<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Navigate cannot be installed]]></title><description><![CDATA[<p dir="auto">I installed MMM-Navigate according to the description on <a href="https://github.com/Ax-LED/MMM-Navigate" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Ax-LED/MMM-Navigate</a>. Unfortunately, there are error messages that, as a “non-programmer”, give me no clues as to how to fix it. Here is the LOG file of the installation:</p>
<p dir="auto">0 verbose cli /usr/local/bin/node /usr/local/bin/npm<br />
1 info using npm@10.1.0<br />
2 info using node@v20.8.0<br />
3 timing npm:load:whichnode Completed in 9ms<br />
4 timing config:load:defaults Completed in 6ms<br />
5 timing config:load:file:/usr/local/lib/node_modules/npm/npmrc Completed in 2ms<br />
6 timing config:load:builtin Completed in 3ms<br />
7 timing config:load:cli Completed in 10ms<br />
8 timing config:load:env Completed in 0ms<br />
9 timing config:load:file:/home/klaus/MagicMirror/modules/MMM-Navigate/.npmrc Completed in 0ms<br />
10 timing config:load:project Completed in 16ms<br />
11 timing config:load:file:/home/klaus/.npmrc Completed in 0ms<br />
12 timing config:load:user Completed in 0ms<br />
13 timing config:load:file:/usr/local/etc/npmrc Completed in 1ms<br />
14 timing config:load:global Completed in 1ms<br />
15 timing config:load:setEnvs Completed in 8ms<br />
16 timing config:load Completed in 51ms<br />
17 timing npm:load:configload Completed in 51ms<br />
18 timing config:load:flatten Completed in 15ms<br />
19 timing npm:load:mkdirpcache Completed in 2ms<br />
20 timing npm:load:mkdirplogs Completed in 1ms<br />
21 verbose title npm install<br />
22 verbose argv “install”<br />
23 timing npm:load:setTitle Completed in 2ms<br />
24 timing npm:load:display Completed in 8ms<br />
25 verbose logfile logs-max:10 dir:/home/klaus/.npm/_logs/2024-06-12T12_09_51_699Z-<br />
26 verbose logfile /home/klaus/.npm/_logs/2024-06-12T12_09_51_699Z-debug-0.log<br />
27 timing npm:load:logFile Completed in 40ms<br />
28 timing npm:load:timers Completed in 1ms<br />
29 timing npm:load:configScope Completed in 0ms<br />
30 timing npm:load Completed in 201ms<br />
31 timing arborist:ctor Completed in 8ms<br />
32 silly logfile start cleaning logs, removing 2 files<br />
33 timing arborist:ctor Completed in 0ms<br />
34 silly logfile done cleaning log files<br />
35 timing idealTree:init Completed in 98ms<br />
36 timing idealTree:userRequests Completed in 2ms<br />
37 silly idealTree buildDeps<br />
38 silly fetch manifest onoff@latest<br />
39 http fetch GET 200 <a href="https://registry.npmjs.org/onoff" target="_blank" rel="noopener noreferrer nofollow ugc">https://registry.npmjs.org/onoff</a> 1321ms (cache revalidated)<br />
40 silly placeDep ROOT onoff@6.0.3 OK for: MagicMirror-Module-Navigate@1.6.0 want: latest<br />
41 silly fetch manifest epoll@^4.0.1<br />
42 silly fetch manifest lodash.debounce@^4.0.8<br />
43 http fetch GET 200 <a href="https://registry.npmjs.org/lodash.debounce" target="_blank" rel="noopener noreferrer nofollow ugc">https://registry.npmjs.org/lodash.debounce</a> 247ms (cache revalidated)<br />
44 http fetch GET 200 <a href="https://registry.npmjs.org/epoll" target="_blank" rel="noopener noreferrer nofollow ugc">https://registry.npmjs.org/epoll</a> 1028ms (cache revalidated)<br />
45 timing idealTree:#root Completed in 2418ms<br />
46 silly placeDep ROOT epoll@4.0.2 OK for: onoff@6.0.3 want: ^4.0.1<br />
47 silly fetch manifest bindings@^1.5.0<br />
48 silly fetch manifest nan@^2.17.0<br />
49 silly placeDep ROOT lodash.debounce@4.0.8 OK for: onoff@6.0.3 want: ^4.0.8<br />
50 http fetch GET 200 <a href="https://registry.npmjs.org/nan" target="_blank" rel="noopener noreferrer nofollow ugc">https://registry.npmjs.org/nan</a> 162ms (cache revalidated)<br />
51 http fetch GET 200 <a href="https://registry.npmjs.org/bindings" target="_blank" rel="noopener noreferrer nofollow ugc">https://registry.npmjs.org/bindings</a> 465ms (cache revalidated)<br />
52 timing idealTree:node_modules/onoff Completed in 496ms<br />
53 silly placeDep ROOT bindings@1.5.0 OK for: epoll@4.0.2 want: ^1.5.0<br />
54 silly fetch manifest file-uri-to-path@1.0.0<br />
55 silly placeDep ROOT nan@2.20.0 OK for: epoll@4.0.2 want: ^2.17.0<br />
56 http fetch GET 200 <a href="https://registry.npmjs.org/file-uri-to-path" target="_blank" rel="noopener noreferrer nofollow ugc">https://registry.npmjs.org/file-uri-to-path</a> 148ms (cache revalidated)<br />
57 timing idealTree:node_modules/epoll Completed in 168ms<br />
58 silly placeDep ROOT file-uri-to-path@1.0.0 OK for: bindings@1.5.0 want: 1.0.0<br />
59 timing idealTree:node_modules/bindings Completed in 15ms<br />
60 timing idealTree:node_modules/file-uri-to-path Completed in 1ms<br />
61 timing idealTree:node_modules/lodash.debounce Completed in 0ms<br />
62 timing idealTree:node_modules/nan Completed in 0ms<br />
63 timing idealTree:buildDeps Completed in 3103ms<br />
64 timing idealTree:fixDepFlags Completed in 2ms<br />
65 timing idealTree Completed in 3221ms<br />
66 timing reify:loadTrees Completed in 3227ms<br />
67 timing reify:diffTrees Completed in 4ms<br />
68 silly reify moves {}<br />
69 timing reify:retireShallow Completed in 4ms<br />
70 timing reify:createSparse Completed in 9ms<br />
71 timing reify:loadBundles Completed in 0ms<br />
72 silly audit bulk request {<br />
72 silly audit   onoff: [ ‘6.0.3’ ],<br />
72 silly audit   epoll: [ ‘4.0.2’ ],<br />
72 silly audit   ‘lodash.debounce’: [ ‘4.0.8’ ],<br />
72 silly audit   bindings: [ ‘1.5.0’ ],<br />
72 silly audit   nan: [ ‘2.20.0’ ],<br />
72 silly audit   ‘file-uri-to-path’: [ ‘1.0.0’ ]<br />
72 silly audit }<br />
73 timing reifyNode:node_modules/bindings Completed in 278ms<br />
74 timing reifyNode:node_modules/lodash.debounce Completed in 284ms<br />
75 timing reifyNode:node_modules/file-uri-to-path Completed in 299ms<br />
76 timing reifyNode:node_modules/epoll Completed in 384ms<br />
77 timing reifyNode:node_modules/onoff Completed in 397ms<br />
78 timing reifyNode:node_modules/nan Completed in 417ms<br />
79 timing reify:unpack Completed in 419ms<br />
80 timing reify:unretire Completed in 0ms<br />
81 timing build:queue Completed in 5ms<br />
82 info run epoll@4.0.2 install node_modules/epoll node-gyp rebuild<br />
83 http fetch POST 200 <a href="https://registry.npmjs.org/-/npm/v1/security/advisories/bulk" target="_blank" rel="noopener noreferrer nofollow ugc">https://registry.npmjs.org/-/npm/v1/security/advisories/bulk</a> 572ms<br />
84 timing auditReport:getReport Completed in 584ms<br />
85 silly audit report {}<br />
86 timing auditReport:init Completed in 0ms<br />
87 timing reify:audit Completed in 591ms<br />
88 info run epoll@4.0.2 install { code: 0, signal: null }<br />
89 timing build:run:install:node_modules/epoll Completed in 15212ms<br />
90 timing build:run:install Completed in 15213ms<br />
91 timing build:deps Completed in 15223ms<br />
92 timing build Completed in 15223ms<br />
93 timing reify:build Completed in 15224ms<br />
94 timing reify:trash Completed in 0ms<br />
95 timing reify:save Completed in 34ms<br />
96 timing reify Completed in 19054ms<br />
97 timing command:install Completed in 19108ms<br />
98 verbose stack Error: command failed<br />
98 verbose stack     at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:53:27)<br />
98 verbose stack     at ChildProcess.emit (node:events:514:28)<br />
98 verbose stack     at maybeClose (node:internal/child_process:1105:16)<br />
98 verbose stack     at ChildProcess._handle.onexit (node:internal/child_process:305:5)<br />
99 verbose pkgid MagicMirror-Module-Navigate@1.6.0<br />
100 verbose cwd /home/klaus/MagicMirror/modules/MMM-Navigate<br />
101 verbose Linux 6.1.21-v8+<br />
102 verbose node v20.8.0<br />
103 verbose npm  v10.1.0<br />
104 error code 126<br />
105 error path /home/klaus/MagicMirror/modules/MMM-Navigate<br />
106 error command failed<br />
107 error command sh -c ./postinstall<br />
108 verbose exit 126<br />
109 timing npm Completed in 20828ms<br />
110 verbose code 126<br />
111 error A complete log of this run can be found in: /home/klaus/.npm/_logs/2024-06-12T12_09_51_699Z-debug-0.log</p>
<p dir="auto">Any tips on what I can and must do to ensure an error-free installation would be greatly appreciated.</p>
]]></description><link>https://forum.magicmirror.builders/topic/18792/mmm-navigate-cannot-be-installed</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 06:03:07 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18792.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 12 Jun 2024 14:45:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Mon, 17 Jun 2024 09:50:10 GMT]]></title><description><![CDATA[<p dir="auto">Hello Sam,<br />
Thank you for continuing to try to solve the problem.<br />
I have carried out:</p>
<p dir="auto">cd ~/MagicMirror<br />
rm -rf node_modules<br />
npm run install-mm</p>
<p dir="auto">and after that:</p>
<p dir="auto">cd modules/MMM-Navigate<br />
./postinstall</p>
<p dir="auto">without problems.</p>
<p dir="auto">Last I did:</p>
npm start</p>
<p dir="auto">This is the result:</p>
<p dir="auto">klaus@raspberrypi:~ $ cd  ~/MagicMirror<br />
klaus@raspberrypi:~/MagicMirror $ npm start</p>
<p dir="auto">magicmirror@2.27.0 start<br />
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js</p>
<p dir="auto">[2024-06-17 11:35:52.232] [LOG]   Starting MagicMirror: v2.27.0<br />
[2024-06-17 11:35:52.333] [LOG]   Loading config …<br />
[2024-06-17 11:35:52.344] [LOG]   config template file not exists, no envsubst<br />
[2024-06-17 11:35:52.354] [LOG]   Loading module helpers …<br />
[2024-06-17 11:35:52.360] [LOG]   No helper found for module: alert.<br />
[2024-06-17 11:35:53.076] [LOG]   Initializing new module helper …<br />
[2024-06-17 11:35:53.078] [LOG]   Module helper loaded: updatenotification<br />
[2024-06-17 11:35:53.080] [LOG]   No helper found for module: MMM-pages.<br />
[2024-06-17 11:35:53.081] [LOG]   No helper found for module: clock.<br />
[2024-06-17 11:35:53.466] [LOG]   Initializing new module helper …<br />
[2024-06-17 11:35:53.472] [LOG]   Module helper loaded: calendar<br />
[2024-06-17 11:35:54.236] [LOG]   Initializing new module helper …<br />
[2024-06-17 11:35:54.241] [LOG]   Module helper loaded: MMM-DWD-Pollen<br />
[2024-06-17 11:35:54.242] [LOG]   No helper found for module: compliments.<br />
[2024-06-17 11:35:54.243] [LOG]   No helper found for module: weather.<br />
[2024-06-17 11:35:54.275] [LOG]   Initializing new module helper …<br />
[2024-06-17 11:35:54.275] [LOG]   Module helper loaded: MMM-birthdays<br />
[2024-06-17 11:35:54.720] [LOG]   Initializing new module helper …<br />
[2024-06-17 11:35:54.723] [LOG]   Module helper loaded: MMM-Rest<br />
[2024-06-17 11:35:54.725] [LOG]   No helper found for module: MMM-Globe.<br />
[2024-06-17 11:35:54.725] [LOG]   No helper found for module: MMM-RAIN-MAP.<br />
[2024-06-17 11:35:54.893] [LOG]   Initializing new module helper …<br />
[2024-06-17 11:35:54.893] [LOG]   Module helper loaded: newsfeed<br />
[2024-06-17 11:35:54.893] [LOG]   All module helpers loaded.<br />
[2024-06-17 11:35:54.909] [LOG]   Starting server on port 8080 …<br />
[2024-06-17 11:35:57.767] [ERROR] Whoops! There was an uncaught exception…<br />
[2024-06-17 11:35:57.823] [ERROR] Error: listen EADDRINUSE: address already in use ::1:8080<br />
at Server.setupListenHandle [as _listen2] (node:net:1872:16)<br />
at listenInCluster (node:net:1920:12)<br />
at GetAddrInfoReqWrap.doListen [as callback] (node:net:2069:7)<br />
at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:109:8) {<br />
code: ‘EADDRINUSE’,<br />
errno: -98,<br />
syscall: ‘listen’,<br />
address: ‘::1’,<br />
port: 8080<br />
}<br />
[2024-06-17 11:35:57.850] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?<br />
[2024-06-17 11:35:57.862] [ERROR] If you think this really is an issue, please open an issue on GitHub: <a href="https://github.com/MagicMirrorOrg/MagicMirror/issues" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MagicMirrorOrg/MagicMirror/issues</a><br />
[2024-06-17 11:36:07.657] [INFO]  System information:</p>
<h3>SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.2; raspberry: [object Object]; virtual: false</h3>
<h3>OS:       platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v8+</h3>
<h3>VERSIONS: electron: 29.3.1; used node: 20.9.0; installed node: 20.8.0; npm: 10.1.0; pm2: 5.3.1</h3>
<h3>OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined</h3>
<p dir="auto">The  internet connection was stabile, it can’t be the reason  for the problem.<br />
I hope you can interpret the result and have a suggestion on how to proceed.</p>
<p dir="auto">Greetings<br />
Klaus</p>
]]></description><link>https://forum.magicmirror.builders/post/118342</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118342</guid><dc:creator><![CDATA[Klaleu]]></dc:creator><pubDate>Mon, 17 Jun 2024 09:50:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Tue, 18 Jun 2024 10:55:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klaleu" aria-label="Profile: Klaleu">@<bdi>Klaleu</bdi></a> you do.  find the message which gives the best answer, click the 3 dots in the lower right and select the option</p>
<p dir="auto">Mark this post …</p>
]]></description><link>https://forum.magicmirror.builders/post/118364</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118364</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Jun 2024 10:55:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Tue, 18 Jun 2024 07:23:06 GMT]]></title><description><![CDATA[<p dir="auto">Dear Sam,<br />
That was my first contact in the MagicMirror Forum and thanks to your help it was a complete success.<br />
My problem is now solved. Who moves the point from unresolved to resolved?</p>
Klaus</p>
]]></description><link>https://forum.magicmirror.builders/post/118363</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118363</guid><dc:creator><![CDATA[Klaleu]]></dc:creator><pubDate>Tue, 18 Jun 2024 07:23:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Mon, 17 Jun 2024 21:01:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klaleu" aria-label="Profile: Klaleu">@<bdi>Klaleu</bdi></a> fantastic!</p>
<p dir="auto">thanks for the feedback</p>
]]></description><link>https://forum.magicmirror.builders/post/118357</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118357</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 17 Jun 2024 21:01:49 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Mon, 17 Jun 2024 19:11:10 GMT]]></title><description><![CDATA[<p dir="auto">Dear Sam,<br />
Thank you very much for your help.<br />
After I did the following:</p>
<p dir="auto">pm2 stop mm</p>
<p dir="auto">and</p>
<p dir="auto">pm2 restart all</p>
<p dir="auto">The new installation of MMM-Navigate ran without errors or problems.<br />
And after I added the code in the Modules array in the config/config.js, MMM-Navigate worked.<br />
Thank you again for your help and for the time you sacrificed.</p>
<p dir="auto">Klaus</p>
]]></description><link>https://forum.magicmirror.builders/post/118356</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118356</guid><dc:creator><![CDATA[Klaleu]]></dc:creator><pubDate>Mon, 17 Jun 2024 19:11:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Mon, 17 Jun 2024 10:24:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klaleu" aria-label="Profile: Klaleu">@<bdi>Klaleu</bdi></a> sorry, I forgot to tell you to stop MagicMirror  under pm2</p>
<p dir="auto">but as the postinstall ran<br />
do</p>
<pre><code class="language-sh">pm2 restart all
]]></description><link>https://forum.magicmirror.builders/post/118344</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118344</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 17 Jun 2024 10:24:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Mon, 17 Jun 2024 09:50:10 GMT]]></title><description><![CDATA[<p dir="auto">Hello Sam,<br />
./postinstall</p>
npm start</p>
errno: -98,<br />
port: 8080<br />
}<br />
Klaus</p>
]]></description><link>https://forum.magicmirror.builders/post/118342</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118342</guid><dc:creator><![CDATA[Klaleu]]></dc:creator><pubDate>Mon, 17 Jun 2024 09:50:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Sat, 15 Jun 2024 17:28:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klaleu" aria-label="Profile: Klaleu">@<bdi>Klaleu</bdi></a> let’s try this</p>
<pre><code class="language-sh">cd ~/MagicMirror
rm -rf node_modules
npm run install-mm
<p dir="auto">then</p>
<pre><code class="language-sh">cd modules/MMM-Navigate
./postinstall
npm start
]]></description><link>https://forum.magicmirror.builders/post/118315</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118315</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 15 Jun 2024 17:28:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Sat, 15 Jun 2024 16:51:27 GMT]]></title><description><![CDATA[<p dir="auto">Ok.<br />
What would you do now if you were me? I only see one option: reinstalling the basic configuration of the Magic Mirror and then installing MMM-Navigate as the first module. Maybe a module I’ve already installed is causing access to be denied. What do you think?</p>
<p dir="auto">First of all, thank you very much for taking the time to help me.</p>
]]></description><link>https://forum.magicmirror.builders/post/118314</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118314</guid><dc:creator><![CDATA[Klaleu]]></dc:creator><pubDate>Sat, 15 Jun 2024 16:51:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Sat, 15 Jun 2024 15:15:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klaleu" aria-label="Profile: Klaleu">@<bdi>Klaleu</bdi></a> no idea.<br />
never run npm audit or npm fund</p>
]]></description><link>https://forum.magicmirror.builders/post/118313</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118313</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 15 Jun 2024 15:15:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Sat, 15 Jun 2024 14:15:24 GMT]]></title><description><![CDATA[<p dir="auto">Dear Sam,<br />
I ran the following commands:</p>
npm uninstall @electron/rebuild</p>
<p dir="auto">This was the result:</p>
klaus@raspberrypi:~/MagicMirror $ npm uninstall @electron/rebuild<br />
up to date in 19s<br />
216 packages are looking for funding<br />
run <code>npm fund</code> for details<br />
klaus@raspberrypi:~/MagicMirror $ npm fund<br />
magicmirror@2.27.0<br />
├── <a href="https://patreon.com/biodiscus" target="_blank" rel="noopener noreferrer nofollow ugc">https://patreon.com/biodiscus</a><br />
│   └── ansis@2.3.0<br />
├─┬ <a href="https://opencollective.com/eslint" target="_blank" rel="noopener noreferrer nofollow ugc">https://opencollective.com/eslint</a><br />
│ │ └── eslint@8.57.0, @eslint/eslintrc@2.1.4, eslint-scope@7.2.2, eslint-visito        r-keys@3.4.3, espree@9.6.1<br />
│ ├── <a href="https://github.com/sponsors/nzakas" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sponsors/nzakas</a><br />
│ │   └── @humanwhocodes/module-importer@1.0.1<br />
│ ├── <a href="https://github.com/sponsors/epoberezkin" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sponsors/epoberezkin</a><br />
│ │   └── ajv@6.12.6, ajv@8.12.0<br />
│ └── <a href="https://github.com/sponsors/feross" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sponsors/feross</a><br />
│     └── run-parallel@1.2.0, queue-microtask@1.2.3, buffer@5.7.1, base64-js@1.5        .1, ieee754@1.2.1, safe-buffer@5.2.1, run-series@1.1.9<br />
├── <a href="https://www.buymeacoffee.com/systeminfo" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.buymeacoffee.com/systeminfo</a><br />
│   └── systeminformation@5.22.7<br />
├─┬ <a href="https://github.com/sindresorhus/eslint-plugin-unicorn?sponsor=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sindresorhus/eslint-plugin-unicorn?sponsor=1</a><br />
│ │ └── eslint-plugin-unicorn@51.0.1<br />
│ ├── <a href="https://github.com/sponsors/sibiraj-s" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sponsors/sibiraj-s</a><br />
│ │   └── ci-info@4.0.0, ci-info@3.9.0<br />
│ └─┬ <a href="https://opencollective.com/core-js" target="_blank" rel="noopener noreferrer nofollow ugc">https://opencollective.com/core-js</a><br />
│   │ └── core-js-compat@3.37.0<br />
│   └── <a href="https://opencollective.com/browserslist" target="_blank" rel="noopener noreferrer nofollow ugc">https://opencollective.com/browserslist</a><br />
│       └── browserslist@4.23.0, caniuse-lite@1.0.30001612, update-browserslist-        db@1.0.13<br />
├── <a href="https://github.com/sponsors/typicode" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sponsors/typicode</a><br />
│   └── husky@9.0.11<br />
├─┬ <a href="https://opencollective.com/lint-staged" target="_blank" rel="noopener noreferrer nofollow ugc">https://opencollective.com/lint-staged</a><br />
│ │ └── lint-staged@15.2.2<br />
│ ├── <a href="https://github.com/chalk/chalk?sponsor=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/chalk/chalk?sponsor=1</a><br />
│ │   └── chalk@5.3.0, chalk@4.1.2<br />
│ ├─┬ <a href="https://github.com/sindresorhus/execa?sponsor=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sindresorhus/execa?sponsor=1</a><br />
│ │ │ └── execa@8.0.1, execa@5.1.1<br />
│ │ └── <a href="https://github.com/sponsors/isaacs" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sponsors/isaacs</a><br />
│ │     └── signal-exit@4.1.0, glob@8.1.0, rimraf@3.0.2<br />
│ └── <a href="https://github.com/chalk/wrap-ansi?sponsor=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/chalk/wrap-ansi?sponsor=1</a><br />
│     └── wrap-ansi@9.0.0, wrap-ansi@7.0.0<br />
├── <a href="https://github.com/prettier/prettier?sponsor=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/prettier/prettier?sponsor=1</a><br />
│   └── prettier@3.2.5<br />
├── <a href="https://opencollective.com/sinon" target="_blank" rel="noopener noreferrer nofollow ugc">https://opencollective.com/sinon</a><br />
│   └── sinon@17.0.1<br />
├─┬ <a href="https://opencollective.com/stylelint" target="_blank" rel="noopener noreferrer nofollow ugc">https://opencollective.com/stylelint</a><br />
│ │ └── stylelint@16.4.0<br />
│ ├── <a href="https://github.com/sponsors/csstools" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sponsors/csstools</a><br />
│ │   └── @csstools/css-parser-algorithms@2.6.1, @csstools/css-tokenizer@2.2.4,        @csstools/media-query-list-parser@2.1.9, @csstools/selector-specificity@3.0.3<br />
│ ├── <a href="https://github.com/sponsors/wooorm" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sponsors/wooorm</a><br />
│ │   └── @dual-bundle/import-meta-resolve@4.0.0, mathml-tag-names@2.1.3<br />
│ ├── <a href="https://github.com/sponsors/d-fischer" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sponsors/d-fischer</a><br />
│ │   └── cosmiconfig@9.0.0<br />
│ └─┬ <a href="https://opencollective.com/postcss/" target="_blank" rel="noopener noreferrer nofollow ugc">https://opencollective.com/postcss/</a><br />
│   │ └── postcss@8.4.38, postcss-safe-parser@7.0.0<br />
│   └── <a href="https://github.com/sponsors/ai" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sponsors/ai</a><br />
│       └── nanoid@3.3.7<br />
├── <a href="https://github.com/sponsors/malept" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sponsors/malept</a><br />
│   └── @malept/cross-spawn-promise@2.0.0<br />
├─┬ <a href="https://github.com/sindresorhus/got?sponsor=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sindresorhus/got?sponsor=1</a><br />
│ │ └── got@11.8.6<br />
│ └── <a href="https://github.com/sindresorhus/is?sponsor=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sindresorhus/is?sponsor=1</a><br />
│     └── @sindresorhus/is@4.6.0<br />
├── <a href="https://github.com/sponsors/ljharb" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sponsors/ljharb</a><br />
│   └── string.prototype.matchall@4.0.11, call-bind@1.0.7, function-bind@1.1.2,        define-data-property@1.1.4, has-property-descriptors@1.0.2, define-properties@1.        2.1, es-abstract@1.23.3, array-buffer-byte-length@1.0.1, arraybuffer.prototype.s        lice@1.0.3, available-typed-arrays@1.0.7, data-view-buffer@1.0.1, data-view-byte        -length@1.0.1, data-view-byte-offset@1.0.0, es-to-primitive@1.2.1, is-date-objec        t@1.0.5, is-symbol@1.0.4, <a href="http://function.prototype.name" target="_blank" rel="noopener noreferrer nofollow ugc">function.prototype.name</a>@1.1.6, functions-have-names@1.        2.3, get-symbol-description@1.0.2, globalthis@1.0.3, has-proto@1.0.3, is-array-b        uffer@3.0.4, is-callable@1.2.7, is-data-view@1.0.1, is-negative-zero@2.0.3, is-r        egex@1.1.4, is-shared-array-buffer@1.0.3, is-string@1.0.7, is-typed-array@1.1.13        , is-weakref@1.0.2, object-inspect@1.13.1, object.assign@4.1.5, safe-array-conca        t@1.1.2, safe-regex-test@1.0.3, string.prototype.trim@1.2.9, <a href="http://string.prototype.tr" target="_blank" rel="noopener noreferrer nofollow ugc">string.prototype.tr</a>        imend@1.0.8, string.prototype.trimstart@1.0.8, typed-array-byte-length@1.0.1, ty        ped-array-byte-offset@1.0.2, typed-array-length@1.0.6, unbox-primitive@1.0.2, ha        s-bigints@1.0.2, which-boxed-primitive@1.0.2, is-bigint@1.0.4, is-boolean-object        @1.1.2, is-number-object@1.0.7, which-typed-array@1.1.15, has-tostringtag@1.0.2,        get-intrinsic@1.2.4, gopd@1.0.1, has-symbols@1.0.3, regexp.prototype.flags@1.5.        2, side-channel@1.0.6, minimist@1.2.8, qs@6.11.0, resolve@1.22.8, is-core-module        @2.13.1, supports-preserve-symlinks-flag@1.0.0, array-includes@3.1.8, array.prot        otype.findlastindex@1.2.5, array.prototype.flat@1.3.2, array.prototype.flatmap@1        .3.2, object.fromentries@2.0.8, object.values@1.2.0<br />
├─┬ <a href="https://ko-fi.com/killymxi" target="_blank" rel="noopener noreferrer nofollow ugc">https://ko-fi.com/killymxi</a><br />
│ │ └── @selderee/plugin-htmlparser2@0.11.0, selderee@0.11.0, parseley@0.12.1, l        eac@0.6.0, peberminta@0.9.0<br />
│ └─┬ <a href="https://github.com/fb55/domhandler?sponsor=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/fb55/domhandler?sponsor=1</a><br />
│   │ └── domhandler@5.0.3<br />
│   └── <a href="https://github.com/sponsors/fb55" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sponsors/fb55</a><br />
│       └── domelementtype@2.3.0<br />
├─┬ <a href="https://github.com/cheeriojs/dom-serializer?sponsor=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/cheeriojs/dom-serializer?sponsor=1</a><br />
│ │ └── dom-serializer@2.0.0<br />
│ └── <a href="https://github.com/fb55/entities?sponsor=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/fb55/entities?sponsor=1</a><br />
│     └── entities@4.5.0<br />
├─┬ <a href="https://github.com/fb55/htmlparser2?sponsor=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/fb55/htmlparser2?sponsor=1</a><br />
│ │ └── htmlparser2@8.0.2<br />
│ └── <a href="https://github.com/fb55/domutils?sponsor=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/fb55/domutils?sponsor=1</a><br />
│     └── domutils@3.1.0<br />
├── <a href="https://github.com/sponsors/broofa" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sponsors/broofa</a><br />
│   └── uuid@9.0.1<br />
├── <a href="https://github.com/sponsors/RubenVerborgh" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sponsors/RubenVerborgh</a><br />
│   └── follow-redirects@1.15.6<br />
├─┬ <a href="https://paulmillr.com/funding/" target="_blank" rel="noopener noreferrer nofollow ugc">https://paulmillr.com/funding/</a><br />
│ │ └── chokidar@3.6.0<br />
│ └── <a href="https://github.com/sponsors/jonschlinkert" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sponsors/jonschlinkert</a><br />
│     └── picomatch@2.3.1, picomatch@4.0.2<br />
├── <a href="https://opencollective.com/typescript-eslint" target="_blank" rel="noopener noreferrer nofollow ugc">https://opencollective.com/typescript-eslint</a><br />
│   └── @typescript-eslint/utils@5.62.0, @typescript-eslint/scope-manager@5.62.0        , @typescript-eslint/visitor-keys@5.62.0, @typescript-eslint/types@5.62.0, @type        script-eslint/typescript-estree@5.62.0<br />
├── <a href="https://github.com/sponsors/ota-meshi" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sponsors/ota-meshi</a><br />
│   └── jsonc-eslint-parser@2.4.0<br />
├── <a href="https://github.com/fisker/git-hooks-list?sponsor=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/fisker/git-hooks-list?sponsor=1</a><br />
│   └── git-hooks-list@1.0.3<br />
├── <a href="https://opencollective.com/babel" target="_blank" rel="noopener noreferrer nofollow ugc">https://opencollective.com/babel</a><br />
│   └── @babel/core@7.24.4<br />
├── <a href="https://github.com/chalk/supports-color?sponsor=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/chalk/supports-color?sponsor=1</a><br />
│   └── supports-color@8.1.1<br />
├── <a href="https://github.com/sponsors/dubzzz" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sponsors/dubzzz</a><br />
│   └── pure-rand@6.1.0<br />
├── <a href="https://github.com/sindresorhus/emittery?sponsor=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sindresorhus/emittery?sponsor=1</a><br />
│   └── emittery@0.13.1<br />
└── <a href="https://github.com/inikulin/parse5?sponsor=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/inikulin/parse5?sponsor=1</a><br />
└── parse5@7.1.2</p>
<p dir="auto">After that I executed these commands:</p>
./postinstall</p>
<p dir="auto">klaus@raspberrypi:~/MagicMirror $ cd modules/MMM-Navigate<br />
klaus@raspberrypi:~/MagicMirror/modules/MMM-Navigate $  ./postinstall<br />
./postinstall: line 8: …/…/node_modules/.bin/electron-rebuild: Permission denied<br />
klaus@raspberrypi:~/MagicMirror/modules/MMM-Navigate $</p>
<p dir="auto">and  and  postinstall is not carried out.</p>
<p dir="auto">I hope you can interpret the results.</p>
]]></description><link>https://forum.magicmirror.builders/post/118312</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118312</guid><dc:creator><![CDATA[Klaleu]]></dc:creator><pubDate>Sat, 15 Jun 2024 14:15:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Fri, 14 Jun 2024 19:03:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klaleu" aria-label="Profile: Klaleu">@<bdi>Klaleu</bdi></a> said in <a href="/post/118296">MMM-Navigate cannot be installed</a>:</p>
<p dir="auto">and sent the results to you.</p>
<p dir="auto">where?  I am not the module author. I don’t see a text message here from you<br />
and I didn’t give you my email</p>
<p dir="auto">edit: sorry, I found it, burried in other messages,</p>
<p dir="auto">very weird… SO, try this</p>
<p dir="auto">then , to see if this is fixed by having the postinstall script reinstall it…</p>
./postinstall
<p dir="auto">this approach was copied from me, so I am confused why it is failing</p>
]]></description><link>https://forum.magicmirror.builders/post/118297</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118297</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 14 Jun 2024 19:03:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Fri, 14 Jun 2024 17:47:48 GMT]]></title><description><![CDATA[<p dir="auto">Dear Sam,<br />
Yes, I have already executed these commands:</p>
<p dir="auto">ls -laF ~/MagicMirror/node_modules/.bin/electron-rebuild<br />
and<br />
ls -laF node_modules/.bin/electron-rebuild-</p>
<p dir="auto">and sent the results to you.<br />
Please tell me what I did wrong so that the results were not meaningful for you.</p>
<p dir="auto">A nice Weekend for you.</p>
]]></description><link>https://forum.magicmirror.builders/post/118296</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118296</guid><dc:creator><![CDATA[Klaleu]]></dc:creator><pubDate>Fri, 14 Jun 2024 17:47:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Fri, 14 Jun 2024 17:08:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klaleu" aria-label="Profile: Klaleu">@<bdi>Klaleu</bdi></a> see here<br />
<a href="https://forum.magicmirror.builders/post/118270">https://forum.magicmirror.builders/post/118270</a><br />
and here<br />
<a href="https://forum.magicmirror.builders/post/118252">https://forum.magicmirror.builders/post/118252</a></p>
]]></description><link>https://forum.magicmirror.builders/post/118295</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118295</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 14 Jun 2024 17:08:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Fri, 14 Jun 2024 17:05:01 GMT]]></title><description><![CDATA[<p dir="auto">Hello Sam,<br />
You wrote: " I need you to execute the command I listed, now and show it’s results"<br />
Now I’m a little bit confused. I executed severel commands you asked my for and dokumented the results.<br />
Please write to me exactly what I need to do to provide you with the information to isolate the problem. Unfortunately, I’m just a layman and can’t get any further in this case on my own and need help from experienced programmers.<br />
Thank you.<br />
Klaus</p>
]]></description><link>https://forum.magicmirror.builders/post/118294</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118294</guid><dc:creator><![CDATA[Klaleu]]></dc:creator><pubDate>Fri, 14 Jun 2024 17:05:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Fri, 14 Jun 2024 14:24:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klaleu" aria-label="Profile: Klaleu">@<bdi>Klaleu</bdi></a> I need you to execute the command I listed, now<br />
and show it’s results</p>
<p dir="auto">I need to determine what the permission problem is  exactly before I  can tell you how to resolve it</p>
]]></description><link>https://forum.magicmirror.builders/post/118282</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118282</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 14 Jun 2024 14:24:49 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Fri, 14 Jun 2024 14:21:04 GMT]]></title><description><![CDATA[<p dir="auto">I mean this excerpt from the LOG_file (see my answer of Jun 13, 2024, 4:41 PM):</p>
<p dir="auto">…</p>
<p dir="auto">klaus@raspberrypi:~/MagicMirror $ ls -laF node_modules/.bin/electron-rebuild<br />
lrwxrwxrwx 1 klaus klaus 34 Jun 12 11:38 node_modules/.bin/electron-rebuild -&gt; . ./electron-rebuild/lib/src/cli.js<br />
klaus@raspberrypi:~/MagicMirror $ cd ~/MagicMirror/modules/<br />
klaus@raspberrypi:~/MagicMirror/modules $ git clone <a href="https://github.com/Ax-LED/MMM-Navigate" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Ax-LED/MMM-Navigate</a><br />
Cloning into ‘MMM-Navigate’…<br />
remote: Enumerating objects: 122, done.<br />
remote: Counting objects: 100% (45/45), done.<br />
remote: Compressing objects: 100% (28/28), done.<br />
remote: Total 122 (delta 24), reused 32 (delta 17), pack-reused 77<br />
Receiving objects: 100% (122/122), 442.08 KiB | 449.00 KiB/s, done.<br />
Resolving deltas: 100% (63/63), done.<br />
klaus@raspberrypi:~/MagicMirror/modules $ cd MMM-Navigate<br />
klaus@raspberrypi:~/MagicMirror/modules/MMM-Navigate $ npm install</p>
<p dir="auto">MagicMirror-Module-Navigate@1.6.0 postinstall<br />
./postinstall</p>
<p dir="auto">./postinstall: line 8: …/…/node_modules/.bin/electron-rebuild: Permission denied<br />
npm ERR! code 126<br />
npm ERR! path /home/klaus/MagicMirror/modules/MMM-Navigate<br />
npm ERR! command failed<br />
npm ERR! command sh -c ./postinstall<br />
…</p>
<p dir="auto">You can see I  did “electron-rebuild”  and after that I tried to install MMM-Navigate  without any success.<br />
I you need the hole LOG-File, or  is the excerpt  sufficient?</p>
<p dir="auto">Greatings Klaus</p>
]]></description><link>https://forum.magicmirror.builders/post/118281</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118281</guid><dc:creator><![CDATA[Klaleu]]></dc:creator><pubDate>Fri, 14 Jun 2024 14:21:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Fri, 14 Jun 2024 13:13:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klaleu" aria-label="Profile: Klaleu">@<bdi>Klaleu</bdi></a> log file where?</p>
]]></description><link>https://forum.magicmirror.builders/post/118277</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118277</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 14 Jun 2024 13:13:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Fri, 14 Jun 2024 13:04:14 GMT]]></title><description><![CDATA[<p dir="auto">Hello Sam,<br />
Yes, I did it. For the result please see the LOG file  in my answer of  Jun 13, 2024, 4:41 PM.<br />
I hope I followed your instructions correctly.<br />
Thank you for your efforts.</p>
]]></description><link>https://forum.magicmirror.builders/post/118276</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118276</guid><dc:creator><![CDATA[Klaleu]]></dc:creator><pubDate>Fri, 14 Jun 2024 13:04:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Fri, 14 Jun 2024 17:06:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klaleu" aria-label="Profile: Klaleu">@<bdi>Klaleu</bdi></a> I asked you to do</p>
<pre><code class="language-sh">ls -laF ~/MagicMirror/node_modules/.bin/electron-rebuild
]]></description><link>https://forum.magicmirror.builders/post/118270</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118270</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 14 Jun 2024 17:06:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Fri, 14 Jun 2024 07:55:28 GMT]]></title><description><![CDATA[<p dir="auto">Hello Sam,<br />
I forgot to answer the question. Your question was: Have you ever used sudo for any npm command for MagicMirror? As far as I can remember, I ran the following commands:  and &lt;sudo npm install -g pm2&gt;. If that is the problem, how can I solve it to be able to install MMM-Navigate.<br />
PS I installed over ten modules for my Magic Mirror and none of them had any problems.</p>
]]></description><link>https://forum.magicmirror.builders/post/118267</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118267</guid><dc:creator><![CDATA[Klaleu]]></dc:creator><pubDate>Fri, 14 Jun 2024 07:55:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Thu, 13 Jun 2024 16:08:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klaleu" aria-label="Profile: Klaleu">@<bdi>Klaleu</bdi></a> but the problem is outside the mmm-navigate folder</p>
<p dir="auto">please provide the information  i asked for</p>
]]></description><link>https://forum.magicmirror.builders/post/118256</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118256</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 13 Jun 2024 16:08:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Thu, 13 Jun 2024 14:41:01 GMT]]></title><description><![CDATA[<p dir="auto">Hello Sam,<br />
Thank you for your suggestion to solve the problem. I deleted the old installation of MMM-Navigate by deleting the MMM-Navigate folder in the /MagicMirror/modules/. I then carried out electron-rebuild, unfortunately the following reinstallation of MMM-Navigate resulted in the same errors . Here is a section of my screen.</p>
./postinstall</p>
npm ERR! command sh -c ./postinstall</p>
<p dir="auto">npm ERR! A complete log of this run can be found in: /home/klaus/.npm/_logs/2024-06-13T13_55_36_051Z-debug-0.log</p>
<p dir="auto">Do you have any suggestions as to what I can try to get an error-free installation?<br />
For information - I use:</p>
<ul>
<li>Raspberry Pi 4</li>
<li>Raspbian GNU/Linux Version 11</li>
<li>Modules: alert, updatenotification, MMM-Pages, clock, calendar, MMM-DWD-Pollen, complements, weather, MMM-birthdays, MMM-Rest, MMM-Globe,  MMM-RAIN-MAP, newsfeed</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/118255</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118255</guid><dc:creator><![CDATA[Klaleu]]></dc:creator><pubDate>Thu, 13 Jun 2024 14:41:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Fri, 14 Jun 2024 17:07:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klaleu" aria-label="Profile: Klaleu">@<bdi>Klaleu</bdi></a> said in <a href="/post/118251">MMM-Navigate cannot be installed</a>:</p>
<p dir="auto">postinstall: line 8: …/…/node_modules/.bin/electron-rebuild: Permission denied</p>
<p dir="auto">hm…</p>
<p dir="auto">have you ever used sudo for any npm command for MagicMirror? please don’t</p>
<p dir="auto">can you do this and show results</p>
]]></description><link>https://forum.magicmirror.builders/post/118252</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118252</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 14 Jun 2024 17:07:31 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Navigate cannot be installed on Thu, 13 Jun 2024 10:07:37 GMT]]></title><description><![CDATA[<p dir="auto">Dear Sam,<br />
Many thanks for the quick response. I tried to implement your suggestions, unfortunately without success. But as a non-programmer, I’m not sure whether I did everything right and whether I understood you correctly. Here is a section of my screen. I hope you recognize my mistake and can help me further:</p>
<p dir="auto">klaus@raspberrypi:~/MagicMirror/modules/MMM-Navigate $ ./postinstall<br />
./postinstall: line 8: …/…/node_modules/.bin/electron-rebuild: Permission deni        ed<br />
klaus@raspberrypi:~/MagicMirror/modules/MMM-Navigate $ chmod +x postinstall<br />
./postinstall</p>
<p dir="auto">npm ERR! A complete log of this run can be found in: /home/klaus/.npm/_logs/2024-06-13T09_49_42_926Z-debug-0.log<br />
]]></description><link>https://forum.magicmirror.builders/post/118251</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118251</guid><dc:creator><![CDATA[Klaleu]]></dc:creator><pubDate>Thu, 13 Jun 2024 10:07:37 GMT</pubDate></item></channel></rss>
