<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-CalendarExt3Agenda no longer works after a certain time.]]></title><description><![CDATA[<p dir="auto">I have completely set up the MagicMirror, which means all modules are configured and display the data correctly.<br />
The modules likely to be affected by the problem are:<br />
Calendar module, shows all dates.<br />
MMM-CalendarExt3, gets the data and displays it correctly.<br />
MMM-CalendarExt3Agenda, gets the data and displays it correctly.<br />
What can be said about the MMM-CalendarExt3Agenda module is that it changes the data. See post here:<br />
<a href="https://forum.magicmirror.builders/topic/18707/modul-calendarext3agenda/12?page=2">https://forum.magicmirror.builders/topic/18707/modul-calendarext3agenda/12?page=2</a></p>
<p dir="auto">Now I put the MagicMirror in the right place and noticed the following error.<br />
After about 40 minutes of running time, no more data will be displayed in the MMM-CalendarExt3Agenda module.<br />
Only an empty mini calendar is displayed.</p>
<p dir="auto">The other modules (Calendar and MMM-CalendarExt3) display the data.</p>
<p dir="auto">Does anyone know the problem or can help me troubleshoot?</p>
]]></description><link>https://forum.magicmirror.builders/topic/18713/mmm-calendarext3agenda-no-longer-works-after-a-certain-time</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 07:33:02 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18713.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 05 May 2024 18:14:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda no longer works after a certain time. on Thu, 09 May 2024 05:36:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a> Hallo,<br />
now I tested the Module and it works fantasic.<br />
Thank you very much.</p>
]]></description><link>https://forum.magicmirror.builders/post/117624</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117624</guid><dc:creator><![CDATA[Old_Death]]></dc:creator><pubDate>Thu, 09 May 2024 05:36:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda no longer works after a certain time. on Tue, 07 May 2024 14:26:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a>  Sorry, I was waiting for your replay. Now I has updated the Module and I will tell you soon, if it works korrekt.<br />
Thank you.</p>
]]></description><link>https://forum.magicmirror.builders/post/117577</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117577</guid><dc:creator><![CDATA[Old_Death]]></dc:creator><pubDate>Tue, 07 May 2024 14:26:31 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda no longer works after a certain time. on Tue, 07 May 2024 07:02:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/old_death" aria-label="Profile: Old_Death">@<bdi>Old_Death</bdi></a> I updated yesterday. Did you check it?</p>
]]></description><link>https://forum.magicmirror.builders/post/117552</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117552</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Tue, 07 May 2024 07:02:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda no longer works after a certain time. on Mon, 06 May 2024 08:31:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/old_death" aria-label="Profile: Old_Death">@<bdi>Old_Death</bdi></a><br />
I found out what was wrong. I made some mistakes in my previous updates, and there is still a missing one.  I’ll fix it and update it soon.</p>
]]></description><link>https://forum.magicmirror.builders/post/117518</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117518</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Mon, 06 May 2024 08:31:31 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda no longer works after a certain time. on Mon, 06 May 2024 07:11:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/old_death" aria-label="Profile: Old_Death">@<bdi>Old_Death</bdi></a><br />
Share with me your config (<a href="mailto:eouia0819@gmail.com" target="_blank" rel="noopener noreferrer nofollow ugc">eouia0819@gmail.com</a>)</p>
]]></description><link>https://forum.magicmirror.builders/post/117516</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117516</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Mon, 06 May 2024 07:11:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt3Agenda no longer works after a certain time. on Sun, 05 May 2024 18:19:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/old_death" aria-label="Profile: Old_Death">@<bdi>Old_Death</bdi></a> said in <a href="/post/117504">MMM-CalendarExt3Agenda no longer works after a certain time.</a>:</p>
<p dir="auto">Now I put the MagicMirror in the right place and noticed the following error.</p>
<p dir="auto">what is different about this place vs the other?</p>
<p dir="auto">were there any edits to any of the MM files in this move? config, css, …</p>
<p dir="auto">the fact that the data is good on other modules implies some error on EXT3<br />
can you use a browser on another system pointed at the MM system, does the same problem occur?<br />
if so, open the developers window, ctrl-shift-i, and select the console tab and add<br />
calendarext3 to the filter field</p>
<p dir="auto">are there any errors?</p>
]]></description><link>https://forum.magicmirror.builders/post/117505</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117505</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 05 May 2024 18:19:15 GMT</pubDate></item></channel></rss>
