {
    updateInterval: 60 * 1000, // one minute
  token: [YOUR_TOKEN]
<p dir="auto">should be</p>
  disabled: false,
  config:{
       token: [YOUR_TOKEN]
<p dir="auto">your module passes this.config to the node_helper, but there is no config block, so only {} gets passed</p>
<pre><code class="language-js">this.sendSocketNotification(this.name + 'CONFIG', this.config);
]]></description><link>https://forum.magicmirror.builders/post/116786</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116786</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 04 Apr 2024 10:31:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Thu, 04 Apr 2024 07:21:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chrisfr1976" aria-label="Profile: chrisfr1976">@<bdi>chrisfr1976</bdi></a> can you share the config you set up for the module (obviously hiding the token)? Apart from a problem with the token itself, I cannot think of anything wrong with what you describe.</p>
]]></description><link>https://forum.magicmirror.builders/post/116784</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116784</guid><dc:creator><![CDATA[0m4r]]></dc:creator><pubDate>Thu, 04 Apr 2024 07:21:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Wed, 03 Apr 2024 19:47:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chrisfr1976" aria-label="Profile: chrisfr1976">@<bdi>chrisfr1976</bdi></a> what is the module property for the api key?  that is what ‘token’ means.</p>
<p dir="auto">and typically [apikey]<br />
means replace all that with the quoted string of the apikey</p>
]]></description><link>https://forum.magicmirror.builders/post/116760</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116760</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 03 Apr 2024 19:47:30 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Wed, 03 Apr 2024 17:46:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/0m4r" aria-label="Profile: 0m4r">@<bdi>0m4r</bdi></a>  There is a problem with the token. I think, I’m stupid, but:</p>
<p dir="auto">You write for the config <code>token: [YOUR_TOKEN] </code></p>
<p dir="auto">So I’ve tried <code>token:[1234567890],</code> With this I get an error in the config.js and the mirror does not start up.<br />
Then I’ve tried <code>token:1234567890,</code>. Same issue.<br />
Then I’ve tried <code>token:"1234567890",</code> Then the config.js is okay and electron starts. But in this case I get an error message:<br />
<code>[ERROR] MMM-euro2024 fetchTeams 2018 {"message":"Your API token is invalid.","errorCode":400} </code></p>
<p dir="auto">…of course I received a real API-key from Daniel. Copy+paste, so the key real in my config is okay.</p>
<p dir="auto">How should I enter the API-Key? :thinking_face:</p>
]]></description><link>https://forum.magicmirror.builders/post/116758</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116758</guid><dc:creator><![CDATA[chrisfr1976]]></dc:creator><pubDate>Wed, 03 Apr 2024 17:46:38 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-euro2024 on Mon, 01 Apr 2024 17:21:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/0m4r" aria-label="Profile: 0m4r">@<bdi>0m4r</bdi></a> Nice! Thanks! 👏<br />
Don’t forget to add it to <a href="https://github.com/MagicMirrorOrg/MagicMirror/wiki/3rd-party-modules" target="_blank" rel="noopener noreferrer nofollow ugc">the module list</a> 🙂</p>
]]></description><link>https://forum.magicmirror.builders/post/116711</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116711</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Mon, 01 Apr 2024 17:21:13 GMT</pubDate></item></channel></rss>
