<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-NetatmoThermostat]]></title><description><![CDATA[<h1>MMM-NetatmoThermostat</h1>
<p dir="auto"><img src="https://github.com/bugsounet/MMM-NetatmoThermostat/blob/dev/resources/netatmo-logo.png?raw=true" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">This module display your Netatmo Thermostat informations on MirrorMirror²</p>
<h2>Screenshoot</h2>
<ul>
<li>Cooling:</li>
</ul>
<p dir="auto"><img src="https://github.com/bugsounet/MMM-NetatmoThermostat/blob/dev/resources/A_Screenshot_0.png?raw=true" alt="" class=" img-fluid img-markdown" /></p>
<ul>
<li>Heating:</li>
</ul>
<p dir="auto"><img src="https://github.com/bugsounet/MMM-NetatmoThermostat/blob/dev/resources/A_Screenshot_1.png?raw=true" alt="" class=" img-fluid img-markdown" /></p>
<h2>Informations</h2>
<p dir="auto">Just checkout <a href="https://github.com/bugsounet/https://github.com/bugsounet/MMM-NetatmoThermostat" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-NetatmoThermostat</a> GitHub repository</p>
]]></description><link>https://forum.magicmirror.builders/topic/18690/mmm-netatmothermostat</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 04:33:16 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18690.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 27 Apr 2024 09:45:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-NetatmoThermostat on Wed, 12 Jun 2024 16:43:14 GMT]]></title><description><![CDATA[<h1>Update v1.1.0</h1>
<hr />
<p dir="auto"><strong>Change Log</strong></p>
<p dir="auto">Update Deps:</p>
<ul>
<li>esbuild</li>
</ul>
<p dir="auto">Fix:</p>
<ul>
<li>refresh_token on start</li>
</ul>
<p dir="auto">Add:</p>
<ul>
<li>save new token in <code>token.json</code> file</li>
</ul>
<hr />
<p dir="auto"><strong>In accord with new API of Netatmo:</strong></p>
<p dir="auto">New token is now writed into a file (token.json)</p>
<p dir="auto"><code>refresh_tohen</code> feature in config file will be now used only on FIRST TIME for starting the module (token.json file don’t exist) and as usual you have to take it in <code>Netatmo Connect</code> website<br />
All next token will be writed in <code>token.json</code> file automaticaly</p>
<p dir="auto">On restart MagicMiror²: <code>MMM-NetatmoThermostat</code> will use <code>token.json</code> file for authenticate and will ignore <code>refresh_token</code> config feature</p>
]]></description><link>https://forum.magicmirror.builders/post/118234</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118234</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Wed, 12 Jun 2024 16:43:14 GMT</pubDate></item></channel></rss>
