<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Fuel]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">There seems something has changed with the MMM-Fuel that it does not work.<br />
When starting up MagicMirror the MMM-Fuel gives the following error message - as attached below :<br />
[01.04.2024 16:43.25.295] [LOG]   [MMM-Fuel]Failed to refresh token FetchError: invalid json response body at <a href="https://api.onegov.nsw.gov.au/oauth/client_credential/accesstoken?grant_type=client_credentials" target="_blank" rel="noopener noreferrer nofollow ugc">https://api.onegov.nsw.gov.au/oauth/client_credential/accesstoken?grant_type=client_credentials</a> reason: Unexpected token ‘&lt;’, "&lt;!DOCTYPE "… is not valid JSON<br />
at /home/pi/MagicMirror/modules/MMM-Fuel/node_modules/node-fetch/lib/index.js:272:32<br />
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)<br />
at async refreshToken (/home/pi/MagicMirror/modules/MMM-Fuel/apis/nsw.js:47:32)<br />
at async module.exports (/home/pi/MagicMirror/modules/MMM-Fuel/apis/nsw.js:218:5)<br />
at async Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Fuel/node_helper.js:25:33) {<br />
type: ‘invalid-json’<br />
}</p>
<p dir="auto">Can some please tell us what is the problem and how it can be fixed.</p>
<p dir="auto">Thank you and much appreciated.<br />
Regards,<br />
Neel.</p>
]]></description><link>https://forum.magicmirror.builders/topic/18619/mmm-fuel</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 03:32:26 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18619.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 Apr 2024 05:48:00 GMT</pubDate><ttl>60</ttl></channel></rss>
