<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Trash schedule module]]></title><description><![CDATA[<p dir="auto">Hello reader,<br />
I want to add some type of module to my screen that tells me if it’s a “trash only” week, or a “trash and recycling” week.</p>
<p dir="auto">I have a month calendar module up already, so I thought I could create two separate calendars and code them green/blue on pick-up days.</p>
<p dir="auto">Ideally, I would prefer a separate part of my screen to show on Mondays and Tuesdays “take the trash out!” or “take both cans out!”</p>
<p dir="auto">Does such a module exist? I looked through different forums and scheduling modules, but didn’t see any that I could manipulate into what I need.</p>
]]></description><link>https://forum.magicmirror.builders/topic/18706/trash-schedule-module</link><generator>RSS for Node</generator><lastBuildDate>Mon, 05 Oct 2026 14:56:21 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18706.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 30 Apr 2024 12:33:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Trash schedule module on Wed, 22 May 2024 19:37:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/angelikittyx" aria-label="Profile: angeliKITTYx">@<bdi>angeliKITTYx</bdi></a></p>
<p dir="auto">MyGarbge should work for you, it works with icons though. It uses a static CSV-file which you can build from a template that is part of the module.</p>
<p dir="auto">The nice thing is, if you have a shift in day (due to holiday) this works with this module by just changing the day. I added a red trash can for off-schedule weeks as visual indicator.</p>
]]></description><link>https://forum.magicmirror.builders/post/117907</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117907</guid><dc:creator><![CDATA[Feedy88]]></dc:creator><pubDate>Wed, 22 May 2024 19:37:56 GMT</pubDate></item><item><title><![CDATA[Reply to Trash schedule module on Sun, 05 May 2024 14:07:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/angelikittyx" aria-label="Profile: angeliKITTYx">@<bdi>angeliKITTYx</bdi></a> I’ve been using <a href="https://github.com/jclarke0000/MMM-MyWastePickup" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/jclarke0000/MMM-MyWastePickup</a> for years and it’s 100% customizable and not Toronto specific. You just edit the custom schedule file to set the days for your garbage/recycling pick up.</p>
]]></description><link>https://forum.magicmirror.builders/post/117503</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117503</guid><dc:creator><![CDATA[ricochetd]]></dc:creator><pubDate>Sun, 05 May 2024 14:07:13 GMT</pubDate></item><item><title><![CDATA[Reply to Trash schedule module on Thu, 02 May 2024 18:52:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mumblebaj" aria-label="Profile: mumblebaj">@<bdi>mumblebaj</bdi></a> ill try out that first one. The second link looks like it only works for a Toronto database.</p>
]]></description><link>https://forum.magicmirror.builders/post/117467</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117467</guid><dc:creator><![CDATA[angeliKITTYx]]></dc:creator><pubDate>Thu, 02 May 2024 18:52:02 GMT</pubDate></item><item><title><![CDATA[Reply to Trash schedule module on Thu, 02 May 2024 18:49:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> yes, as I explained in my original post, that was my back-up plan. I was hoping for a separate module if possible.</p>
]]></description><link>https://forum.magicmirror.builders/post/117466</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117466</guid><dc:creator><![CDATA[angeliKITTYx]]></dc:creator><pubDate>Thu, 02 May 2024 18:49:40 GMT</pubDate></item><item><title><![CDATA[Reply to Trash schedule module on Thu, 02 May 2024 09:05:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/angelikittyx" aria-label="Profile: angeliKITTYx">@<bdi>angeliKITTYx</bdi></a> You might want to look and see if your trash company provides a calendar that can be added to yours, then you can use a simple calendar app to show the schedule. Mine (Waste Management) does so and it’s a great no-nonsense method.</p>
]]></description><link>https://forum.magicmirror.builders/post/117458</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117458</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Thu, 02 May 2024 09:05:47 GMT</pubDate></item><item><title><![CDATA[Reply to Trash schedule module on Thu, 02 May 2024 08:52:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/angelikittyx" aria-label="Profile: angeliKITTYx">@<bdi>angeliKITTYx</bdi></a> You may want to have a look at <a href="https://github.com/htilburgs/MMM-MyGarbage" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-MyGarbage</a>. Looks like it may do what you want. You can setup your own schedule with it.</p>
<p dir="auto">OR</p>
<p dir="auto">You could look at the following one as well.<br />
<a href="https://github.com/jclarke0000/MMM-MyWastePickup" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-MyWastePickup</a></p>
]]></description><link>https://forum.magicmirror.builders/post/117457</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117457</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Thu, 02 May 2024 08:52:21 GMT</pubDate></item><item><title><![CDATA[Reply to Trash schedule module on Wed, 01 May 2024 19:53:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Just tried this out and unfortunately <a href="https://github.com/sabo10o29/MMM-SimpleNotifyTrashDay" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-SimpleTrashDay</a> won’t work.</p>
<p dir="auto">Our trash is every week, and recycling is every other week, so it’s not consistently “the 1st and 3rd week of the month”.</p>
]]></description><link>https://forum.magicmirror.builders/post/117453</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117453</guid><dc:creator><![CDATA[angeliKITTYx]]></dc:creator><pubDate>Wed, 01 May 2024 19:53:50 GMT</pubDate></item><item><title><![CDATA[Reply to Trash schedule module on Tue, 30 Apr 2024 18:42:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> weird - first time I searched, the only ones that came up were specific city databases. I see the locally customizable one now. Thanks! I’ll try that out.</p>
]]></description><link>https://forum.magicmirror.builders/post/117432</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117432</guid><dc:creator><![CDATA[angeliKITTYx]]></dc:creator><pubDate>Tue, 30 Apr 2024 18:42:57 GMT</pubDate></item><item><title><![CDATA[Reply to Trash schedule module on Tue, 30 Apr 2024 12:49:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/angelikittyx" aria-label="Profile: angeliKITTYx">@<bdi>angeliKITTYx</bdi></a> look thru the new 3rd party modules list<br />
<a href="https://kristjanesperanto.github.io/MagicMirror-3rd-Party-Modules/" target="_blank" rel="noopener noreferrer nofollow ugc">https://kristjanesperanto.github.io/MagicMirror-3rd-Party-Modules/</a></p>
<p dir="auto">you can search</p>
<p dir="auto">there are 3 that come up for trash</p>
]]></description><link>https://forum.magicmirror.builders/post/117428</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117428</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 30 Apr 2024 12:49:42 GMT</pubDate></item></channel></rss>
