<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PAJ7620u2 Sensor (Grove Gesture)]]></title><description><![CDATA[<p dir="auto">i everyone, I installed this PAJ7620u2 Sensor (Grove Gesture) on MM, it works very well, but if possible I would like to send a command with one of the available gestures to suspend and turn on the HDMI monitor of the Raspberry Pi4. Any help would be appreciated, thank you very much</p>
]]></description><link>https://forum.magicmirror.builders/topic/18709/paj7620u2-sensor-grove-gesture</link><generator>RSS for Node</generator><lastBuildDate>Wed, 19 Aug 2026 15:07:16 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18709.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 May 2024 13:22:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PAJ7620u2 Sensor (Grove Gesture) on Sat, 04 May 2024 07:28:35 GMT]]></title><description><![CDATA[<p dir="auto">hi,<br />
yes I am using MMM-GroveGestures, and I would like to suspend the screen for example with “CLOCKWISE”  and reactivate it with “ANTICLOCKWISE”</p>
]]></description><link>https://forum.magicmirror.builders/post/117487</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117487</guid><dc:creator><![CDATA[Dennys1]]></dc:creator><pubDate>Sat, 04 May 2024 07:28:35 GMT</pubDate></item><item><title><![CDATA[Reply to PAJ7620u2 Sensor (Grove Gesture) on Fri, 03 May 2024 14:22:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dennys1" aria-label="Profile: Dennys1">@<bdi>Dennys1</bdi></a><br />
Are you using MMM-GroveGesture?</p>
]]></description><link>https://forum.magicmirror.builders/post/117470</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117470</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Fri, 03 May 2024 14:22:54 GMT</pubDate></item></channel></rss>
