<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MagicMirror 2.27 Error - modules failing - not displaying output - 7May2024]]></title><description><![CDATA[<p dir="auto">Hi ;</p>
<p dir="auto">I am having problems with MM 2.27 where MMM-page-indicator does not display the 3 circle dots on MM.<br />
The program does not seem to have code error but the error is from MM.</p>
<p dir="auto">the error is attached below :<br />
defined (reading ‘appendChild’)<br />
at main.js:34:12<br />
at Array.forEach ()<br />
at createDomObjects (main.js:14:11)<br />
at Object.modulesStarted (main.js:605:4)<br />
at startModules (loader.js:37:6)<br />
at async loadNextModule (loader.js:216:6)<br />
at async loadNextModule (loader.js:209:6)<br />
(anonymous)	@	main.js:34<br />
createDomObjects	@	main.js:14<br />
modulesStarted	@	main.js:605<br />
startModules	@	loader.js:37<br />
load (async)		<br />
(anonymous)	@	loader.js:180<br />
loadFile	@	loader.js:173<br />
loadNextModule	@	loader.js:214<br />
loadNextModule	@	loader.js:209</p>
<p dir="auto">How do I look for the problem or if anyone can help.</p>
<p dir="auto">Thank you,<br />
Regards,<br />
Neel.</p>
]]></description><link>https://forum.magicmirror.builders/topic/18721/magicmirror-2-27-error-modules-failing-not-displaying-output-7may2024</link><generator>RSS for Node</generator><lastBuildDate>Wed, 19 Aug 2026 17:01:22 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18721.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 May 2024 05:37:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MagicMirror 2.27 Error - modules failing - not displaying output - 7May2024 on Wed, 08 May 2024 06:53:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> - I have now install MM 2.27 (a clean install) the third time - And the modules seem to work…I will install other modules which I need and test them…Thank you.</p>
]]></description><link>https://forum.magicmirror.builders/post/117601</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117601</guid><dc:creator><![CDATA[nkc]]></dc:creator><pubDate>Wed, 08 May 2024 06:53:55 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror 2.27 Error - modules failing - not displaying output - 7May2024 on Wed, 08 May 2024 11:28:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nkc" aria-label="Profile: nkc">@<bdi>nkc</bdi></a> thx. I deleted the duplicate post.<br />
all posts from users with reputation below 2 are reviewed before being posted on the forum.  I review every post, so patience</p>
<p dir="auto">this stops all the spam, and porn posts</p>
]]></description><link>https://forum.magicmirror.builders/post/117605</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117605</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 08 May 2024 11:28:42 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror 2.27 Error - modules failing - not displaying output - 7May2024 on Wed, 08 May 2024 06:53:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> - I have now install MM 2.27 (a clean install) the third time - And the modules seem to work…I will install other modules which I need and test them…Thank you.</p>
]]></description><link>https://forum.magicmirror.builders/post/117601</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117601</guid><dc:creator><![CDATA[nkc]]></dc:creator><pubDate>Wed, 08 May 2024 06:53:55 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror 2.27 Error - modules failing - not displaying output - 7May2024 on Wed, 08 May 2024 02:37:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nkc" aria-label="Profile: nkc">@<bdi>nkc</bdi></a> and it ran ok after that?</p>
<p dir="auto">and then how did you get your modules installed?</p>
<p dir="auto">you didn’t try to upgrade w my upgrade script?</p>
]]></description><link>https://forum.magicmirror.builders/post/117595</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117595</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 08 May 2024 02:37:01 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror 2.27 Error - modules failing - not displaying output - 7May2024 on Wed, 08 May 2024 02:02:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> : Did a clean install on a new disk of MM 2.27.</p>
]]></description><link>https://forum.magicmirror.builders/post/117593</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117593</guid><dc:creator><![CDATA[nkc]]></dc:creator><pubDate>Wed, 08 May 2024 02:02:58 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror 2.27 Error - modules failing - not displaying output - 7May2024 on Wed, 08 May 2024 01:59:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> - Used the script : bash -c  “$(curl -sL <a href="https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh</a>)”</p>
]]></description><link>https://forum.magicmirror.builders/post/117592</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117592</guid><dc:creator><![CDATA[nkc]]></dc:creator><pubDate>Wed, 08 May 2024 01:59:53 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror 2.27 Error - modules failing - not displaying output - 7May2024 on Wed, 08 May 2024 01:46:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nkc" aria-label="Profile: nkc">@<bdi>nkc</bdi></a> how did you upgrade?</p>
]]></description><link>https://forum.magicmirror.builders/post/117590</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117590</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 08 May 2024 01:46:32 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror 2.27 Error - modules failing - not displaying output - 7May2024 on Wed, 08 May 2024 01:42:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> - I upgraded my MM to MM 2.27 and saw that some of the modules did not display So I debugged and saw this Error message on the debug console.<br />
some modules have stopped displaying which uses wrapper.AppendChild () calls So when I saw this error - I am thing its got to do with the error message.<br />
(PS: all modules were working perfectly fine until after the upgrade to MM 2.27.)</p>
<p dir="auto">I am just exhausted trying to find out what the hack is going on !</p>
<p dir="auto">Thanks,<br />
Regards,<br />
Neel.</p>
]]></description><link>https://forum.magicmirror.builders/post/117589</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117589</guid><dc:creator><![CDATA[nkc]]></dc:creator><pubDate>Wed, 08 May 2024 01:42:32 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror 2.27 Error - modules failing - not displaying output - 7May2024 on Tue, 07 May 2024 11:41:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nkc" aria-label="Profile: nkc">@<bdi>nkc</bdi></a> so, how did u get here? is this after the same other weirdness problem?</p>
]]></description><link>https://forum.magicmirror.builders/post/117559</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117559</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 07 May 2024 11:41:34 GMT</pubDate></item></channel></rss>
