<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Lego MM]]></title><description><![CDATA[<p dir="auto">I didn’t feel like getting into woodwork with high chances of messing up, so I gave Lego a go (actually a cheaper Lego-alternative, that might be even better because the pieces snap more tightly together and are harder to separate).</p>
<p dir="auto">I was planning on glueing the whole thing with MEK, but thought that it would still be too prone to break and not be strong enough to hang on the wall. So for now it’s literally a Lego frame.</p>
<p dir="auto"><img src="/assets/uploads/files/1715784942891-5d1b4d65-e7b3-4cd0-8741-1a6d2b0f7b4b-resized.jpg" alt="5D1B4D65-E7B3-4CD0-8741-1A6D2B0F7B4B.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto">The spidey-cabin-element is meant to hold the Raspberry pi in place, since then we put the pi in its case, so it needs a bit more room. Good thing about Lego: I can flexibly change it.<br />
<img src="/assets/uploads/files/1715785046872-img_1697.png" alt="IMG_1697.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I used lego pieces sticking out of the frame and into the box to hold the screen in place<br />
<img src="/assets/uploads/files/1715785126509-img_1698.png" alt="IMG_1698.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">And built a one-lego-stud-wide slit (8mm) to hold a 4mm mirror in place.<br />
<img src="/assets/uploads/files/1715785175358-img_1700.png" alt="IMG_1700.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Seems to work well so far.</p>
]]></description><link>https://forum.magicmirror.builders/topic/18738/lego-mm</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Jul 2026 20:44:08 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18738.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 15 May 2024 15:00:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Lego MM on Sun, 19 May 2024 20:12:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/elisa" aria-label="Profile: elisa">@<bdi>elisa</bdi></a> Neat. I’d be worried about loosening structure over time, but, nice,</p>
]]></description><link>https://forum.magicmirror.builders/post/117864</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117864</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Sun, 19 May 2024 20:12:59 GMT</pubDate></item><item><title><![CDATA[Reply to Lego MM on Sun, 19 May 2024 04:58:40 GMT]]></title><description><![CDATA[<p dir="auto">As a Lego house here, that is AWESOME!</p>
]]></description><link>https://forum.magicmirror.builders/post/117854</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117854</guid><dc:creator><![CDATA[dlindval]]></dc:creator><pubDate>Sun, 19 May 2024 04:58:40 GMT</pubDate></item></channel></rss>
