<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[VNC Alternative]]></title><description><![CDATA[<p dir="auto">As you may know VNC retiring the Home plan and those existing Home team will be closed on 17/06/2024. Is there any other free alternative?</p>
<p dir="auto">I always use VNC to connect to the MagicMirror, TeamViewer was not good. Are there any other good alternatives?</p>
]]></description><link>https://forum.magicmirror.builders/topic/18787/vnc-alternative</link><generator>RSS for Node</generator><lastBuildDate>Sun, 09 Aug 2026 00:37:08 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18787.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 09 Jun 2024 15:08:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to VNC Alternative on Mon, 04 Aug 2025 01:09:45 GMT]]></title><description><![CDATA[<p dir="auto">nomachine is a great and free alternative to VNC.  I have been using it to mirror my smart mirror to my laptop’s display and it works very well.</p>
]]></description><link>https://forum.magicmirror.builders/post/127698</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127698</guid><dc:creator><![CDATA[raspberrypi9]]></dc:creator><pubDate>Mon, 04 Aug 2025 01:09:45 GMT</pubDate></item><item><title><![CDATA[Reply to VNC Alternative on Thu, 31 Jul 2025 12:37:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mumblebaj" aria-label="Profile: mumblebaj">@<bdi>mumblebaj</bdi></a> I tried to investigate rpi-connect but I was not able to install it, unfortunately my raspberry pi is not reacheable anymore from smb, only SSH, no idea why.</p>
]]></description><link>https://forum.magicmirror.builders/post/127620</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127620</guid><dc:creator><![CDATA[luisestrada]]></dc:creator><pubDate>Thu, 31 Jul 2025 12:37:24 GMT</pubDate></item><item><title><![CDATA[Reply to VNC Alternative on Mon, 10 Jun 2024 17:04:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Seems like rpi-connect is still in beta. May be a viable option if no relay is required else the lag could be nasty as the turn server is located in the OK.</p>
]]></description><link>https://forum.magicmirror.builders/post/118203</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118203</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Mon, 10 Jun 2024 17:04:00 GMT</pubDate></item><item><title><![CDATA[Reply to VNC Alternative on Mon, 10 Jun 2024 16:32:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/luisestrada" aria-label="Profile: luisestrada">@<bdi>luisestrada</bdi></a> said in <a href="/post/118201">VNC Alternative</a>:</p>
<p dir="auto">I see is SSH file access, I have done that in the past</p>
<p dir="auto">sorry, don’t understand that sentence</p>
]]></description><link>https://forum.magicmirror.builders/post/118202</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118202</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 10 Jun 2024 16:32:36 GMT</pubDate></item><item><title><![CDATA[Reply to VNC Alternative on Wed, 30 Jul 2025 20:02:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I missed it as a started looking into info about bitvise and winscp. My bad.</p>
<p dir="auto">I see it is a SSH file access. I have done that in the past, I thought is was something more like VNC or Teamviewer.</p>
]]></description><link>https://forum.magicmirror.builders/post/118201</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118201</guid><dc:creator><![CDATA[luisestrada]]></dc:creator><pubDate>Wed, 30 Jul 2025 20:02:41 GMT</pubDate></item><item><title><![CDATA[Reply to VNC Alternative on Mon, 10 Jun 2024 15:31:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/luisestrada" aria-label="Profile: luisestrada">@<bdi>luisestrada</bdi></a> said in <a href="/post/118193">VNC Alternative</a>:</p>
<p dir="auto">Thank you for your answer. Does this work for Mac?</p>
<p dir="auto">I said in my prior post</p>
<p dir="auto">I havent found that for Mac yet only cause I havent needed it</p>
]]></description><link>https://forum.magicmirror.builders/post/118194</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118194</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 10 Jun 2024 15:31:06 GMT</pubDate></item><item><title><![CDATA[Reply to VNC Alternative on Mon, 10 Jun 2024 15:19:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/118183">VNC Alternative</a>:</p>
<p dir="auto">ou can edit from your windows machine<br />
and if you set the MagicMirror server to allow other system access</p>
<p dir="auto">address:“0.0.0.0”,<br />
ipWhitelist :[],<br />
then you can interact/debug the MagicMirror screen anywhere you have a browser</p>
<p dir="auto">on linux you can use the caja file manager to get remot</p>
]]></description><link>https://forum.magicmirror.builders/post/118193</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118193</guid><dc:creator><![CDATA[luisestrada]]></dc:creator><pubDate>Mon, 10 Jun 2024 15:19:49 GMT</pubDate></item><item><title><![CDATA[Reply to VNC Alternative on Sun, 09 Jun 2024 15:38:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/luisestrada" aria-label="Profile: luisestrada">@<bdi>luisestrada</bdi></a> pi released a vnc<br />
replacement , and tight vnc works</p>
<p dir="auto">if you  use winscp or bitvise ssh clients you can edit from your windows machine<br />
<pre><code class="language-js">address:"0.0.0.0",
ipWhitelist :[],
<p dir="auto">then you  can interact/debug the MagicMirror screen anywhere you have a browser</p>
<p dir="auto">on linux  you can  use the caja file manager to get remote ssh filesystem access, similar to bitvise and winscp<br />
]]></description><link>https://forum.magicmirror.builders/post/118183</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118183</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 09 Jun 2024 15:38:32 GMT</pubDate></item></channel></rss>
