<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SmartMirror Reinstalled, worked, then failed...]]></title><description><![CDATA[<p dir="auto">So, my SmartMirror was setup once again and then it started working and will no longer start up. This is what happens when I try and force it to start.</p>
<p dir="auto">rutger@smartmirror:~/MagicMirror $ npm start dev</p>
<p dir="auto">magicmirror@2.27.0 start<br />
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js dev</p>
<p dir="auto">[2024-04-14 10:45:29.422] [LOG]   Starting MagicMirror: v2.27.0<br />
[2024-04-14 10:45:29.481] [LOG]   Loading config …<br />
[2024-04-14 10:45:29.488] [LOG]   config template file not exists, no envsubst<br />
[2024-04-14 10:45:29.495] [LOG]   Loading module helpers …<br />
[2024-04-14 10:45:29.497] [LOG]   No helper found for module: alert.<br />
[2024-04-14 10:45:29.976] [LOG]   Initializing new module helper …<br />
[2024-04-14 10:45:29.977] [LOG]   Module helper loaded: updatenotification<br />
[2024-04-14 10:45:29.979] [LOG]   No helper found for module: clock.<br />
[2024-04-14 10:45:29.981] [LOG]   No helper found for module: MMM-NsInfo.<br />
[2024-04-14 10:45:29.983] [LOG]   No helper found for module: compliments.<br />
[2024-04-14 10:45:29.984] [LOG]   No helper found for module: weather.<br />
[2024-04-14 10:45:31.036] [ERROR] (node:1578) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘core-js/modules/es.string.replace.js’<br />
Require stack:</p>
<ul>
<li>/home/rutger/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/url-signature/dist/index.umd.js</li>
<li>/home/rutger/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/google-maps-services-js/dist/serialize.js</li>
<li>/home/rutger/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/google-maps-services-js/dist/directions.js</li>
<li>/home/rutger/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/google-maps-services-js/dist/client.js</li>
<li>/home/rutger/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/google-maps-services-js/dist/geolocate.js</li>
<li>/home/rutger/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/google-maps-services-js/dist/index.js</li>
<li>/home/rutger/MagicMirror/modules/MMM-GoogleTrafficTimes/node_helper.js</li>
<li>/home/rutger/MagicMirror/js/app.js</li>
<li>/home/rutger/MagicMirror/js/electron.js<br />
at Module._resolveFilename (node:internal/modules/cjs/loader:1055:15)<br />
at s._resolveFilename (node:electron/js2c/browser_init:2:115690)<br />
at Module._resolveFilename (/home/rutger/MagicMirror/node_modules/module-alias/index.js:49:29)<br />
at Module._load (node:internal/modules/cjs/loader:908:27)<br />
at c._load (node:electron/js2c/node_init:2:13672)<br />
at Module.require (node:internal/modules/cjs/loader:1122:19)<br />
at require (node:internal/modules/helpers:130:18)<br />
at /home/rutger/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/url-signature/dist/index.umd.js:1:79<br />
at Object. (/home/rutger/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/url-signature/dist/index.umd.js:1:807)<br />
at Module._compile (node:internal/modules/cjs/loader:1256:14)<br />
at Module._extensions…js (node:internal/modules/cjs/loader:1311:10)<br />
at Module.load (node:internal/modules/cjs/loader:1098:32)<br />
at Module._load (node:internal/modules/cjs/loader:945:12)<br />
(Use <code>electron --trace-warnings ...</code> to show where the warning was created)<br />
[2024-04-14 10:45:31.059] [ERROR] (node:1578) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag <code>--unhandled-rejections=strict</code> (see <a href="https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode" target="_blank" rel="noopener noreferrer nofollow ugc">https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode</a>). (rejection id: 1)<br />
[2024-04-14 10:45:40.165] [INFO]  System information:</li>
</ul>
<h3>SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Rev 1.2; raspberry: [object Object]; virtual: false</h3>
<h3>OS:       platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v7+</h3>
<h3>VERSIONS: electron: 29.3.0; used node: 20.9.0; installed node: 20.8.0; npm: 10.1.0; pm2: 5.3.1</h3>
<h3>OTHER:    timeZone: Europe/Amsterdam; ELECTRON_ENABLE_GPU: undefined</h3>
]]></description><link>https://forum.magicmirror.builders/topic/18656/smartmirror-reinstalled-worked-then-failed</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 17:54:01 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18656.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 14 Apr 2024 08:52:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to SmartMirror Reinstalled, worked, then failed... on Sun, 14 Apr 2024 11:18:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rutgerm" aria-label="Profile: rutgerm">@<bdi>rutgerm</bdi></a> .MMM-GoogleTrafficTimes</p>
<p dir="auto">did you update your system?</p>
<p dir="auto">please go to that module folder and do<br />
npm install</p>
]]></description><link>https://forum.magicmirror.builders/post/116993</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/116993</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 14 Apr 2024 11:18:19 GMT</pubDate></item></channel></rss>
