<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Google assistant]]></title><description><![CDATA[<p dir="auto">Hello, I have a problem with the Google Assistant Module with the magic mirror on raspberrypi 3 model b. The problem is when I write the auth_and_test.js node command, the file with this name is not found, and you write run token also does not work, although I changed all the previous steps correctly and the credential file was completed in the module.</p>
<p dir="auto"><img src="/assets/uploads/files/1712562243349-img-20240406-wa0000.jpg" alt="IMG-20240406-WA0000.jpg" class=" img-fluid img-markdown" /> ```</p>
]]></description><link>https://forum.magicmirror.builders/topic/18638/google-assistant</link><generator>RSS for Node</generator><lastBuildDate>Thu, 10 Sep 2026 14:21:59 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18638.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Apr 2024 07:44:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Google assistant on Sun, 14 Apr 2024 11:45:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ahmed245275111" aria-label="Profile: ahmed245275111">@<bdi>ahmed245275111</bdi></a> I recommend opening a topic on the authors own forums. as he prefers support there</p>
]]></description><link>https://forum.magicmirror.builders/post/116996</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116996</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 14 Apr 2024 11:45:50 GMT</pubDate></item></channel></rss>
