<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Round MagicMirror]]></title><description><![CDATA[<p dir="auto">Hi!</p>
<p dir="auto">After building a raspberry for my 3d printer, i was looking for other pi uses. Then i came acros this beauty!<br />
So  i got another pi (4b) and started installing the magic mirror (with a lot of forum reading and copy/pasting/adjusting)<br />
then started collecting materials. I asked if she wanted a square or a rectangle mirror… “a round one!”.</p>
<p dir="auto">Bent and welded the outer frame, ordered a round 4mm glass, adhesive and some mirror foil.<br />
Power adaptor, power splitter and after about 2 weeks the mirror was hanging!<br />
The screen is a 24" monitor i had laying around. it is mounted with two corner brackets in the top left and right of the screen</p>
<p dir="auto">updating after holiday was a bit challenging, after fixing the bootloop, the microSD had insufficient storage.<br />
so extracted the config.js and reinstalled everything on a 32GB SD and it works again</p>
<p dir="auto">Thanks sdetweil for the install scripts<br />
Thanks Michael for the MagicMirror</p>
<p dir="auto"><img src="https://i.imgur.com/awtakWG.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://i.imgur.com/p6ru7QO.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://i.imgur.com/7OLWDqv.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/18757/round-magicmirror</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 09:52:54 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18757.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 May 2024 20:43:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Round MagicMirror on Sun, 26 May 2024 14:18:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ferby09" aria-label="Profile: ferby09">@<bdi>ferby09</bdi></a>  and the powercable is white so it is less obvious running down the wall. The netgear is a mobile router for a network connection to the pi wich i used for testing some modules</p>
]]></description><link>https://forum.magicmirror.builders/post/117956</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117956</guid><dc:creator><![CDATA[Barrel91]]></dc:creator><pubDate>Sun, 26 May 2024 14:18:36 GMT</pubDate></item><item><title><![CDATA[Reply to Round MagicMirror on Sun, 26 May 2024 08:31:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/barrel91" aria-label="Profile: Barrel91">@<bdi>Barrel91</bdi></a> Wow, I never thought about using an IEC plug for powering your mirror if you don’t have a power outlet right behind it. That’s genius and so convenient!<br />
Also, what is that Netgear device?</p>
]]></description><link>https://forum.magicmirror.builders/post/117952</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117952</guid><dc:creator><![CDATA[ferby09]]></dc:creator><pubDate>Sun, 26 May 2024 08:31:51 GMT</pubDate></item><item><title><![CDATA[Reply to Round MagicMirror on Sat, 25 May 2024 14:30:16 GMT]]></title><description><![CDATA[<p dir="auto">thanks all!<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/stephanvdplas" aria-label="Profile: stephanvdplas">@<bdi>stephanvdplas</bdi></a> i have admired your MM aswell (and copy’d a bit of your config). Nice!</p>
]]></description><link>https://forum.magicmirror.builders/post/117940</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117940</guid><dc:creator><![CDATA[Barrel91]]></dc:creator><pubDate>Sat, 25 May 2024 14:30:16 GMT</pubDate></item><item><title><![CDATA[Reply to Round MagicMirror on Thu, 23 May 2024 08:53:31 GMT]]></title><description><![CDATA[<p dir="auto">Wow, this is a nice MM!<br />
I have created a bathroom MM (<a href="https://forum.magicmirror.builders/topic/18406/bathroom-mirror/2?_=1705489145468">https://forum.magicmirror.builders/topic/18406/bathroom-mirror/2?_=1705489145468</a>) but something like this for the hallway or kitchen would be awesome. Thanks for the ideas!</p>
<p dir="auto">Regards,<br />
Stephan</p>
]]></description><link>https://forum.magicmirror.builders/post/117916</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117916</guid><dc:creator><![CDATA[stephanvdplas]]></dc:creator><pubDate>Thu, 23 May 2024 08:53:31 GMT</pubDate></item><item><title><![CDATA[Reply to Round MagicMirror on Thu, 23 May 2024 02:41:32 GMT]]></title><description><![CDATA[<p dir="auto">I have to tell you that I am awed! And really considering making a round MM now. It is fabulous!</p>
]]></description><link>https://forum.magicmirror.builders/post/117915</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117915</guid><dc:creator><![CDATA[kayakbabe]]></dc:creator><pubDate>Thu, 23 May 2024 02:41:32 GMT</pubDate></item><item><title><![CDATA[Reply to Round MagicMirror on Tue, 21 May 2024 21:01:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/barrel91" aria-label="Profile: Barrel91">@<bdi>Barrel91</bdi></a> nice work! the  Pic on the wall does show how big it is!</p>
]]></description><link>https://forum.magicmirror.builders/post/117892</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/117892</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 21 May 2024 21:01:21 GMT</pubDate></item></channel></rss>
