<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Noob problem: updated config file not showing changes in the application]]></title><description><![CDATA[<p dir="auto">Hi Everyone,</p>
<p dir="auto">I am an excited new user of MagicMirror but I am also a beginner. I have been able to get MM installed on my Windows Machine and successfully launched!</p>
<p dir="auto">However, I am running into issue with editing the config file. I use a text editor to make edits, run the config check to make sure there are no syntax errors, but when I launch the application, it shows the outputs from the original config file rather than the edits I have made to that same file.</p>
<p dir="auto">What am I doing wrong?</p>
<p dir="auto">All help much appreciated.</p>
<p dir="auto">Thanks</p>
<p dir="auto">Jon</p>
]]></description><link>https://forum.magicmirror.builders/topic/18658/noob-problem-updated-config-file-not-showing-changes-in-the-application</link><generator>RSS for Node</generator><lastBuildDate>Sun, 16 Aug 2026 00:58:45 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18658.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Apr 2024 20:32:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Noob problem: updated config file not showing changes in the application on Tue, 16 Apr 2024 18:00:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I was editing the sample. How embarrassing! I am away to the races now though :)</p>
<p dir="auto">Thanks so much for the rapid response.</p>
]]></description><link>https://forum.magicmirror.builders/post/117038</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117038</guid><dc:creator><![CDATA[jwin]]></dc:creator><pubDate>Tue, 16 Apr 2024 18:00:44 GMT</pubDate></item><item><title><![CDATA[Reply to Noob problem: updated config file not showing changes in the application on Mon, 15 Apr 2024 21:20:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jwin" aria-label="Profile: jwin">@<bdi>jwin</bdi></a> can you show me an example of a change?</p>
<p dir="auto">and the messages from npm start</p>
<p dir="auto">you ARE editing config.js,  right<br />
after you created it by copying the sample</p>
]]></description><link>https://forum.magicmirror.builders/post/117013</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117013</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 15 Apr 2024 21:20:47 GMT</pubDate></item></channel></rss>
